    [Plugin] Selection Toys
    594 Posts 121 Posters 552.7k Views 121 Watching
      hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
      Whatever it was, I'm glad it work for you now. πŸ˜„
        stonebreaker
        btw. thx for the help. πŸ˜„
        i don't want to miss your really great plugin which makes work so much easier.^^
        • Dan RathbunD
          Dan Rathbun
          I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
          These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
          I'm not here much anymore.
            Jim
            Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
            Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
            • Dan RathbunD
              Dan Rathbun
              It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
              • K
                Khai
                can someone give me a step by step idiots guide on how to actually use this?
                I can get it to light an edge up orange. that's all. how do you select things with it?
                • Dan RathbunD
                  Dan Rathbun
                  See the first post for basic use.
                  Thomas has a link to a Command Cheatsheet also in the first post.
                  (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                  • K
                    Khai
                    erm. I did?
                    and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
                    this is what I mean by step by step and ... be patient? I asked once and waited...?
                      d12dozr
                      Khai, what are you trying to select? What function are you trying to use?
                      http://goo.gl/f7ooYh
                      • K
                        Khai
                        well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
                        I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
                        just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
                          d12dozr
                          Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
                          HTH
                          [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                            Thanks Marcus! Great video - I should put that in the original post.
                            Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
                              d12dozr
                              Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
                              http://www.youtube.com/watch?v=bemMh3gpLVI
                              • K
                                Khai
                                thank you that really helps πŸ˜„
                                tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
                                  • K
                                    Khai
                                    Select Ngon
                                      Select Only -> Polygons ?
                                      Note that Select Only and Deselect modifies your current selection - doesn't add to it.
                                      • K
                                        Khai
                                        that's exactly what I'm doing.
                                        select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
                                        to clarify :Stoys.jpg
                                          Better if you post your SKP file πŸ˜‰
                                          • K
                                            Khai
                                            sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 29
                                            • 30
                                            • 15 / 30
