    [Plugin] C of G Reporter 1.3
    41 Posts 8 Posters 82.8k Views 8 Watching
      @ Tig
      The big mystery is why so much languages? 😉
        Bertier
        MERCI / THANK YOU / Danke !
        that is awsome !
          Bertier
          Hello TIG
          tryed it, got this :
          cofgreporter
          Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in +': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81 C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in cofgreporter'
          (eval):0
            Bertier
            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
            The error in the error message is fixed!
            Please retry...
            To be on the safe site please ensure your file_path/skp_name contains no accented characters - SUp's Ruby is not happy with unicoded characters 😞
              Bertier
              will do now;
              thank you
                Bertier
                new error message :
                cofreporter
                Error: #<NameError: undefined local variable or method `cofreporter' for main:Object>
                (eval)
                  @bertier said:
                  new error message :
                  cofreporter
                  (eval)
                  It's cof****g****reporter - you mistyped! 😒
                    Bertier
                    oops...
                      Bertier
                      working but :
                      CoG Report File:
                      'F:\neo batitrad\Bar & Ka/console_CofG_Report.csv'
                      Cannot be written - it's probably already open.
                      Close it and try making the Report again...
                      Exiting.
                      nil
                      and it's not open, cause it's not written yet !
                        @bertier said:
                        working but :
                        CoG Report File:
                        Exiting.
                        nil
                        Try renaming the folder 'Bar & Ka' to 'Bar_Ka' - The '&' in the file_path might be the culprit ?
                        Also is your model SKP really called 'console.skp' ?
                        Try the version 1.2 which has more error messages, that might report what is really up...
                          Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                          with some extra error reporting to try and trap Bertier's reported cryptic error messages...
                            Bertier
                            thank you TIG
                            I'll try this tonite, got to get the kids at their grand parents now.
                            where are you from ?
                              It's a secret but there's a clue in his profile 😉
                                If accents are forbidden, that is very annoyous for French Windows System 😲
                                Because there is an accent for the principal Desk and for some of path! !!! 😮
                                C:\Documents and Settings\Propriétaire\Bureau
                                PS I have not the use of this plug, but it's by curiosity 😄
                                Of course now I obtain nothing 😄
                                except this 😄 (i have saved my object with Cof as Untitled.skp
                                curious is the "/" and ""
                                cofgreporter
                                No such file or directory - C;\Documents and Settings\Propriétaire\Bureau/Untitled_CofG_Report.csv
                                CoG Report File;
                                'C;\Documents and Settings\Propriétaire\Bureau/Untitled_CofG_Report.csv'
                                Exiting.
                                nil
                                Edit: That works when I use a path without accent for save my file! 😎 👍
                                  The Unicode paradox is an annoying bit of Sketchup's Ruby - some of the 'File' functions don't work properly if there are accented characters etc in path_names etc... Sorry!
                                  At least we know the cause of the problem...
                                  The \ / is also from the same methods when you get the filepath on a PC it has \ separators [/ on MAC], when you join on the new file_name it's always with the as the ;joining; separator / - but it still works OK... 😒
                                    Bertier
                                    there is no accent in my path ....
                                    cofgreporter
                                    undefined method `definition' for #Sketchup::Group:0xe005344
                                    CoG Report File:
                                    'F:\neo batitrad\Bar_Ka/console_CofG_Report.csv'
                                    Exiting.
                                    nil
                                      Have you save your file SKp in the samme path?
                                        Bertier
                                        Did you install v1.2
                                        Although it might still fail you should get more error messages... 😕
                                          Heres's v1.3 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                                          It corrects the glitch that a few users might get with 'group.definition' - OK if you have some of my other tools installed but not this one alone - now sorted...
                                          Please try and report back... 😕
                                            Bertier
                                            hooray !
                                            it's working :
                                            cofgreporter
                                            CofG Report written to
                                            nil
                                            nice.
                                            • 3 / 3
