    Best way to get all Face's in model?
    25 Posts 5 Posters 2.3k Views 5 Watching
      draftomatic
      I'm having trouble getting an Array of all Face's in the model, since Sketchup.active_model.entities returns Group objects, without the Face's contained within them.
        model = Sketchup.active_model
        faces = []
        faces.concat( model.entities.select{|e| e.is_a?( Sketchup;;Face ) }
        model.definitions.each { |d|
          next if d.image?
          faces.concat( d.entities.select{|e| e.is_a?( Sketchup;;Face ) }
          draftomatic
          Thanks thomthom!
          • E Offline
            exvion
            thomthom, I run your code on Sketchup 7.1:
            (eval);508; compile error
            (eval);505; syntax error, unexpected tIDENTIFIER, expecting ')'
            (eval);508; syntax error, unexpected '}', expecting ')'<<< Process finished.
            • TIGT Online
              Ther was a typo [a missing ')'...]
                  faces = []
                    next if d.image?
                    faces.concat( d.entities.select{|e| e.is_a?( Sketchup;;Face ) } )
              • E Offline
                exvion
                This code work:
                    faces = []
                    faces.concat( model.entities.select{|e| e.is_a?( Sketchup;;Face ) }    )
                      next if d.image?
                  draftomatic
                  @exvion said:
                  This code work:
                  >     faces = []
                  >       next if d.image?
                  It doesn't seem to be working for me. I put it as a method called get_face_array() inside a class called Tester:
                  This is a 68.2MB model.
                    faces = [] faces.concat( model.entities.select{|e| e.is_a?( Sketchup::Face ) } )
                    Could be simplified to:
                    faces = model.entities.select{|e| e.is_a?( Sketchup::Face ) }
                      It doesn't return the correct number because the code doesn't take into account instances.
                      <span class="syntaxdefault">def number_of_faces<br />  model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />  faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> 0<br />    faces </span><span class="syntaxkeyword">+=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword">*</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">count_instances </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end</span>
                        Or - even easier if you can settle with SU7.1 or higher:
                        model.number_faces
                          Oh, wait - you actually need arrays of all the face entities?
                            draftomatic
                            Well, I really just needed to iterate through all the Faces in the model... the array thing is just useful for testing.
                            Bah, I should've realized the instances issue... So your code in the 2nd post isn't quite right 😃
                              It depends what you do with it...
                              If you need to count the faces you need to take into account all instances.
                              But if you need to just iterate over all faces you only need to process model.entities and the entities of each definition, even if a definition has multiple instances, a face in that definition is the same in each instance. It just exist in multiple locations.
                                draftomatic
                                As you saw a few minutes ago, I'm writing an exporter, and it doesn't keep Component information. I need every Face.
                                  draftomatic
                                  Closer, but still not working:
                                  Here's the get_face_count() method I'm using:
                                    def get_face_count()
                                      count = 0
                                      @model.entities.each { |e|
                                        if (e.is_a?(Sketchup;;Face))
                                          count +=1
                                      @model.definitions.each { |d|
                                        next if d.image?
                                        next if d.count_instances == 0
                                        count += d.entities.select { |e|
                                        }.length * d.count_instances
                                      return count
                                    hm... instances inside other instance might throw the count of...
                                    I think you need to traverse the model in a tree like structure
                                    <span class="syntaxdefault"><br />def&nbsp;process_model<br />&nbsp;&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /><br />def&nbsp;walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new&nbsp;)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;[]<br />&nbsp;&nbsp;for&nbsp;</span><span class="syntaxdefault">e&nbsp;in&nbsp;entities<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">e<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;elseif&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">ComponentInstance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">concat</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">walk_faces</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">*&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)&nbsp;)<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;end<br />&nbsp;&nbsp;faces<br />end<br /></span>
                                    (Untested - but something like this)
                                      draftomatic
                                      Your code had a few lil typos; this one works:
                                        def process_model()
                                          return walk_faces( Sketchup.active_model.entities )
                                        def walk_faces( entities, transformation = Geom;;Transformation.new )
                                          faces = []
                                          entities.each { |e|
                                            if e.is_a?( Sketchup;;Face )
                                              faces << e
                                            elsif e.is_a?( Sketchup;;Group )
                                              faces.concat( walk_faces( e.entities, transformation * e.transformation ) )
                                            elsif e.is_a?( Sketchup;;ComponentInstance )
                                              faces.concat( walk_faces( e.definition.entities, transformation * e.transformation ) )
                                          return faces
                                      Thanks Tom, you're the best!
                                        There we go - got there in the end! 😄
                                          draftomatic
                                          One more question - I see you're messing with a transformation - if I ask a nested instance for, say, it's Face's vertices locations (assuming it's just a rectangle or something simple), will it give me the (globally) correct coordinates, or something relative to the Component's origin?
                                          I guess ComponentDefinitions have entities, so I can ask for their locations. But ComponentInstances are transformed somewhere... I don't have much experience with transformations...
                                          EDIT: Ah nevermind, I see now that you're carrying the transformation through each nesting of an instance. Gotcha.
                                          Thanks again Tom
                                            Had a feeling the transformation would be needed.
