    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
    • C
      cheriyan
      Thanks for this plugins
      • gullfoG
        gullfo
        @jasper.middelberg said:
        yet I discovered that bending will stretch the boards...
        does anybody know how this can be solved digitally?
        i usually pre-calculate the length of the target shape. e.g. if i have a 4' length and need to bend it in a arc, i figure out the length of the arc so the bent object is the correct length.
        it might be simpler to use extrude tools to make the outline of the shape and extrude it. or maybe vertex tools could manipulate the grid correctly...
        Glenn
        http://www.runnel.com
        • Chris FullmerC
          👍 +1 Measure the line you are bending to first, and make you straight line the exact same length. (this is all funcionality I have planned to add to the next version of this tool if I ever get around to making it). Then make your board the exactly same length also. Then there should be no stretching.
            jasper.middelberg
            Hello,
            perhaps a shot in the dark, hopefully a suggestion or otherwise a cue for anybody that can point me in a good direction to work with this:
            An experiment, using standard plywood boards, bolted together.
            the idea is that if bending plywood, the structural capacity of the plywood becomes higher,
            thus, being able to make a light weight skin roof that can support itself.
            Now, my quest is how to bolt a bunch of plywood boards together to form a sort of
            conics tipi roof.
            I hoped Shapebender would get me there,
            draw up a grid of plywood boards and being able to bend them in a desired shape,
            in order to find out:
            • optimum plywood pattern
            • where to make the bolt holes
            • where the cutlines would be for top and bottom of the roof
            possible workflow:
            • to bend the plywood boards around a surface,
            • then to be able to make markings on the different boards,
            • then to unbend
            • and have straight boards again for scaled drawings for:
              cut patterns and bolting positions
            yet I discovered that Shapebender will stretch the boards...
            does anybody know how this can be solved?
            the idea of bending plywood I found at
            http://conicshelter.com/
            thank you,
            Jasper
            below image
            left back: started testing bending boards,
            front: a preferred conic shape:
              jasper.middelberg
              Thank you Chris and Gullfo,
              yet, starting point is the standard size of the plywood
              and not having to make cuts before hand.
              Making use of standard sized plywood,
              bend it onto a desired shape,
              with an overlap, to be able to determine the boltpositions
              and finally know the cutpatterns for top & bottom
              I really don't know how this can be modeled in a way it is easy to experiment.
              in Sketchup or any 3d software.
              yet I guess this workflow might be a bit too much to ask from your plugin,
              anyway, I really appreciate your work,
              thanks again,
              Jasper
                Jasper, I've been having a think about how to draw a curve of known length to make the path for Shape Bender. It occurred to me that one could draw a straight line of known length and then use the Radial Bend function of Fredo's FredoScale extension to bend it as desired. You can make irregular curves with it, too. If the line you are bending is a copy of one that you leave straight, you then end up with both of the lines required for Shape Bender.
                Of course you could also use Radial Bend to bend the 'plywood' panel. In some cases, though, it might be easier to work on a single line and get it bent as desired and use shape Bender to do the final bend.
                • O
                  oscarfalcon
                  Hello, I'm new to this forum. I've been using SU for over two years now and really like how it works, specially with all the plug-ins and scripts there are for making things awesome with it.
                  I have one problem though, I downloaded the shape bender script and the progressbar.rb file but SU7 doesn't seem to recognize them, any help here would be great. I'm using a mac as of today, I placed the files in the plug-ins folder and can't seem to find them in sketch up.
                  Cheers, wonderful SU community.
                  OFL
                    Oscar, go to Window>Preferences>Extensions and tick the box for Shape Bender. Then go to View>Toolbars and select Shape Bender.
                      mac1
                      thanks again,
                      Jasper
                      Reality vs Virtual Reality?
                      Having dealt with some issues with graphic epoxy structures some questions come to mind:
                      1. What is the max thickness can you bend;
                      2. What plans are in work to establish knock down factors for bolt holes and when / how will structural allowables be establish and how. (Building and say it does not fall down is not acceptable);
                      3. Plywood by spec has voids so what plans are in place to insure stress risers can be mitigated. Ultra sound is used some times and since the strength is so much processed controlled vs metal what would be done to insure each panel meets some type of spec. I would guess some plywood that is made from radial sheared layers would be very different. Some same questions about the adhesive interface stress, heat and cold flow.
                      4. How does one handle the changes in allowables with moisture content;
                        You have a big hill to climb to get this concept accepted for general use. And then comes the question of analysis capability especially for stress. Have not done any search for plywood to see if any has well established allowables but with its use would hope so.
                        10/1 23:57 update Note: Did a quick search for plywood allowable stress. One of the returns was a APA plywood spec. One item would have immediate application to your effort. That is the min bend radius for various thickness and they have differnt for the cross grain ( 4 ft) and with grain ( 8 ft) evn for small thickness like 5/32 the numbers are big. ~ 3ft for cross and 8 ft with 👿
                      • B
                        bowlr
                        I have dl the Shape Bender, but have an error
                        "Error Loading File clf_shape_bender_loader.rb
                        No such file to load -- progressbar.rb"
                        when I open SU.
                        • Chris FullmerC
                          Hi Barry, shape bender also requires a script called "progressbar" to work. You can download it from here:
                          File Not Found
                          (www.smustard.com)
                          Install that and hopefully that will do the trick!
                          • charly2008C
                            charly2008
                            Hello Chris,
                            thank you for your wonderful plugin. It works fine except for the edge in the picture. With the previous version, there was no problem with such edges.
                            Charly
                              SahmElshamal
                              can you help me please < it doesnt work with me < it always says ( Error Loading File clf_shape_bender_loader.rb
                              No such file to load -- progressbar.rb)
                              whyyyyyyyyyyyyyyyy
                              • GaieusG
                                Hi Salma,
                                Please, go back to page 1 in this topic and there is Progressbar.rb linked somewhere at the top. You also need to download/install that plugin so that this can work.
                                  SahmElshamal
                                  Hi Gaieus
                                  thanx 4 ur reply
                                  i will try what u said
                                    SahmElshamal
                                    No such file to load -- clf_shape_bender/clf_shape_bender.rbError Loading File clf_shape_bender_loader.rb
                                    that message came after i downloaded the Progressbar.rb[
                                    i have already downloaded the plugin and the Progressbar.rb , i work with SU 6
                                    plz tell me the steps of installing a plugin
                                    i cant find set up icon
                                    so i copy - past it to the plugins of SU
                                    is it right ???
                                    thanx
                                      SahmElshamal
                                      it finally worked
                                      thank u ,moderator
                                      thank u chris
                                      great plugin
                                      • charly2008C
                                        charly2008
                                        what I still don't understand is how do I control the length of the curved object?
                                        Charly
                                          You have to make the arc the desired length. In your example, the arc needs to be 2.80 metres long. You can get the length from the Entity Info box after you've drawn it but that doesn't make it easy. How you arrive at that arc length will be the challenge. I wonder if someone could write a plugin that would take a given radius and arc length and draw the arc.
                                          Generally I draw the arc first, measure its length and draw the straight line and the straight shape to match.
                                          • charly2008C
                                            charly2008
                                            Hi Dave,
                                            thanks for your reply. I've done it with your method, but can still get a different length in the curved object.
                                            Charly
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 63
                                            • 64
                                            • 30 / 64
