    Writing a config or temp file in Plugins folder
    20 Posts 7 Posters 1.3k Views 7 Watching
      tomasz
      I have a big headache trying to save a config file in 'Plugins/MyPlugin' folder.
      I work always as an administrator on my computer and have full right to the folder, but many plugin users don't.
      Moreover.. under Win Vista \ 7 there is the worst thing on the Earth .. the UAC. I really hate it.
      Is there a way to successfully save a file into Plugins whatever permissions are there or at least help users grant such a permission to themselves - like starting folder properties window?
      Even when I would give an user an option to select a different, writable folder, I have to save this location in a config file somehow!
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • PixeroP Offline
        Pixero
        Me too. I work as administrator too, and even if I have UAC off, quite often when trying to save something from the internet (IE) says I dont have write permission. Then if I try again I can and it overwrites a dummy 0kb file with a real sized file. Any ideas?
        Not a solution to your question, but for people who cant stand UAC is to use the free TweakUAC to turn it off. πŸ‘
        I had a drive that "dissapeared" and Vista said it wasn't formatted...tried hard until I turned UAC off. Then it all came back.
        If you're interested you can read about my struggle here: http://forums.sketchucation.com/viewtopic.php?f=72&t=17248
          hm... My Selection Toys write to a config file in its subfolder - I don't recall any trouble with that when I ran it on my Notebook with UAC enabled...
          Sketchup.write_default ?
            Mind you - the account was still an administrator account - I have never tried a User account...
            • N Offline
              notareal
              I think there many that struggles with this issue (administrated environments). For some running as administrator is simply impossible and/or against corporate security policy.
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                So the issue here is users without admin privileges won't be able to run plugins that need to write to the plugins folder?
                • N Offline
                  notareal
                  Yes. It's simply a no good route in Vista/win7 (possibly in XP too), if a strict security policy is in use - user cannot write anything in application folders. It can even be restricted from admins (by group policy).
                  • Chris FullmerC Offline
                    So what folder does Windows expect people should be able to write to? - somewhere in the users folders probably, right? Could you set it up to write to a special folder in the users MyDocuments or something? And then like Thom suggests, use write_default to save the location of the file.
                      You'd have to make a Win32 API call to get the correct path.
                      What about OSX, any restriction there?
                      • jeff hammondJ Offline
                        yeah, there are restrictions there.
                        for instance, using fredoscale as an example (which has the default parameter file), i can only change those defaults from my admin account.. if i try doing it from a user acct then the changes don't stick.
                        i can however, as an admin, give the user acct. read/write permissions to the entire plugin folder or specific files in which case a user can make changes to fredoscale's parameters which will affect both the user's sketchup and the admin's sketchup.
                        [and if i remember correctly, there were some problems with the fredoscale.def file being created in the first place when someone was trying to install from a non-admin acct.. ie- it didn't work]
                        • TIGT Online
                          Why does it have to be a file made in the ../Plugins/ folder ?
                          There are many places that a user will have access rights - e.g. C:\Temp ?
                          You can also get the User's very own 'TEMP' folder using ENV["TEMP"] for PC or ENV["TMPDIR"] for MAC - e.g. C:\Users\TIG\AppData\Local\Temp
                          πŸ€“
                            The temp folder doesn't work well when you want to store persistent config files.
                              What we need in the API is a method that will return the path to where one can store application data on each OS.
                                On Win7 I see this key:
                                LOCALAPPDATA - C:\Users\Thomas\AppData\Local
                                Is there something on OSX?
                                • TIGT Online
                                  My ENV example combined with a simple OS test lets you find the User's own TEMP file...
                                  The PC's ENV["LOCALAPPDATA"] would allow you to then make a specific sub-folder to contain the config file - on a MAC what is it ?
                                  BUT you can save config info in other ways...
                                  To save them
                                  If it's entity specific use entity.set_attributes(dict,key,value)
                                  If it's model specific use model.set_attributes(dict,key,value)
                                  If it's Sketchup specific use Sketchup.write_default(section,variable,value)
                                  [if it's a file-path with '' you'll need to use tr("\\","/") before writing it]
                                  To retrieve them use
                                  entity.get_attributes(dict,key,default)
                                  model.get_attributes(dict,key,default)
                                  Sketchup.read_default(section,variable,value)
                                  [if it's a file-path you'll need to use tr("/","\\") after reading it and before using it]
                                  πŸ€“
                                    @tig said:
                                    [if it's a file-path with '' you'll need to use tr("\","/") before writing it]
                                    Or use File.expand_path
                                    I have to try if once again. If my memory doesn't deceive me I haven't had good results with it in the past.
                                    I use it quite frequently. But beware that it doesn't handle Length objects well - so convert them into floats first. (I made a wrapper to handle conversion of Length and Symbol for write/read_default)
                                      tomasz
                                      It doesn't have to be. If I would have just a chance to write a path to the config file then it would be ok...
                                      I have forgotten about Sketchup.write_default. Thanks Thomas!
                                      I have to try it once again. If my memory doesn't deceive me I haven't had good results with it in the past.
                                      • TIGT Online
                                        Note that read/write_defaults is best with Strings - convert then from/to Float [or whatever] afterwards... πŸ˜‰
                                          works fine with floats, integers, even arrays in my experience...
                                          • N Offline
                                            notareal
                                            For windows %appdata% ?
