    [Plugin] Solid Inspector
    303 Posts 99 Posters 275.0k Views 98 Watching
    • olisheaO Offline
      olishea
      cheers πŸ‘
      oli
        GWD
        Solid Inspector doesn't load. I place the plugin in the plugin folder and also downloaded the TT_lib2 and placed it on the right placed. But the menu doesn't show up. I tried to load it manually and get the following error:
        Error: #<LoadError: (eval):923:in `load': No such file to load -- tt_solid_inspector.rb>
        (eval):923
        regards,
        Guy
          What is the exact location to extracted tt_solid_inspector.rb to?
            GWD
            C:\Program Files\Google\Google SketchUp 8\Plugins
              This is just odd...
              You have the file at "C:\Program Files\Google\Google SketchUp 8\Plugins\tt_solid_inspector.rb" - and when you type in load "tt_solid_inspector.rb" into the Ruby Console you get
              Error: #<LoadError: (eval):923:inload': No such file to load -- tt_solid_inspector.rb>
              (eval):923`
              which claims the file is not there... ?
              I also don't understand why it says (eval):923
              When I try to load a non-existent file I get:
              load 'test' Error: #<LoadError: (eval):0:inload': no such file to load -- test>
              (eval)
              (eval):0`
              Are you sure you didn't but the .rb file in a folder and not directly in the Plugins folder?
              Can you post a screenshot of the file in Explorer (including the filepath in the address bar). Sorry to have to make you confirm what you say, but I have had cases like this where the file actually was misplaced.
                GWD
                thomthom,
                no problem...
                regards,
                Guy
                • KrisidiousK Offline
                  Krisidious
                  I know you're tryin to get me to upgrade Thom...
                  By: Kristoff Rand
                    GWD
                    ThomThom,
                    Problem is fixed. I completly removed v7 from my system. It seams that he sometimes opened v7 when i thought i was working with v8.
                    regards,
                    Guy
                      This doesn't require SU8. πŸ˜‰
                        ThomThom,
                        regards,
                        Guy
                        Ah - yes, if you double-click a file to open SU it will open the version you last used.
                          GWD
                          ThomThom,
                          Thanks for this fantastic plugin!!!!
                          regards,
                          Guy
                            πŸ˜„
                            • F Offline
                              fountainhead
                              I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
                              "It isn't a real solid...well what's wrong with it?"
                              "Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
                              Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
                              NICE.
                                πŸ˜„
                                  tomislavm
                                  When can we expect this
                                  Future Ideas
                                  * Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
                                  Automatically fix, o yes!
                                    I don't know. It all depends on when I get a spare moment. I'm currently looking into some UV mapping tool.
                                      Jim
                                      Hi Thom. Here's a scenario - I have a Group I'm checking for a solid. It's quite big and takes a few seconds to open and close the Group. When I use Solid Inspector on the Group to find the errors, I then need to open the Group for editing to fix them, then close it to re-check - open, close, open, close, etc.
                                      Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
                                        Yea - I've been thinking it needs a function like that.
                                        adding to the todo list
                                          Bertier
                                          Hi there, would it be possible to tell solid :
                                          this is (for example) : solid oak
                                          solid oak is : 640 kg / cubic meter
                                          solid weight : whatever volume * 640 in this case ?
                                          that would be great.
                                          thanx to you guys !
                                            d12dozr
                                            Bertier,
                                            Have you seen Volume Calculator by TIG?
                                            http://goo.gl/f7ooYh
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
