    [Plugin] C of G Reporter 1.3
    41 Posts 8 Posters 84.0k Views 8 Watching
    • W Offline
      watkins
      Dear TIG,
      Thanks for the explanation.
      Regards,
      Bob
        You can always move the text-tag by editing the CofG group...
        Thanks, Pilou
        ...Comme toujours, je peut te faire confiance...
        Aucun problème !
        • KrisidiousK Offline
          Krisidious
          does this do Imperial Weights too?
          By: Kristoff Rand
            @Tig 😄
            Je peut no, Je peux yes
            a very useful thing for French verbs and conjugation ☀
            (on left top page: enter the verb, press ok ..and scroll )
              If you use the 'imperial' measurements for the CogG volumes and density...
              Possible units are "kg/m3", "tonnes/m3", "g/cm3", "tons/yd3", "lbs/ft3"
              If others were preferred they could be added...
                @Tig 😄
                Pilou 😞
                I know!
                I can..., thou canst..., he/she/it can..., we can..., you can... they can...? [can!]
                My French is rubbish [but, so is your English! 😉 ]
                Je le sais!
                Je peux..., tu peux...,il/elle peut..., nous pouvons..., vous pouvez... ils/elles peuvent? [pu!]
                Mon Français est des déchets [mais c'est que t'anglais! 😉 ]
                In good humour...
                Dans la bonne humeur ...
                l'eau is water
                la peau is skin
                Both of these nouns are considered male, there is no reason behind this it is just the way the language works!
                Similarly there are rules for female nouns such as:
                un périphérique is a peripheral
                un graphique is a graph........................ 😕
                  Krisidious
                  excellente' sorry wrong language...
                  now another question... I know this is kinda off subject. what is the implication of this plugin, does this allude to a future where these weights could be transfered through shear force or straight line force?
                  the reason I ask is that I look forward to a time when I can build roofs, beams or arches and have their loads followed and measured.
                  SketchyPhysics got me excited about the possibility... that a model could have gravity and therefore transfer weight and force towards a central point.
                  thanks for another great plugin...
                  By: Kristoff Rand
                    Kristoff
                    No reason why not... BUT we just haven't written it yet... 🤓
                      @ Tig
                      The big mystery is why so much languages? 😉
                        Bertier
                        MERCI / THANK YOU / Danke !
                        that is awsome !
                          Bertier
                          Hello TIG
                          tryed it, got this :
                          cofgreporter
                          Error: #<TypeError: C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in +': can't convert nil into String> C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81 C:/Program Files/Google/Google SketchUp 8/Plugins/cofgreporter.rb:81:in cofgreporter'
                          (eval):0
                            Bertier
                            Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                            The error in the error message is fixed!
                            Please retry...
                            To be on the safe site please ensure your file_path/skp_name contains no accented characters - SUp's Ruby is not happy with unicoded characters 😞
                              Bertier
                              will do now;
                              thank you
                                Bertier
                                new error message :
                                cofreporter
                                Error: #<NameError: undefined local variable or method `cofreporter' for main:Object>
                                (eval)
                                  @bertier said:
                                  new error message :
                                  cofreporter
                                  (eval)
                                  It's cof****g****reporter - you mistyped! 😒
                                    Bertier
                                    oops...
                                      Bertier
                                      working but :
                                      CoG Report File:
                                      'F:\neo batitrad\Bar & Ka/console_CofG_Report.csv'
                                      Cannot be written - it's probably already open.
                                      Close it and try making the Report again...
                                      Exiting.
                                      nil
                                      and it's not open, cause it's not written yet !
                                        @bertier said:
                                        working but :
                                        CoG Report File:
                                        Exiting.
                                        nil
                                        Try renaming the folder 'Bar & Ka' to 'Bar_Ka' - The '&' in the file_path might be the culprit ?
                                        Also is your model SKP really called 'console.skp' ?
                                        Try the version 1.2 which has more error messages, that might report what is really up...
                                          Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=278046#p278046
                                          with some extra error reporting to try and trap Bertier's reported cryptic error messages...
                                            Bertier
                                            thank you TIG
                                            I'll try this tonite, got to get the kids at their grand parents now.
                                            where are you from ?
                                            • 1 / 3
