    [Plugin] Greeble 2 released! (Updated August 31st, 2009)
    94 Posts 24 Posters 85.5k Views 24 Watching
      Jim
      @bugmcw said:
      hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
      [edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
      It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
      • X
        xrok1
        i'll model you one if that helps. 🤣
        • B
          bugmcw
          haha i wont buy you one Jim, but youre more than welcome to test on mine! let me know if i can help!
            So goto the Protrude thread and ask your problem ! 😉
            Maybe it's because you have a Mac 😒
            Damned crossing post 😒
            • Chris FullmerC
              Ressurecting the dead - or at leas the long forgotten!
              But I've updated this script, and its a big enough update that I thought I'd post and let people know. Two main things are that it now works inside of groups and components and does not cause bug splats! (that was a big bug I never noticed until about 3 weeks ago, oops!). Also, the script remembers your settings between uses (but not between SketchUp sessions).
              So if you have an old copy (include clf_greeble.rb or an old clf_greeble2.rb) please delete them and install this one.
              UPDATE August 31, 2009
              2.20:: 2009-08-31
              • Fixed a MAJOR bug that would cuase SketchUp to crash when greeble was used inside a group or component. So yes, you can now safely use Greeble inside a group or component!
              • Changed some code that should theoretically speed things up ever so slightly....frankly I don't think it helped.
              • Changed some code to make it run smarter, skip certain methods if they were not being executed.
              • Fixed some code that could cause problems when faces would overlap.
                2.21:: 2009-08-31
              • Now user input settings are rembered between script uses.
              Download
              This script is hosted at http://www.smustard.com/script/Greeble2
                skkor9y
                hi,CHRIS your tools are doin magic.
                though my heart was shrunk when two of yr tools didnt worked ...
                but yr solution(to PIBUZ),of updating component spray worked...
                once again thanx..to u and also pibuz
                  roytchaikowsky
                  This thread cannot be in page 11 man
                  • Chris FullmerC
                    Ummm, what?
                    • GaieusG
                      It was probably sunken to page 11 of the Ruby Forum. He must have been surprised how that comes although this is such a great plugin
                      Roy, there IS a reason; this forum is quite active and not only due to the published plugins but also to the technical discussions between the scripters.
                      Here is a better (cleaner) list of the plugins published on this forum so far (not totally proof though)
                      http://forums.sketchucation.com/search.php?keywords=Plugin&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=s&sd=a&st=0&ch=300&t=0&submit=Search
                      Note that this list spans over 21 pages itself so something inevitably must be below page 10.
                        jhearcht
                        SketchUp 6.4.265 on Windows XP
                        As a newbie, apparently I'm missing something that a more experienced modeler would take for granted.
                        I downloaded Greeble 2, along with Progress Bar and Offset. Put them in the Plug-ins folder. After a re-start, "Chris Fullmer Tools" appears in Plug-ins menu.
                        I select a grouped rectangular box with Juniper vegetation texture. I want to add some roughness to the surface. So I select the Greeble tool and enter some numbers. After clicking OK, nothing happens. I also trying selecting just one surface, but no go.
                        I was assuming the tool would draw a 2D grid with my +/- dimensions, then pull each piece up to a random height. If I could get some kind of response, I could then play with the numbers to get the look I want : pointy pyramids may do the trick.
                        Do I need to draw a grid before selecting the tool? Is there an auto grid tool? Should I greeble one face at a time? What do I need to do before invoking the Greeble tool?
                        Thanks for covering my ignorance with your intelligence. 😄
                        • Chris FullmerC
                          Hi jhearcht, it should work. But it does require a grid be drawn first. It will extrude each face, so if you just have one large face, it can extrude that face only. If you have a thousand faces, it then extrudes all those faces.
                          As a note, this plugin is apparently broken with SketchUp version 8.0 for now. I need to look into a fix for it. (but it should be working with version 6.x like you have).
                          You could upload your model and I'll see if I can play with it and see if there is some odd error if that would help,
                            Funny I just reply there ☀
                            • C
                              craigcampbell66
                              Sketchup 7 windows7 pro 64
                              Hi all, I am in need of some advice re the Greeble plugin. I seem to follow the workflow in the tutorials/videos but with no effect. Not a ripple. Have tried on planes/grids/boxes/spheres.
                              Any advice appreciated.
                              thanks in advance, Craig
                                (I am in meters unity)I suppose that is the problem 😉
                                I have also nothing when I input inch unity 😉
                                surely measures are not accorded and i don't want have an headache for make conversion
                                for have the good measures 💚
                                so I take meter unity for simplify my life 😄
                                Draw a simple box (7,6,4) select it and input numbers as shown
                                If you don't obtain something like this there is a problem 😄
                                click image for zoom
                                • C
                                  craigcampbell66
                                  Hi, I tried again to use the greeble with the numbers in your parameters. Some success. It ceases to work at all when I input something into the offset parameters. I have tried in on a box and a sphere with the same results.
                                  I have the offset.rb installed in the plugins folder along with the progressbar.rb and the greeble
                                  any ideas as to where I am going wrong.
                                  • bagateloB
                                    bagatelo
                                    Please do download the file and see if it is possible to solve my problem. The file was created in the latest version of Sketchup.
                                    my pain.skp
                                      This is made with my old Latticeizer script, 3cm frames and default pane with some PudhPull on the panes [with existing lines NOT kept] afterwards...Capture.PNG
                                      • bagateloB
                                        bagatelo
                                        Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
                                        One day I will no more bore you, because I'm trying to learn Ruby Script. Thanks.
                                        WHAT I NEED SKT 7.skp
                                          This plug is always very funny ☀
                                          • Chris FullmerC
                                            Pilou, you crack me up! Great stuff as always.
                                            PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
                                            • 3 / 5
