    [Plugin] Selection Toys
    594 Posts 121 Posters 381.4k Views 121 Watching
      stonebreaker
      SU 8 issue:
      i put the required files in the plugin folder but it doesn't appear in the app.
        @stonebreaker said:
        SU 8 issue:
        Please post a screenshot of the Plugins folder with the files where you placed them.
          stonebreaker
          Hi thomthom.
          here is the content of my plugin folger:
          #extrusionToolbar.rb
          2D#.rb
          2DTools
          bezierspline.rb
          BoolTools
          booltools.rbs
          BZ_Dir_14
          ChrisP_RadialMove_EN.rb
          clf_scale_rotate_multiple
          clf_select_outer_edges.rb
          clf_shape_bender
          clf_shape_bender_loader.r
          crvsmth.rb
          ctrlpnts.rb
          CURVILOFT_Dir_10
          CurviShear.rb
          deBabelizer.rb
          DEFPARAM_Dir
          Eclate_Deplace.3.0.2_EN.r
          Examples
          examples.rb
          extrudeEdgesByEdges.rb
          extrudeEdgesByFace.rb
          extrudeEdgesByFaces.rb
          extrudeEdgesByLathe.rb
          extrudeEdgesByLoft.rb
          extrudeEdgesByRails.rb
          extrudeEdgesByRailsByFace
          extrudeEdgesByRailsToLatt
          extrudeEdgesByVector.rb
          FREDOSCALE_Dir_20
          FredoScale_ZH.lang
          FreeRotate.rb
          fur_en
          fur_en.rb
          jointpushpull.rb
          JPP_Dir
          LibFredo6.rb
          LIBFREDO6_Dir_35
          LibTraductor.rb
          lss_tb_icons
          lss_toolbar.rb
          maxwell
          maxwell.rb
          mshstick.rb
          Ocean
          ocean_extension.rb
          offset.rb
          pathface.rb
          pb_loader.rb
          pnts2mesh.rb
          ProfileBuilder
          progressbar.rb
          proper_animation_1.07.rbs
          protrude
          protrude.rb
          ROUNDCORNER_Dir_21
          RubyWinFunc.so
          sample
          SketchyBevel.rb
          SketchyPhysics
          sketchyphysics.rb
          SketchyPhysics3
          sketchysolids.rb
          skin
          skin.rb
          SliceModeler.rb
          SoapSkinBubble
          SoapSkinBubbleTools.rb
          sublend.rb
          Subsmooth
          subsmooth_loader.rb
          surface_plotter.rb
          TheaExporter.rbs
          TheaExporter_files
          TIGtools
          TOS_Dir_16
          tt_edgetools.rb
          tt_image_opacity.rb
          TT_Lib
          TT_Lib2
          tt_plan_tools.rb
          tt_selection_toys.rb
          TT_Select_Toys
          tt_solid_inspector.rb
          Twilight
          twilight.rb
          unins000.dat
          unins000.exe
          Utilities
          utilities.rb
          win32api.so
          wudworx
          wudworx.rb
          WxSU
          ZLoader__Curviloft.rb
          ZLoader__FredoScale.rb
          ZLoader__OnSurface.rb
          ZLoader__RoundCorner.rb
            hmm... I see no reason why it would not load.
            Are you looking for the menus in the Tools menu and the context menu?
            There was another user that had problems with not seeing the menus of a plugin he'd installed - turned out that the plugins was correctly installed in SU8, but the user was launching SU7. (when you doubleclick .skp files Windows will launch the last SU version you used.)
              stonebreaker
              yeah...i look in both menues.
              su8 is the only sketchup app on my pc^^
                And there are no errors at all when you start SU?
                If you open Ruby Console, what output do you get when you type:
                Select_Toys
                load 'tt_selection_toys.rb'
                TT_Lib::VERSION
                  stonebreaker
                  Select_Toys
                  --Select_Toys
                  --true
                  TT_Lib::VERSION
                  --1.2.0
                  i use the german su8 version.^^
                    I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
                    I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
                    Can you post a screenshot of your Tools menu?
                      stonebreaker
                      hi
                      now it runs...i reinstall su8 and copy the plugin seperatly in before i add my "backup-plugin" folder.^^
                      ...for whatever reason...^^
                        hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
                        Whatever it was, I'm glad it work for you now. πŸ˜„
                          stonebreaker
                          btw. thx for the help. πŸ˜„
                          i don't want to miss your really great plugin which makes work so much easier.^^
                          • Dan RathbunD Offline
                            Dan Rathbun
                            I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
                            These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
                            I'm not here much anymore.
                              Jim
                              Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
                              Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. 😠
                                Dan Rathbun
                                It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
                                  Khai
                                  can someone give me a step by step idiots guide on how to actually use this?
                                  I can get it to light an edge up orange. that's all. how do you select things with it?
                                    Dan Rathbun
                                    See the first post for basic use.
                                    Thomas has a link to a Command Cheatsheet also in the first post.
                                    (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
                                      Khai
                                      erm. I did?
                                      and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
                                      this is what I mean by step by step and ... be patient? I asked once and waited...?
                                        d12dozr
                                        Khai, what are you trying to select? What function are you trying to use?
                                        http://goo.gl/f7ooYh
                                          Khai
                                          well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
                                          I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
                                          just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
                                            d12dozr
                                            Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
                                            HTH
                                            [flash=853,505:3vn20087]http://www.youtube.com/v/bemMh3gpLVI&fs=1[/flash:3vn20087]
                                            • 29
                                            • 30
                                            • 6 / 30
