    Preview SU files on Mac
    10 Posts 4 Posters 1.9k Views 4 Watching
      liam887
      Anybody know if this is possible? I know on windows you get thumbnails of the model and on MAC this is not possible but is there any other way of looking at a file without opening it in SU?
      Problem is I am cleaning up my drive and I have so many SU files taking up a ton of space I think I can delete a few hundred of the 16GB worth I have 😲 !
      VISIT MY ONLINE GALLERY
      • jeff hammondJ Offline
        There's an app called graphic converter that you can see preview thumbs with (even if they weren't saved with su's 'custom icon')
        Get the demo version ( which you can use as much as you'd like. There's a ten second startup wait with the trial version)
          liam887
          thanks Jeff lifesaver and timesaver!!!!
          Is this is http://www.macupdate.com/info.php/id/263/graphicconverter-x
            oh nice.. they updated it to version 7 which looks much better (as in, the UI looks better)
            there's a filter at the bottom of the browser window but i can't figure out how to show only SKP previews .. when you click on a skp preview, it says the file format is 'SKP preview' but i can't single them out..
            probably in your case it might be best to have the skps in folders and go through each folder individually?
            [edit] oh wait!.. you can make an osx smart folder (opt/cmmd/N in finder.. type skp in the search bar and switch to file name or type) which will show all the skps on your system then browse that folder via graphicconverter.. that way, you'll see previews of every skp on your system.. sort by name, date, etc if you wish.
            • F Offline
              fakircho
              Graphic converter works, but why can we not get a native support under OSX for previews??? 😠
                liam887
                I think I spoke about this matter with a member of the google sketchup team at basecamp and the OSX architecture just doesn't support this option I think? Could be wrong.
                  tfdesign
                  @liam887 said:
                  Could be wrong.
                  I'm afraid you are. SketchUp has been written in Cocoa. There is absolutely no reason why this shouldn't work (after all, why do we have Coverflow?? πŸ˜„). All Google need to do is to write a simple script that takes a snapshot of the screen when the last save was pressed, or when the window was closed (upon saving). The resulting image then appears as an icon within the resources part of the app bundle. High resolution as much as possible of course! Simple.
                    fwiw, there's another app out there called file juicer
                    it can extract every image associated with a skp..
                    ie- a monochrome view, a textured one, every scene thumbnail, all texture files, + anything else that's saved in the skp..
                    [JPEG, JP2, PNG, GIF, PDF, BMP, WMF, EMF, PICT, TIFF, Flash, Zip, HTML, WAV, MP3, AVI, MOV, MPG, WMV, MP4, AU, AIFF or text file ]
                    here's a typical looking html sheet from a skp file..
                      liam887
                      @tfdesign said:
                      @liam887 said:
                      Could be wrong.
                      well then hopefully some of the ruby guys could write a little file browser to use within sketchup that would be great!
                      nice ill have a little gander at that later Jeff
                        tfdesign
                        That's a nice idea, but I don't think it would work, because the code has to be written within the app itself. It would probably be best just to badger Google more for an update in SU9.
