[Plugin] Selection Toys
Thanks Marcus! Great video - I should put that in the original post.
Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar
Tools->Selection Toys->Enable Toolbar
Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
Youtube Video -
thank you that really helps
tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
What function are you trying to use?
Select Ngon
Select Only -> Polygons
?Note that
Select Only
andDeselect
modifies your current selection - doesn't add to it. -
that's exactly what I'm doing.
select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.to clarify :
Better if you post your SKP file
sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
Polygon and N-Gon refer to entities where the Entity Info display Polygon.
erm... pardon?
ok I must be being dense... that made no sense at all?
In fact i believe this N Gon function shown only figures who are made with the tool "Polygon"
And not geometric figures that you can see as Ngons -
And not geometric figures that you can see as NgonsExactly - the selection tool doesn't look at the shape of the geometry, but filters the selection based on the types of entities SketchUp reports.
When you select something in SU, the Entity Info window will say what type it is - all the filtering is based on these types.
ah. thanks for your help then.. this explains all my problems with this Ruby. we're not compatible.. but thats ok.
@thomthom said:
I can make so sense why you would not have a
Selection Toys
menu item under tools and various Context Menu entries (which depend on what you right-click)I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
Can you post a screenshot of your Tools menu?
Hello Thomas!
It happens with me also! You can see a screenshot here
http://www.netcond.net/N3TO/Screenshot_toolsmenu.jpg
I see all posts but I can't resolve the trouble.
apologies for my bad english...
Thanks -
Check the Tools menu.
Tools -> Selection Toys -> Enable Toolbar
then after you do that - check the menu you showed in the screenshot. -
Version 2.2.1
- Fixed Select DC Instances
Sorry - I forgot to include a file. Redownload.
It was working in V7, but I can't get Sel Toys working in V8. Feeling stupid for a number of reasons.
My configurtion of Sel Toys:
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib
C:\Program Files (x86)\Google\Google SketchUp 8\Tools\TT_Select_ToysAfter SU8 re-start:
no context picks for Sel Toys
no pick for Sel Toys in Tools menu drop down -
C:\Program Files (x86)\Google\Google SketchUp 8\Tools\TT_Select_ToysDon't put plugins in the Tools folder.
There should be
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Lib\ - (inside, lots of .rb files)
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\tt_selection_toys.rb
C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\TT_Select_Toys\
