    [Plugin] Selection Toys
    594 Posts 121 Posters 396.8k Views 121 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @jim said:
      @dan rathbun said:
      I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
      Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
      It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
      I'm not here much anymore.
        Khai
        can someone give me a step by step idiots guide on how to actually use this?
        I can get it to light an edge up orange. that's all. how do you select things with it?
          Dan Rathbun
          See the first post for basic use.
          Thomas has a link to a Command Cheatsheet also in the first post.
          (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
            Khai
            erm. I did?
            and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
            this is what I mean by step by step and ... be patient? I asked once and waited...?
              d12dozr
              Khai, what are you trying to select? What function are you trying to use?
              http://goo.gl/f7ooYh
                Khai
                well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
                I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
                just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
                  d12dozr
                  Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
                  HTH
                  [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                    Thanks Marcus! Great video - I should put that in the original post.
                    Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
                      d12dozr
                      Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
                      http://www.youtube.com/watch?v=bemMh3gpLVI
                        Khai
                        thank you that really helps πŸ˜„
                        tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
                            Khai
                            Select Ngon
                              Select Only -> Polygons ?
                              Note that Select Only and Deselect modifies your current selection - doesn't add to it.
                                Khai
                                that's exactly what I'm doing.
                                select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
                                to clarify :Stoys.jpg
                                  Better if you post your SKP file πŸ˜‰
                                    Khai
                                    sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
                                      Polygon and N-Gon refer to entities where the Entity Info display Polygon.
                                        Khai
                                        erm... pardon?
                                        ok I must be being dense... that made no sense at all?
                                          In fact i believe this N Gon function shown only figures who are made with the tool "Polygon" πŸ˜‰
                                          And not geometric figures that you can see as Ngons πŸ˜‰
                                            Exactly - the selection tool doesn't look at the shape of the geometry, but filters the selection based on the types of entities SketchUp reports.
                                            When you select something in SU, the Entity Info window will say what type it is - all the filtering is based on these types.
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 29
                                            • 30
                                            • 14 / 30
