    SketchUp is not a NURBS modeler because...
    28 Posts 11 Posters 11.1k Views 11 Watching
    • soloS
      ERROR: The request could not be satisfied
      (www.rhino3d.com)
      • jeff hammondJ
        i think that image might be confusing unless you look at it very closely.. notice the blue surface isn't actually being created by those lines as it would be in sketchup.. the control points are influencing the surface but not defining it's boundaries.. those control points aren't the same thing as a vertex in sketchup
          d12dozr
          404 Not Found
          (develop3d.com)
          This article has a good part about NURBS vs. polygons.
          http://goo.gl/f7ooYh
          • jeff hammondJ
            fwiw, nurbs like behavior isn't impossible in sketchup and we've already seen a few ventures into it..
            BezierSpline.rb is a good example and curviloft as well. (especially when looking at the various spline methods fredo has used and the edibility of surfaces).. i'm thinking fredo has a bunch of SUnurbs experiments going on at the moment and we'll eventually see even more nurbs style plugins.
            • jeff hammondJ
              this may or may not help but an example of something that's possible with rhino but isn't with sketchup is this drawing..
              here's a surface that would be possible to mimic in sketchup (just a revolved spline) notice how it's mellower towards the bottom and tightening up as it nears the top..
              but, in rhino, since that surface is mathematically defined and not just a collection of vertices that aren't aware of one another (my simplistic definition of a polygon surface ๐Ÿ˜„), i can extend that surface very easily and you'll see that it continues tightening as the existing surface was doing.
                and the funny of the thing is at least in final on your screen Su or Rhino are bother "triangles" from the graphic card for be possible to visible render ๐Ÿ˜‰
                (in my simplistic definition) ๐Ÿ˜„
                  Interesting... just last night I was revisiting my BezierPatch plugin I experimented on about a year ago...
                  • mitcorbM
                    mitcorb
                    It seems that every ruby extension created for Sketchup is analogous to features native to other modeling apps. That is simply because the needs are the same in Sketchup.
                      hm...
                      One do not always need NURBS. Some times you do, some times you don't.
                      Nor do one always need every feature any other modelling application has.
                      If it had - then we'd have a big bloating beast.
                      But - SketchUp has a platform where you can make it fit your own specialised needs.
                      • mitcorbM
                        mitcorb
                        @ThomThom:
                        Yes. You are right about the beast. As we know the SU developers wanted to keep the app compact.
                        • jeff hammondJ
                          yeah, in nurbs modelers we only see a representation of the surface via a render mesh and it's not accurate (well, it's 100% accurate if you take measurements from it or export to cnc production etc..). i think it's impossible to show a true nurbs surface on our current monitor technologies in the same way we can't truly see a circle on our screens.. (a bunch of square pixels can't display a true curve)
                          here's a closeup view of a rhino surface.. the wires are what you have to pay attention to and trust them but the surfaces will often to appear segmented (well, because they are meshes just like in SU)
                          click pic for larger
                          the one thing i don't really like about rhino is their nurbs to mesh technique and i don't think they're nearly as clean as they could be.. i hear moi is much better at this.. hopefully, rhino v5 (which will also be the 1st official iRhino release) will change this.
                            yes in Moi you can regulate for have a "perfect fit" of the curve on the surfaces
                            But it's only for the screen and that can slowdown all if you have a very big file!
                            It's just for pleasure of the eyes ๐Ÿ˜‰
                            But for normal file size that is very cool ๐Ÿ˜Ž
                            • PixeroP
                              Pixero
                              I've worked a lot with Nurbs in Maya and they are good for some things and polygons are better for some.
                              What is needed if ever someone makes a nurbs/spline patch ruby is that it keeps the editing capabilities all the time. Meaning it makes it possible to change the "subdivision" to polys even after editing and just crank it up when its time to render.
                                mhm.. NURBS modellers will have to refine the mesh to the point where a edge segment is <= 1px
                                  Something like this:
                                  Experimental Prototype
                                  ๐Ÿ˜‰
                                  • jason_marantoJ
                                    jason_maranto
                                    Wow... a picture really is worth a thousand words. I can't wait to try that plugin ๐Ÿ˜ฒ
                                    Best,
                                    Jason.
                                      In these moments Scripts' conceptors are out burst! ๐Ÿ˜ฒ ๐Ÿ˜Ž
                                      Users can't follow the flux ๐Ÿ’š
                                        And the plus side of these patches are that they are easy to UV map. ๐Ÿ˜‰
                                        • daleD
                                          dale
                                          UV mapping ๐Ÿ˜ฎ Please go on ๐Ÿ‘
                                            Patches generate regular geometry which is much easier to map as you know the full structure of the mesh.
