    Google Earth into Sketchup?
    23 Posts 9 Posters 2.7k Views 9 Watching
    • olisheaO
      olishea
      Im using 7.1 because I can still import dwg files for free!
      Shame how they removed this feature from 8, an incentive to buy I guess.
      right i'll give it a go now. cheers
      oli
        A weak marketing ploy as you can still keep 7.1 just to do your dwg imports and then import that file into a v8 skp... however, v8 does offer several other new features as well as various format import, like Layout and boolean ops...
        • olisheaO
          olishea
          BINGO!! Is this one of those 'duh' moments?
          how come the actual satellite photo texture is in black and white?
          TIG. yeah i really liked the bool style tools but I just didn't think they were worth the money. Also, photomatch is now crap!! I have to use 7.1 because there are less features in the new one!! WHY?!! 👿
          oli
            Well with 8 it imports in colour then save as 7...voila
            • jeff hammondJ
              besides 8 being in color, it also has more detailed and precise terrain elevations.
              edit- and you don't have to also use google earth with su8
              • olisheaO
                olishea
                cheers guys massive help!! its for a university project, im designing a shrine of all things. 😄
                i just deleted sketchup 8 out of frustration! time to reinstall..... 😳
                oli
                • charly2008C
                  charly2008
                  Please, can you help me with this problem i asked in the post below.
                  http://forums.sketchucation.com/viewtopic.php?f=15&t=31427&p=276692#p276692
                  Charly
                  • olisheaO
                    olishea
                    can i just ask why you still want to import into sketchup 7? you get a colour texture in sketchup 8....
                    oli
                      You asking charly or the world?
                      • soloS
                        Too bad that the image resolution is still pretty weak in version 8, I believe that bing 3d maps may be better. 😲
                        • charly2008C
                          charly2008
                          Hi Olishea,
                          I have also ver.8 but mainly I still work with 7.1. And I can not stop if something is not working properly.
                          Charly
                            d12dozr
                            Pete, is there a way to get Bing data into Sketchup?
                            http://goo.gl/f7ooYh
                            • olisheaO
                              olishea
                              same here charly, i'm still with 7.1 for most work. 😄
                              is there a way of saving the spherical image from google street views? i can see the preview in google earth (see screengrab) but i cant save the whole image.....any suggestions? (besides stitching)
                              oli
                              • GaieusG
                                Some places, yes. My city's just a barely coloured blob in Bing. The new SU 8 import brings in the best available resolution both for the imagery and the terrain (when zoomed in properly).
                                • charly2008C
                                  charly2008
                                  Csaba,
                                  I agree with you. Also the terrain overlap in SKP 8 has been clearly improved. Yesterday I bought a 24 "widescreen monitor and I'm thrilled that I can now import huge pieces. It is a pity that the selection window, only in height but not can change in width.
                                  Charly
                                  • GaieusG
                                    I would still like a safe and precise way to merge those terrains (hopefully not completely manually).
                                    • charly2008C
                                      charly2008
                                      I would like also. The other would be a better projection of the image. But I do not know if such a thing were possible. That would probably require a more accurate DTM.
                                      • GaieusG
                                        Hehe. That's a neat, slanting shoreline!
                                          Ross Macintosh
                                          Charly, at the recent 3dBaseCamp, it was noted by the SketchUp developers that the resolution of the terrain will (if the data is available in Google's database) be imported at a higher resolution if your grab area is smaller. For instance, if you have a smaller building site on the island then grab it as well but making the grab only as big as you need. It can allow you to get higher resolution where you need it most by combining it with the big grabs.
                                          They also noted that the terrain in SUv8 can actually be higher resolution than it appears in Google Earth. SketchUp now has access to the same source database that is used by Google Earth. The difference is Google Earth down-samples if the database file has excessive resolution whereas SketchUp can bring it in full resolution if the grab area is relatively small. Apparently there are some limited areas of the world in the database that have resolution the equivalent of 6" contour intervals!
                                          Regards, Ross
                                          • charly2008C
                                            charly2008
                                            Hi Ross,
                                            Thanks for the note. What I meant is that for example the floor plan of the Roman Villa Jovis and the water lines are not placed correctly.
