    [Plugin] Radial Lines
    24 Posts 8 Posters 16.1k Views 8 Watching
      I wish the red lines ๐Ÿ˜‰
      They will have all the same length!(2.23 m)
      http://forums.sketchucation.com/download/file.php?id=55001
        Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=273614#p273614
        It now has an additional option 'Lines [layered]' - with this the Lines are put on their own layer rather than Layer0...
          I think I see...
          So if you used the 'Line' option the line would stop at a set length...
          I'll think about it... ๐Ÿค“
            Many thx by advance โ˜€ ๐Ÿ‘
            Ps It's not possible to select also extremity points (like faces and segments)extremity.jpg
              It will draw lines to both ends of any selected edges - you'll need to erase the unwanted lines...
                There's now a separate script for drawing fixed length radial lines http://forums.sketchucation.com/viewtopic.php?p=273654#p273654
                  Damned you have a speedy coding method ! ๐Ÿ˜Ž
                  (I will use for the extremities not wanted if not too numerous ๐Ÿ’š
                  • mitcorbM
                    mitcorb
                    How do you place the cpoint or guide point?
                    Error message keeps asking for this.
                    I thought by using measuring tape you could get a guide point.
                    Something I am not doing? Can't get this script to acknowledge the guide point, because it then wants a vertex?
                      Use the tools bar Projection by Didier Bur
                      There is a CPoint inside and some very useful tools!
                      • mitcorbM
                        mitcorb
                        Thanks, Dave.
                        But I do not understand the conditions for guidepoint only. I usually get guidelines.
                        Thanks Pilou, I forgot about Didier's Projections. I have it on my home computer, but not here.
                          then a vertex
                          How dow you select one vertex from a single segment in the space? (extremity)
                            A guide point is created when you measure off a point, vertex, intersection, etc. A guideline is created when you click on a line, edge or axis first.
                            There are also some plugins like Point at Center and the Point cloud plugin that create guidepoints.
                            • B
                              Ben Ritter
                              @dave r said:
                              I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
                              Dave, you hit the nail on the head. Remembering that when the time comes, you have such a helpful tool available.
                              How do you all keep track of all the tools available in your SU arsenal, if they're not used on a regular basis?
                              Ben
                              • B
                                Ben Ritter
                                TIG, thank you very much. Again.
                                  Ben
                                  I gave up a long time ago, Ben. Periodically I look through my Plugins folder to see what treasures I've forgotten about. ๐Ÿ˜’ ๐Ÿ˜†
                                    i use projections and keep only the CPoint icon
                                    You have no keep The icone Extrude lines along a vector? โ˜€
                                    • jeff hammondJ
                                      re: construction point
                                      pay four bucks for the privilege of placing one
                                      http://www.smustard.com/script/AddConstructionPoint
                                      ๐Ÿคฃ
                                      personally, i use projections and keep only the CPoint icon in my toolbar (next to draw construction lines which is another way to get a cpoint)
                                      with , start the measurement on an entity then click in blank space and you'll get a cpoint as well.
                                      [edit]- another way to get one without adding any rubies is to turn on 'ruby script examples' in the extensions preferences.. draw an arc the right-click on it and you'll have the option "Point at Center" in the context menu.. that will give a cpoint that can be moved around.
                                      • KrisidiousK
                                        Krisidious
                                        do you ever sleep?
                                        By: Kristoff Rand
                                        • jeff hammondJ
                                          You have no keep Extrude lines along a vector?
                                          i use TIG's version in the extrude edges suite.. i keep that entire toolbar turned on.
                                            mitcorb, the Tape Measure tool is the way to set a guidepoint or at least one way. After setting the guidepoint, select it and edges with vertices or ends and run the tool.
                                            TIG, thank you for this. I'm not sure where I'll use it but I wouldn't be surprised if it comes in handy one day.
