    Best way to get all Face's in model?
    25 Posts 5 Posters 3.9k Views 5 Watching
      @draftomatic said:
      It doesn't seem to be working for me. I put it as a method called get_face_array() inside a class called Tester:
      It doesn't return the correct number because the code doesn't take into account instances.
      <span class="syntaxdefault">def number_of_faces<br />  model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />  faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    faces </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end</span>
        Or - even easier if you can settle with SU7.1 or higher:
        model.number_faces
          Oh, wait - you actually need arrays of all the face entities?
            draftomatic
            Well, I really just needed to iterate through all the Faces in the model... the array thing is just useful for testing.
            Bah, I should've realized the instances issue... So your code in the 2nd post isn't quite right 😃
              It depends what you do with it...
              If you need to count the faces you need to take into account all instances.
              But if you need to just iterate over all faces you only need to process model.entities and the entities of each definition, even if a definition has multiple instances, a face in that definition is the same in each instance. It just exist in multiple locations.
                draftomatic
                As you saw a few minutes ago, I'm writing an exporter, and it doesn't keep Component information. I need every Face.
                  draftomatic
                  Closer, but still not working:
                  Here's the get_face_count() method I'm using:
                    def get_face_count()
                      count = 0
                      @model.entities.each { |e|
                        if (e.is_a?(Sketchup;;Face))
                          count +=1
                      @model.definitions.each { |d|
                        next if d.image?
                        next if d.count_instances == 0
                        count += d.entities.select { |e|
                        }.length * d.count_instances
                      return count
                    hm... instances inside other instance might throw the count of...
                    I think you need to traverse the model in a tree like structure
                    <span class="syntaxdefault"><br />def&nbsp;process_model<br />&nbsp;&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new&nbsp;)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;entities<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;faces<br />end<br /></span>
                    (Untested - but something like this)
                      draftomatic
                      Your code had a few lil typos; this one works:
                        def process_model()
                          return walk_faces( Sketchup.active_model.entities )
                        def walk_faces( entities, transformation = Geom;;Transformation.new )
                          faces = []
                          entities.each { |e|
                            if e.is_a?( Sketchup;;Face )
                              faces << e
                            elsif e.is_a?( Sketchup;;Group )
                              faces.concat( walk_faces( e.entities, transformation * e.transformation ) )
                            elsif e.is_a?( Sketchup;;ComponentInstance )
                              faces.concat( walk_faces( e.definition.entities, transformation * e.transformation ) )
                          return faces
                      Thanks Tom, you're the best!
                        There we go - got there in the end! 😄
                          draftomatic
                          One more question - I see you're messing with a transformation - if I ask a nested instance for, say, it's Face's vertices locations (assuming it's just a rectangle or something simple), will it give me the (globally) correct coordinates, or something relative to the Component's origin?
                          I guess ComponentDefinitions have entities, so I can ask for their locations. But ComponentInstances are transformed somewhere... I don't have much experience with transformations...
                          EDIT: Ah nevermind, I see now that you're carrying the transformation through each nesting of an instance. Gotcha.
                          Thanks again Tom
                            Had a feeling the transformation would be needed.
                              soldatino
                              I had the same problem, but I need to get the "material" of each face.
                              So I had a lot of problems because the "material" is hereditary if there is (or not) in the groups of faces (or nested groups). So it is really difficult to get the tree of the materials of all the faces.
                              So I wrote this inelegant recursive sub, and it works fine for me.
                              def pov_ex()
                                 model=Sketchup.active_model
                                 entities=model.entities
                                 entities.each do |entity|
                                      if entity.typename=="ComponentInstance"
                                          entity.explode
                                          pov_ex()
                                      elsif entity.typename=="Group"
                                          entity.explode
                                          pov_ex()
                              at the end, after material's extraction, I wrote a "model.abort_operation" so all the entities return to original state and are not corrupted by explode.
                              But a question... this code works really slow, I'd like to find a better way....
                              r3nDer tools
                                There are two reasons your code is slow:
                                1. You're comparing strings a lot. Don't use .typename to check for entity type. It's very slow. ( See more performance tips here: http://forums.sketchucation.com/viewtopic.php?f=180&t=25305#p217180 )
                                  Instead, test for its class: e.is_a?( Sketchup::Group )
                                2. Exploding is very slow in SU. ( and if your script should fail at some point and halt - you're left with a broken model. )
                                I have a plugin that transfer the group/component materials onto the faces with default materials - here's an extract from that plugin:
                                <span class="syntaxdefault"><br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_materials_to_faces<br />    model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'Instance Material to Faces'</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> true</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> nil </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />  end<br />  <br />  def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> material </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    for e in entities<br />      if TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> e </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        temp_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> material<br />        d </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> TT</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Instance</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> e </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instance_material_to_faces</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> temp_material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxcomment"># Recursive call<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />      elsif e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> material if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">        e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> material if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">      end<br />    end<br />  end<br /></span>
                                Note that I have to custom methods here, not explained:
                                TT::Instance.is?( e ) returns true if the entity is a Group or ComponentInstance
                                TT::Instance.definition( e ) return the definition of a Group or ComponentInstance
                                  soldatino
                                  Thanks for your responce!
                                  Yes, teorically the strings compare is ever slow ... but here the difference is irrelevant more than in other languages, I checked a large file, and the part of the scanning and explode sub is the 99.99% of the working code of my parser.
                                  if entity.is_a?(Sketchup::ComponentInstance)
                                  and groups ...
                                  start 13:49:42 -> end 14:08:26
                                  and groups ..
                                  start 14:11:30 -> end 14:29:07
                                  In the second reason (explode is slow insted of get from material list) you are right 100%, but it is a bit complicated for me at this time (I am new about skup database).... but next time I must to improve at...
                                  I was hoping that there are something like these easy :
                                  group_parent.face .... group_parent.group ...
                                  but the only parent seems to be the entire list of materials...
                                  Thanks again, I apologize for my bad english.
                                  r3nDer tools
                                    It's a significant difference - check out the test data in this thread: http://forums.sketchucation.com/viewtopic.php?f=323&t=19576&st=0&sk=t&sd=a&start=15#p166698
                                    is_a? - 16.297c
                                    kind_of? - 16.141c
                                    class - 18.703c
                                    typename - 88.703c
                                      soldatino
                                      ok! I changed my way and it seems work alot faster! (for my plugin converter 2 POV-Ray script).
                                      note: At this time I get only the color of the parent object(s) and not texture...
                                       def pov_find_faces(entities,tform,layername)
                                          if entity.is_a?(Sketchup;;Face)
                                            pov_write_face(entity, tform)
                                          elsif entity.is_a?(Sketchup;;Group)
                                            if entity.material
                                              if entity.material.color
                                                $levelcolor[$level]=entity.material.color
                                              else
                                                $levelcolor[$level]=$levelcolor[$level-1]
                                              if entity.material.alpha
                                                $levelalpha[$level]=entity.material.alpha.to_s
                                              else
                                                $levelalpha[$level]=$levelalpha[$level-1]
                                            else
                                            $level+=1
                                            pov_find_faces(entity.entities,tform * entity.transformation,entity.name)
                                          elsif entity.is_a?(Sketchup;;ComponentInstance)
                                            if entity.material
                                              else
                                              else
                                            else
                                            $level+=1
                                            pov_find_faces(entity.definition.entities,tform * entity.transformation,entity.name)
                                        $level=$level-1
                                        #UI.messagebox($level.to_s)
                                      r3nDer tools
