    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
      To 'cobble' = to make shoes, or pave with small stones.
      To 'clobber' = to beat up or bash.
      I 'clobbered it together' by bashing square pegs into round holes, until it surrendered.
      Whereas 'cobbled together' suggested 'botched or bungled'... and I hope it's not that...
      but I am not a 'cobbler' - as the skill of making a 'fine shoe' is beyond me !
      πŸ‘Š πŸ˜’
      • mitcorbM
        mitcorb
        Well, no intense offended. πŸ˜†
        • utilerU
          utiler
          πŸ‘Š πŸ˜’
          FWIW, in addition to this explanation, a 'cobber' in Australia is a friend of mate.
          Thanks cobber, great work!!
          πŸ‘
          Just Curious...
          • CadFatherC
            CadFather
            ..i would vote the option of having the plane not centered retained (like in version one)
              I propose the following - perhaps to satisfy all and to satisfy no one...
              The WorkPlane is still made centered by default, BUT IF you press <Tab> before picking the 1st point the alignment is that the corner is now the 1st point...
              You can still use the context-menu 'Move Selected' to relocate it as desired...
              There would be new options in the context-menu...
              'Scale Selected' - this unlocks the selected WorkPlane, starts the main 'Scale' tool and then re-locks the WorkPlane on completion...
              'Rotate Selected' - this unlocks the selected WorkPlane, starts the main 'Rotate' tool and then re-locks the WorkPlane on completion...
              I'm also considering a 'New Disk' version where it makes a centered WorkPlane 'disk' with a picked radius and radial lines at division angles [15 degrees default] changeable in a dialog... and a 'Toggle Center:Corner' option on a selected WorkPlane too...
              Comments welcome...
              • CadFatherC
                CadFather
                no comment! πŸ‘ πŸ‘
                  You are always on the top action! 😎
                  • mitcorbM
                    mitcorb
                    Tool versatility would always be my vote. You always have to balance this with simplicity, I suppose. πŸ˜’
                      Maybe a real radial grid will be fun πŸ˜„
                      http://forums.sketchucation.com/download/file.php?id=55720
                      • EarthMoverE
                        EarthMover
                        I agree with Mitcorb - Workflow is key. For me, pulling some of the items out of the right click menu and having an extended toolbar would be beneficial. Rotate, Move, Scale and Delete, specifically would be better served in a toolbar, IMO. I would like to be able to manipulate the workplane on the fly as much as possible. Would make for a better ability to use work planes when vertex editing.
                        Everything else you are mentioning adding sounds perfect!
                        BTW - I think this plugin deserves a mention in The Daily Catchup!
                        Content Creator at Skapeup
                          WHEN I get the other options working I'll look at extending some of the toolbar items too... πŸ€“
                            Here's v2.1 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                            There are lots of changes...
                            Please read the notes on the linked page - I think I've addressed all issues to date. πŸ€“
                            • CadFatherC
                              CadFather
                              • EarthMoverE
                                EarthMover
                                Wow killer update! πŸ‘ πŸ‘
                                  dedmin
                                  Excellent work, TIG! You guys just don't let me go away from SketchUP!
                                    Seems near perfection πŸ˜„
                                    Seems just missing πŸ˜„
                                    in adjust ask number of circles
                                    and "center" is always some tricky ergonomy : possible with inference
                                    but not evident on an inclined plan! πŸ˜‰
                                    I arrive one time on 20 try and must think! 😳
                                    Will be more easy with another paradigme πŸ˜„
                                    Center point = (pt1 pt2)/2 , (pt2 pt3)/2
                                    and diameter size = smaller edge
                                    (ok I can draw a diagonal for have the middle and then the center but...)
                                      PS Something curious when you "adjust" a circular Plane you obtain the Adjust menu of the rectangular work plane and of course Cirular is transformed in rectangular πŸ˜„!
                                      Edit That was in the notes 😳
                                        Pilou!
                                        I just knew you'd ask this... πŸ˜’
                                        'Adjust' should recognize a rectangular and disk shaped WorkPlane and thereafter have alternative dialogs... it's on the list...
                                        Currently you shouldn't get 'Adjust' as an option at all if the selected WorkPlane is a disk.
                                        This coding error could be corrected... but I supposed one day soon I'll have to fix the 'Adjust' to do both kinds anyway...
                                        πŸ˜’ πŸ˜’ πŸ˜’
                                        • kenK
                                          ken
                                          Since the Cline Axes and Cline Normal are used to check alignment, would it be possible to add a set of TAB toggling 3 workplane disks at the origin of both of these plugin, so one would have a workplane to align the protractor. They would need to be to large, just big enough to allow one to the set the protractor's to the plane.
                                          Thank you for ALL the work.
                                          Ken
                                            Ken
                                            I suppose I could add an extra type 'WorkPlane...' > 'New Protractor' to do that - it's be quite easy to make...
                                            • 6 / 10
