    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 118.4k Views 34 Watching
    • EarthMoverE Offline
      EarthMover
      Jeff, you're right. I've always tried to make arrays with the tape measure tool by itself after pulling a cline off of an edge. Using the move tool works as expected. A truly "duh" moment for me! 😲 😆
      Content Creator at Skapeup
      • jeff hammondJ Offline
        That'd be sweet though. Something that google could/should add to standard SU as it wouldn't compromise simplicity for a bit more complexity. There are a few native tools that could acquire added functions while staying true to the vision. (multiface pushpull is another example)
          @earthmover said:
          (On a side note, can you implement a multiple copy array feature to your divide face tool? That would be very handy! 😛)
          It already has. After placing a line you can type * or / to add more lines. Even adjust the amounts.
            WorkPlane Disk!
            But I have seen this plug who transform a line in "guide lines"
            Xline by Rick WilsonConvert edges to construction lines at Smustard
            Seems that works for any curves (arc, circle) ☀
            apply with other plugs who need lines construction that work ☀
            but when I convert circle that works not 😞
            The plug is this one, for the moment works with lines guide and with more difficulties with my circle line guides
            (even with the working plan circular explosed)
            Surely something in the plug itself!
            Drilling Milling by Menfin (French and English version) ☀
            [flash=640,385:3rqxvkx7]http://www.youtube.com/v/KwehT4_aM1M?fs=1&amp[/flash:3rqxvkx7]
              Panga
              Just wanted to add a big thanks for this plugin which saved me today !! 😍
                Version 1.2.0
                • CPoint at Edge-Face Intersection
                • CPoint at Edge-Edge Intersection
                  And CPoint at intersection of Guides lines?
                  Intersection of selected construction guides?
                    EarthMover
                    Perhaps I need to update my version then. The one I have doesn't. That's great news though! Sorry for the redundant questions. 😳
                    EDIT - Ahhh, you're right, I'm an idiot. It seems the / key on the keyboard doesn't work, but the one on the Num pad works. I usually put my / or "x" after the number and I usually use "X" instead of * to make forward arrays. Using the * or / from the keypad and using them first instead of last works as expected. Sorry again for the bother.
                      if it's not a very hard work, sure with extrem pleasure! ☀
                      (but maybe it's include with your last version, take me five minutes for test it 😄
                        Seems don't works for the V 6 😮
                        I will test the V 7
                        Works for the the V 7 ! ☀
                        (so maybe i must intersect before in the V6 😉
                        That is that!!! 😎
                        Works in the V6 when I Intersect before! 👍
                        (of course if you can make an autoùatic intersction in the V6 that will be luxuous ☀
                        PS And you write 😉
                        1.1.0 - 11.10.2010
                        * CPoint at Edge-Face Intersection
                        * CPoint at Edge-Edge Intersection
                          Yea, I made the assumption that edges split each other, not just overlapping. I never use SU6 any more - forgotten it didn't auto-split edges.
                            And this (not a big deal as I can move and re put) but... 😄
                            it's because segments touch the perimeter? (only "loose" edges)
                              😄 Yes old but so charming! 😎
                                Nah - this is charming: http://www.youtube.com/watch?v=mOZqRJzE8xg
                                  And one existential question with the Cpoint at Arcs Center! 🤓
                                  (of course from a same circle trimed) 😉
                                    Very Romantic yes 😄
                                    But there is a little problem 😮
                                    That works not with that! 😲
                                    (I have also tried with explode Circle, convert, erase..., not better) !
                                    Good result must be 5 CPpoints !
                                    Else of course your plug if very fun (and useful) for this sort of thing 😉
                                    CPoint at Circle Center
                                    Insert Components at CPoints 👍
                                    And of course Selection Toys for Select CPoints 😉
                                    http://forums.sketchucation.com/download/file.php?id=56417
                                      Very Romantic yes 😄
                                      [attachment=0:26fwmhk5]<!-- ia0 -->worksnot1.jpg<!-- ia0 -->[/attachment:26fwmhk5]
                                      Are these edges that's split each other?
                                      From your original request I thought you wanted cpoints at edge crossings if the edge where not part of a face.
                                      Maybe it should just not check if edges are connected to faces?
                                      Should it only place a cpoint for overlapping edges (but does not split each other? )
                                      [attachment=0:26fwmhk5]<!-- ia0 -->existential.png<!-- ia0 -->[/attachment:26fwmhk5]
                                      I don't understand the question...
                                        In fact just put a CPoint at any real intersections of a selection of lines and/or circles, arc circle and /or curves
                                        on faces or in the space
                                        (i don't know if it's an hard work or not) 😳
                                        for the existential question 😄
                                        an Arc Circle A has a Cpoint CPA, xa , ya, za
                                        an Arc Circle B has a Cpoint CPB xb, yb, zb
                                        but of course as you can see on my previous image
                                        because arc are from a same circle
                                        xa = xb, ya = yb, za = zb
                                        So my question what about this "double CPoint"?
                                        is there 2 Cpoints or you merge it in only one?
                                          Where edges are split where they intersect? Or where they overlap - like they often do in SU6 and older?
                                          Doesn't check for existing CPoints.
                                            I don't know, on the face I suppose 😳
                                            In any case we have solution to move them out the face (when existing)
                                            call the plug, and re put on the face 😄
                                            So there are 2CPoint overlaped
                                            or they are automatical merged as one by SU as having same coordinates ?
                                            (same than you draw 2 lines ovelapped)
                                            • 2 / 5
