    [Plugin] Solid Inspector
    303 Posts 99 Posters 368.3k Views 98 Watching
      jsteacy
      This is a great tool! Awesome!
      • olisheaO
        olishea
        cheers πŸ‘
        oli
        • G
          GWD
          Solid Inspector doesn't load. I place the plugin in the plugin folder and also downloaded the TT_lib2 and placed it on the right placed. But the menu doesn't show up. I tried to load it manually and get the following error:
          Error: #<LoadError: (eval):923:in `load': No such file to load -- tt_solid_inspector.rb>
          (eval):923
          regards,
          Guy
            What is the exact location to extracted tt_solid_inspector.rb to?
            • G
              GWD
              C:\Program Files\Google\Google SketchUp 8\Plugins
                This is just odd...
                You have the file at "C:\Program Files\Google\Google SketchUp 8\Plugins\tt_solid_inspector.rb" - and when you type in load "tt_solid_inspector.rb" into the Ruby Console you get
                Error: #<LoadError: (eval):923:inload': No such file to load -- tt_solid_inspector.rb>
                (eval):923`
                which claims the file is not there... ?
                I also don't understand why it says (eval):923
                When I try to load a non-existent file I get:
                load 'test' Error: #<LoadError: (eval):0:inload': no such file to load -- test>
                (eval)
                (eval):0`
                Are you sure you didn't but the .rb file in a folder and not directly in the Plugins folder?
                Can you post a screenshot of the file in Explorer (including the filepath in the address bar). Sorry to have to make you confirm what you say, but I have had cases like this where the file actually was misplaced.
                • G
                  GWD
                  thomthom,
                  no problem...
                  regards,
                  Guy
                  • KrisidiousK
                    Krisidious
                    I know you're tryin to get me to upgrade Thom...
                    By: Kristoff Rand
                    • G
                      GWD
                      ThomThom,
                      Problem is fixed. I completly removed v7 from my system. It seams that he sometimes opened v7 when i thought i was working with v8.
                      regards,
                      Guy
                        This doesn't require SU8. πŸ˜‰
                          ThomThom,
                          regards,
                          Guy
                          Ah - yes, if you double-click a file to open SU it will open the version you last used.
                          • G
                            GWD
                            ThomThom,
                            Thanks for this fantastic plugin!!!!
                            regards,
                            Guy
                              πŸ˜„
                              • F
                                fountainhead
                                I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
                                "It isn't a real solid...well what's wrong with it?"
                                "Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
                                Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
                                NICE.
                                  πŸ˜„
                                  • T
                                    tomislavm
                                    When can we expect this
                                    Future Ideas
                                    * Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
                                    Automatically fix, o yes!
                                      I don't know. It all depends on when I get a spare moment. I'm currently looking into some UV mapping tool.
                                        Jim
                                        Hi Thom. Here's a scenario - I have a Group I'm checking for a solid. It's quite big and takes a few seconds to open and close the Group. When I use Solid Inspector on the Group to find the errors, I then need to open the Group for editing to fix them, then close it to re-check - open, close, open, close, etc.
                                        Would it be possible to tell the plugin to operator on the current context so we do not need to always change the context between checking and fixing?
                                          Yea - I've been thinking it needs a function like that.
                                          adding to the todo list
                                          • B
                                            Bertier
                                            Hi there, would it be possible to tell solid :
                                            this is (for example) : solid oak
                                            solid oak is : 640 kg / cubic meter
                                            solid weight : whatever volume * 640 in this case ?
                                            that would be great.
                                            thanx to you guys !
                                            • 15
                                            • 16
                                            • 1 / 16
