    1.3k Posts 300 Posters 3.1m Views 298 Watching
    • charly2008C
      charly2008
      Hi Thomas,
      i welded each line and below the result in Sketchup 8.
      Charly
        You have to weld the curves for loft to work?
        • charly2008C
          charly2008
          Yes this is my experience, otherwise you will have multiple lines.
            Even more odd - that unwelded needs more distance...?
            • charly2008C
              charly2008
              I must correct myself. In your example it works without welding but only if the two lines have a little more distance. Otherwise I get the same error messages. I previously thought the lines would have to be welded. now I've found that it is not so. Sorry, I am ashamed. I was back to cheeky.
              Charly
                robert111
                charly how to modeling this exemple plz can you make tuto plz, il love yours objet with this plugin
                  robert111
                  and for this exemple too
                  • charly2008C
                    charly2008
                    To all who are interested,
                    My mistake is based on the plugin Extrude Edges by Loft. Here welded edges or corners are required. I realized only now with Curviloft only just a double-click on the edges is necessary to complete the selection. Without the post from Thomas, I would have thought about it.
                    I could have saved myself a lot of time. You get used sometimes to a particular workflow or action and thought no more about it.
                    Charly
                    • jeff hammondJ
                      or, adjust the max edge angle then single click (though in thom's example, the filter needs to be around 130 deg.)
                      [this feature comes in very handy in certain instances]
                      [use the tab key for even more filter options]
                      • charly2008C
                        charly2008
                        Thanks Jeff for your tip.
                        • charly2008C
                          charly2008
                          Hi Robert111,
                          i will place the tutorial here:
                          404 Not Found
                          (forums.sketchucation.com)
                          Charly
                            SpookyChick1013
                            Hi there Fredo! I've had Curviloft in my plugin folder for quite a while, and only recently figured out how to make it work. (To Whom It May Concern; Thank you all for your tutorials!) Curviloft is an awesome plugin and extremely useful. Once I figured out how to use it, I have had no problems until just recently, (say, a week ago?) when I started getting the following error message:Curvi Load Error.PNG
                            I think we can safely ignore the matchbox plugin error, as MatchBox is not even installed and has not been for over 18 months (it would not play nice with other plugins so I vaped it...)and Curvi worked fine until after i downloaded and installed the latest version( Curviloft 1.0c, and LibFredo6 35c.) Curvi still works ok for the most part but I have started to get strange behavior from the orthogonal curves setting. As you can see this happened with both of the Orthogonal settingsInterestingly, this did not start until last night. I figured a work-around,What I wanted and got after a work around but I was curious if the reported errors had something to do with it.
                            Once again, thank you so much for all of your hard work and genius! >hugz'n'cookiez, because I don't have any beer today<
                            https://kuromatsudriveyards.com
                            Fo-su to tomo ni aran koto o...
                            • charly2008C
                              charly2008
                              a Curviloft Lamp.
                              Charly
                                SpookyChick1013
                                As always, BEAUTIFUL work, Charly!
                                • fredo6F
                                  SpookyChick1013
                                  1) Error with Matchbox
                                  I have no clue what the matchbox plugin has to do here (especially if it is not present on your disk), but you seems to get an error from CurviloftPalette which is rather strange. Did you download Curviloft from Sketchucation?
                                  1. Error on model
                                    I don't see exactly what is the problem. Maybe it could be a good idea to post the model, so that I can have a look. There are still plenty of issues with all functions, and some simply depend on the order of selection, or orientation of curves, which may explain why it works one day and not the other.
                                    By the way, did you get a crash (bugsplat) in Curviloft the night before you start having problems?
                                    SpookyChick1013
                                    SpookyChick1013
                                    Neither do I. For some reason SU just refuses to acknowledge that the darn thing is gone, but it has never been a problem,so I haven't worried about it.
                                    Yes. Latest versions from right there on the first post of this thread. Oh, and I also DID go ahead and redownload and reinstall the whole thing today. Still getting the error.
