    Writing a config or temp file in Plugins folder
    20 Posts 7 Posters 1.8k Views 7 Watching
    • N
      notareal
      @thomthom said:
      So the issue here is users without admin privileges won't be able to run plugins that need to write to the plugins folder?
      Yes. It's simply a no good route in Vista/win7 (possibly in XP too), if a strict security policy is in use - user cannot write anything in application folders. It can even be restricted from admins (by group policy).
      • Chris FullmerC
        So what folder does Windows expect people should be able to write to? - somewhere in the users folders probably, right? Could you set it up to write to a special folder in the users MyDocuments or something? And then like Thom suggests, use write_default to save the location of the file.
          You'd have to make a Win32 API call to get the correct path.
          What about OSX, any restriction there?
          • jeff hammondJ
            yeah, there are restrictions there.
            for instance, using fredoscale as an example (which has the default parameter file), i can only change those defaults from my admin account.. if i try doing it from a user acct then the changes don't stick.
            i can however, as an admin, give the user acct. read/write permissions to the entire plugin folder or specific files in which case a user can make changes to fredoscale's parameters which will affect both the user's sketchup and the admin's sketchup.
            [and if i remember correctly, there were some problems with the fredoscale.def file being created in the first place when someone was trying to install from a non-admin acct.. ie- it didn't work]
              Why does it have to be a file made in the ../Plugins/ folder ?
              There are many places that a user will have access rights - e.g. C:\Temp ?
              You can also get the User's very own 'TEMP' folder using ENV["TEMP"] for PC or ENV["TMPDIR"] for MAC - e.g. C:\Users\TIG\AppData\Local\Temp
              πŸ€“
                The temp folder doesn't work well when you want to store persistent config files.
                  What we need in the API is a method that will return the path to where one can store application data on each OS.
                    On Win7 I see this key:
                    LOCALAPPDATA - C:\Users\Thomas\AppData\Local
                    Is there something on OSX?
                      My ENV example combined with a simple OS test lets you find the User's own TEMP file...
                      The PC's ENV["LOCALAPPDATA"] would allow you to then make a specific sub-folder to contain the config file - on a MAC what is it ?
                      BUT you can save config info in other ways...
                      To save them
                      If it's entity specific use entity.set_attributes(dict,key,value)
                      If it's model specific use model.set_attributes(dict,key,value)
                      If it's Sketchup specific use Sketchup.write_default(section,variable,value)
                      [if it's a file-path with '' you'll need to use tr("\\","/") before writing it]
                      To retrieve them use
                      entity.get_attributes(dict,key,default)
                      model.get_attributes(dict,key,default)
                      Sketchup.read_default(section,variable,value)
                      [if it's a file-path you'll need to use tr("/","\\") after reading it and before using it]
                      πŸ€“
                        @tig said:
                        [if it's a file-path with '' you'll need to use tr("\","/") before writing it]
                        Or use File.expand_path
                        I have to try if once again. If my memory doesn't deceive me I haven't had good results with it in the past.
                        I use it quite frequently. But beware that it doesn't handle Length objects well - so convert them into floats first. (I made a wrapper to handle conversion of Length and Symbol for write/read_default)
                        • T
                          tomasz
                          It doesn't have to be. If I would have just a chance to write a path to the config file then it would be ok...
                          I have forgotten about Sketchup.write_default. Thanks Thomas!
                          I have to try it once again. If my memory doesn't deceive me I haven't had good results with it in the past.
                            Note that read/write_defaults is best with Strings - convert then from/to Float [or whatever] afterwards... πŸ˜‰
                              works fine with floats, integers, even arrays in my experience...
                              • N
                                notareal
                                For windows %appdata% ?
