    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 259.0k Views 43 Watching
      As Adam said - it only appears in the right-click context-menu under the 'Hole Punching...' submenu - the options will vary depending on the current selection.
      Please read the guidance-notes before diving into the shallow water!
      ๐Ÿ˜’
      *Comme Adam a dit - Il n'apparaรฎt que dans la droite-cliquez/menu-contextuel sous le sous-menu 'Hole Punching...' -
      SVP lire les directives-notes avant de plonger dans les eaux peu profondes!*
      ๐Ÿ˜‰
      • B
        Bertier
        sorry guys, too much to do too little time
        thanx again
        merci !
          Seems a simple face as component don't work ๐Ÿ˜ฎ
          Works with the basic "Component Puncher"! ๐Ÿ˜Ž
          (so only with no depth choice) ! ๐Ÿ˜•
            Can you post an example SKP with this problem ? ๐Ÿ˜’
              sure ๐Ÿ˜„
              When you take a component disc (Gluing, cutting) from the menu /component and past it on a face of the box
              That don't works! ๐Ÿ˜ฎ
              (it's just a surface not a volume) but that's works with the old first Component Punch ๐Ÿ˜‰
              So there is something wrong in this last sophisticated version ๐Ÿ˜„
              disc.skp
                Pilou ! You nitwit!
                The Component might glue BUT you hadn't given it a cutting behavior OR made its center open or transparent so when it did punch the hole you couldn't see it as it entirely covered the 'hole' - try it in Xray mode....Capture.PNG
                  Ahhhhhh! That is very cool! ๐Ÿ‘
                  So any complex curves even not welded (without any face inside) can make a Punch!!! ๐Ÿ˜ฒ
                  No need to take a surface! โ˜€
                  That's rocks! ๐Ÿ˜Ž So your plug works like a charm ! ๐Ÿ˜Ž
                  And I have have something for the Duhduh thread ๐Ÿ˜„
                  When you have made a component with Glue, you must take it from the Menu Window/ Components! And not first from the screen! ๐Ÿ˜ณ
                  • U
                    urs0815
                    Very cool plugin ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                    • K
                      kwalkerman
                      Awesome Plugin!!! I thought about doing something with a similar approach, but you beat me to it!
                      Two comments:
                      1. The plugin works session to session (which is awesome) IF you open your file by double clicking on it and opening it directly. It doesn't seem to work if you open SU first, then do "file, open." Minor issue.
                      2. After punching, if you select any of the reveal faces, all of the other reveal faces are selected, but the window component remains unselected. Again, minor, but worthy of a fix.
                      3. If you create a new file by selecting "file, new", the windows are punched, but the hole doesn't move when the window is moved (same issue as #1, I think)
                      Anyway, overall AWESOME plugin. Definitely saves much time & effort.
                      Karen
                        Two comments:
                        Karen
                        1. This is because the way the observers run / work - it is fixable - thanks for bringing it up.
                        2. This one IS deliberate - if you want to adjust the reveals without affecting the punching-component - e.g. make the reveals splayed by adding a temp face and scaling it.
                        3. This issue IS similar to 1., and again it's because of the way the observers run / work - and again it's fixable... ๐Ÿค“
                          Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                          A new AppObserver has been added to keep the 'hole_punch' observers firing when a model is 'from menu' as 'open' or 'new'.
                          • GaieusG
                            TIG, this is an awesome plugin!
                            I've had my quite easy routines to do this but of course, such a useful addition is always welcome (and of course, the transition part of it - when you move all the necessary parts together - is the greatest part of it)!
                            Thank you very-very much! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                            • K
                              kwalkerman
                              TIG,
                              #2 makes sense. Thanks for updating the plugin with an app observer. Definitely an awesome tool.
                              Karen
                              • GaieusG
                                TIG,
                                I have some minor issues (although of course it can easily be fixed and I guess fixing the plugin itself would need some completely different approach you are using now...)
                                See the attached screenshot of the same window from the front and from the back. The front has a "frame" which will obviously make the cutting face larger than the inside, "tunnel" part.
                                If the plugin's method (which I guess) is to duplicate the front cutting shape on the back, there is a hole around my tunnel (I can fix this manually by offsetting the outer edges out and filling that gap while hiding the surrounding edges).
                                Can the plugin be somewhat effortlessly modified so that it tries to detect such a hole and heals it somehow? See example model attached, too.
                                Another question; when copying the window along a face, SU seems to handle all the components together (like a single entity). So if I Move-Copy an instance and then want to go on doing with other instances, all the existing ones move along. Why is that?
                                Punch hole.skp
                                  Gai
                                  The simple answer is 'No' !
                                  It detects the intersection of the component and the face it's glued onto - i.e. it uses the component's cutting-hole as the punched holes edges.
                                  If the component itself has some internal faces to it then there will be no 'gaps'.
                                  If the component is effectively an outer 'frame' placed onto the wall with an inner hole then you need to set the 'frame' forward by 1mm and the hole-cutting parts at z=0, so that the whole frame no longer lies on the wall and so it does not cut it...
                                  Here's an example...Capture.PNG So the solution is in the design of your hole-cutting-components not the hole-punching tool itself ๐Ÿค“
                                  • GaieusG
                                    Okay TIG, thanks. Yes, I know the solution - was just wondering if there was an easy way to modify the plugin. If not then I will have to modify my workflow of course - no problem with that at all.
                                    ๐Ÿ˜‰
                                    And the other question?
                                      It's in the guidance notes...
                                      If you copy a pre-punched hole [and it's reveals] the links get twisted because the original component is linked to all of the reveal copies and the instance can't then cut the face.
                                      If you want to copy a pre-punched component you must 'un-punch' it first [i.e. delete the internal hole/reveals], then copy the component instance, and then select it and its copies, and then punch the holes again... ๐Ÿค“
                                      • GaieusG
                                        Okay,. thanks (and I know - RTFM) Sorry. I will do so.
                                        ๐Ÿ‘
                                        • K
                                          kwalkerman
                                          TIG,
                                          one option for Gaieus' suggestion is to add a Tools Observer, if a punching component is in the selection, the move tool is active, and the tool goes to 'copy' mode, then un-select the linked components and copy only the hole punching component... or would this mess with some other functionality with the tool??? It would be handy though.
                                          Again, awesome plugin. I've been waiting for something like this for a looooong time.
                                          Thanks again,
                                          Karen
                                          • P
                                            Phil Rader AIA
                                            FLABERGASTED...This is Awesome...What a time saver this will be.
                                            http://www.philrader.com
                                            • 3 / 10