                                    2) Error on model
                                    Maybe it could be a good idea to post the model, so that I can have a look. Here you go.gAUSS pISTOL 2copy.skp
                                    By the way, did you get a crash (bugsplat) in Curviloft the night before you start having problems? No. Curvi just started doing this after I had been modelling for 2-3 hours. I'm not sure exactly why, either. Of course, I don't know much about writing plugins, just quite a bit about breaking them (self-deprecating humor)
                                    Thanks for being willing to take a look at this Fredo. I admit I don't know much at all about coding. I'm an enduser not a developer, so ruby script might as well be ancient Sumerian to my eyes. 😕
                                    • jeff hammondJ
                                      hey spooky,
                                      if your loft lines were vertical then ortho would do what you're asking it to.. as it is, the splines are perpendicular to your profiles.. curviloft lets you make global adjustments to the segments etc (in the main curviloft display) as well as individual sections (while in edit mode, click in one of the sections which will highlight yellow then adjust segmentation in there)..
                                      that aside, i think you'd be better off using a different approach as you'll see in pics 3&4 + in the attached skp
                                      i made a few changes to your profile lines but that's a different story..
                                      [i hope this makes enough sense.. i posted this with a 1am vino filter 😄]
                                        SpookyChick1013
                                        hey spooky,
                                        %(#0000BF)[Thanks, I actually was unaware that that can make a difference. I definitely will be keeping it in mind for the future, although my question to Fredo about this still stands, because either the program was operating wrong before, and started working the way it's supposed to, or it originally was working right and something went wrong. Either way, it seems odd that a plugin would change behavior midsession like that. Then again, I do have a talent for breaking things, so who knows..... 😕]
                                        I guess I'm a bit dense, but perpendicular in what way? No sarcasm, I just don't exactly understand what you mean.
                                        Right. That I was aware of. One of the many things I love about Curviloft.
                                        [attachment=4:obxht400]<!-- ia4 -->1.jpg<!-- ia4 -->[/attachment:obxht400]
                                        [attachment=3:obxht400]<!-- ia3 -->2.jpg<!-- ia3 -->[/attachment:obxht400]
                                        [attachment=2:obxht400]<!-- ia2 -->3.jpg<!-- ia2 -->[/attachment:obxht400]
                                        [attachment=1:obxht400]<!-- ia1 -->4.jpg<!-- ia1 -->[/attachment:obxht400]
                                        [attachment=0:obxht400]<!-- ia0 -->handle.skp<!-- ia0 -->[/attachment:obxht400]
                                        No worries about the vino filter Jeff. You're speaking clearly enough, and 1 am is the perfect time for that... The model you sent back looks great. I had not even considered using the skinning function as you did. I definitely should have tried that. Whatever changes you made to the profile curves certainly worked out well, and I most certainlydont mind in the slightest. Although, so I can learn from this, what changes did you make and how did you do it?
                                        • jeff hammondJ
                                          it's not that they need to be vertical per se but the profile splines should be parallel to get your desired results.. it's just something i noticed with curviloft and the orthogonal settings.. (fwiw, in rhino, the profiles can be tilted like you have them and the lofted surface remains straight on the bottom/top_
                                          the red lines are perpendicular.. so are the splines created with curviloft/orthogonal
                                          i redrew all the profiles using fredo's BezierSpline plugin.. it makes a smoother curve and evens out the segmentation..
                                          here's a video showing the whole process.. i did this on a laptop using the trackpad so i apologize about the jumpy navigation etc..
                                          [flash=660,405:3u6imqlr]http://www.youtube.com/v/Ai8ggH9NfIs?fs=1&amp;hl=en_US&amp;color1=0x2b405b&amp;color2=0x6b8ab6&amp;border=1[/flash:3u6imqlr]
                                          [also - i copy/pasted your lines into my own template.. i noticed with yours that they are drawn upside down.. the solid blue axis line should be pointing up instead of down.. if you turn on sky or ground, you'll see what i'm saying + the navigation is weird (for me) in your file]
                                          • O
                                            olbapxpablo
                                            curviloft is not working for me.
                                            other plug-ins works fine except this one
                                            is there anyone can help?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 65
                                            • 66
                                            • 17 / 66
