    Going nuts - Orient Faces
    11 Posts 7 Posters 1.6k Views 7 Watching
      Tomasz's FrontFace will make quick work of it.
      • GaieusG
        There IS in the context menu. Make sure however NOT to pre-select multiple faces - just right click the ONE you want all the others oriented with.
        It will work with unexpected results however when the model is not "solid" (with a newer SU term).
        • H
          Hepf
          I do that by selecting faces, right mouse button click, select "invert faces". It works also with multiple selectons ...
            Sometimes very complex objects are impossible to resolve without hands πŸ˜’
              On non-solids.
              • jgbJ
                jgb
                OK, it worked. Thankyou. 😍
                I was selecting the whole surface, rather than a single face.
                But why is that tool NOT in any help file? I searched under both Face and Orient. NO hits dealing with Orient Face.
                jgb
                • GaieusG
                  This place is the addendumto the help file.
                  πŸ˜‰
                  • jgbJ
                    jgb
                    πŸ˜‰
                    Agreed, but it is just a little slower in finding things. πŸ˜‰
                    Much better explanations though. β˜€
                    jgb
                    • Jean LemireJ
                      Jean Lemire
                      Hi folks.
                      After entering the Help center directly from the Help Menu of SU, I typed "orient face" (without the quotes) in the search field and I get there:
                      http://sketchup.google.com/support/bin/search.py?ctx=en%3Asearchbox&query=orient+face
                      If I click on the first link I get there:
                      http://sketchup.google.com/support/bin/answer.py?hl=en&answer=70117
                      If I scroll down I see this:
                      ----- START OF EXCERPT -----
                      Orient Faces
                      The Orient Faces menu item is used to automatically orient all the connected faces of your model to the orientation of the currently selected face. This option could lead to unexpected results when an edge of a face bounds three or more other faces.
                      This menu item is available for the Face and Surface entities.
                      ----- END OF EXCERPT -----
                      Just ideas.
                        On non-solids.
                        Even on solid !
                        "Double faces" are so mixed that is impossible to solve πŸ˜„
                        (with SU Scripts or Reverse, Orient functions πŸ˜„
                        Hands are necessary πŸ’š
