    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 261.4k Views 43 Watching
    • EarthMoverE
      EarthMover
      Thanks TIG for the update! 👍 It works in every case I've tried now. Flawless thus far.
      Content Creator at Skapeup
      • EarthMoverE
        EarthMover
        One foreseeable issue. I have a lot of modified components where a glue/cut component is nested inside a larger component.....i.e. a window with shutters and mantle. Is there a way to either search the component for a nested cutting component and make the cut with that, or allow me to perform the cut from within the components edit mode?
        (Attached is a component I made for testing.)
        Windows with shutter and brick mantle.skp
        • B
          Bertier
          great thank you
          same thing with the name changing in chrome...
          will use #
          • B
            Bertier
            not working in SU 7
              @bertier said:
              not working in SU 7
              It works in v7 or v8...
              A little more detail please 😒
              I'm not psychic...
              • B
                Bertier
                sorry
                I put it in my pluggin folder
                it doesn't show up in my pluggin list...
                using SU7 on XP pro
                • EarthMoverE
                  EarthMover
                  Bertier,
                  It's context sensitive. It only shows up in the right click menu when you have a component selected that has a "cut opening" value assigned to it. It's not in my plugin list either.
                    As Adam said - it only appears in the right-click context-menu under the 'Hole Punching...' submenu - the options will vary depending on the current selection.
                    Please read the guidance-notes before diving into the shallow water!
                    *Comme Adam a dit - Il n'apparaît que dans la droite-cliquez/menu-contextuel sous le sous-menu 'Hole Punching...' -
                    SVP lire les directives-notes avant de plonger dans les eaux peu profondes!*
                    • B
                      Bertier
                      sorry guys, too much to do too little time
                      thanx again
                      merci !
                        Seems a simple face as component don't work 😮
                        Works with the basic "Component Puncher"! 😎
                        (so only with no depth choice) ! 😕
                          Can you post an example SKP with this problem ? 😒
                            sure 😄
                            When you take a component disc (Gluing, cutting) from the menu /component and past it on a face of the box
                            That don't works! 😮
                            (it's just a surface not a volume) but that's works with the old first Component Punch 😉
                            So there is something wrong in this last sophisticated version 😄
                            disc.skp
                              Pilou ! You nitwit!
                              The Component might glue BUT you hadn't given it a cutting behavior OR made its center open or transparent so when it did punch the hole you couldn't see it as it entirely covered the 'hole' - try it in Xray mode....Capture.PNG
                                Ahhhhhh! That is very cool! 👍
                                So any complex curves even not welded (without any face inside) can make a Punch!!! 😲
                                No need to take a surface! ☀
                                That's rocks! 😎 So your plug works like a charm ! 😎
                                And I have have something for the Duhduh thread 😄
                                When you have made a component with Glue, you must take it from the Menu Window/ Components! And not first from the screen! 😳
                                • U
                                  urs0815
                                  Very cool plugin 👍 👍 👍
                                  • K
                                    kwalkerman
                                    Awesome Plugin!!! I thought about doing something with a similar approach, but you beat me to it!
                                    Two comments:
                                    1. The plugin works session to session (which is awesome) IF you open your file by double clicking on it and opening it directly. It doesn't seem to work if you open SU first, then do "file, open." Minor issue.
                                    2. After punching, if you select any of the reveal faces, all of the other reveal faces are selected, but the window component remains unselected. Again, minor, but worthy of a fix.
                                    3. If you create a new file by selecting "file, new", the windows are punched, but the hole doesn't move when the window is moved (same issue as #1, I think)
                                    Anyway, overall AWESOME plugin. Definitely saves much time & effort.
                                    Karen
                                      Two comments:
                                      Karen
                                      1. This is because the way the observers run / work - it is fixable - thanks for bringing it up.
                                      2. This one IS deliberate - if you want to adjust the reveals without affecting the punching-component - e.g. make the reveals splayed by adding a temp face and scaling it.
                                      3. This issue IS similar to 1., and again it's because of the way the observers run / work - and again it's fixable... 🤓
                                        Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                                        A new AppObserver has been added to keep the 'hole_punch' observers firing when a model is 'from menu' as 'open' or 'new'.
                                        • GaieusG
                                          TIG, this is an awesome plugin!
                                          I've had my quite easy routines to do this but of course, such a useful addition is always welcome (and of course, the transition part of it - when you move all the necessary parts together - is the greatest part of it)!
                                          Thank you very-very much! 👍 👍 👍
                                          • K
                                            kwalkerman
                                            TIG,
                                            #2 makes sense. Thanks for updating the plugin with an app observer. Definitely an awesome tool.
                                            Karen
                                            • 2 / 10
