    Google Earth into Sketchup?
    23 Posts 9 Posters 2.5k Views 9 Watching
      Well with 8 it imports in colour then save as 7...voila
      • jeff hammondJ Offline
        besides 8 being in color, it also has more detailed and precise terrain elevations.
        edit- and you don't have to also use google earth with su8
        • olisheaO Offline
          olishea
          cheers guys massive help!! its for a university project, im designing a shrine of all things. 😄
          i just deleted sketchup 8 out of frustration! time to reinstall..... 😳
          oli
          • charly2008C Offline
            charly2008
            Please, can you help me with this problem i asked in the post below.
            404 Not Found
            (forums.sketchucation.com)
            Charly
            • olisheaO Offline
              olishea
              can i just ask why you still want to import into sketchup 7? you get a colour texture in sketchup 8....
              oli
                You asking charly or the world?
                • soloS Offline
                  Too bad that the image resolution is still pretty weak in version 8, I believe that bing 3d maps may be better. 😲
                    charly2008
                    Hi Olishea,
                    I have also ver.8 but mainly I still work with 7.1. And I can not stop if something is not working properly.
                    Charly
                      d12dozr
                      Pete, is there a way to get Bing data into Sketchup?
                      http://goo.gl/f7ooYh
                      • olisheaO Offline
                        olishea
                        same here charly, i'm still with 7.1 for most work. 😄
                        is there a way of saving the spherical image from google street views? i can see the preview in google earth (see screengrab) but i cant save the whole image.....any suggestions? (besides stitching)
                        oli
                          Some places, yes. My city's just a barely coloured blob in Bing. The new SU 8 import brings in the best available resolution both for the imagery and the terrain (when zoomed in properly).
                            charly2008
                            Csaba,
                            I agree with you. Also the terrain overlap in SKP 8 has been clearly improved. Yesterday I bought a 24 "widescreen monitor and I'm thrilled that I can now import huge pieces. It is a pity that the selection window, only in height but not can change in width.
                            Charly
                              I would still like a safe and precise way to merge those terrains (hopefully not completely manually).
                                charly2008
                                I would like also. The other would be a better projection of the image. But I do not know if such a thing were possible. That would probably require a more accurate DTM.
                                  Hehe. That's a neat, slanting shoreline!
                                    Ross Macintosh
                                    Charly, at the recent 3dBaseCamp, it was noted by the SketchUp developers that the resolution of the terrain will (if the data is available in Google's database) be imported at a higher resolution if your grab area is smaller. For instance, if you have a smaller building site on the island then grab it as well but making the grab only as big as you need. It can allow you to get higher resolution where you need it most by combining it with the big grabs.
                                    They also noted that the terrain in SUv8 can actually be higher resolution than it appears in Google Earth. SketchUp now has access to the same source database that is used by Google Earth. The difference is Google Earth down-samples if the database file has excessive resolution whereas SketchUp can bring it in full resolution if the grab area is relatively small. Apparently there are some limited areas of the world in the database that have resolution the equivalent of 6" contour intervals!
                                    Regards, Ross
                                      charly2008
                                      Hi Ross,
                                      Thanks for the note. What I meant is that for example the floor plan of the Roman Villa Jovis and the water lines are not placed correctly.
