    [Plugin] Solid Inspector
    303 Posts 99 Posters 339.1k Views 98 Watching
    • jeff hammondJ Offline
      ha! that just saved me a a bunch of headache (well the headache was already coming on trying to figure out why and older group of mine wouldn't be recognized as a solid in su8)..
      used your inspector and it found the teeniest tiniest little face inside
      πŸ‘ πŸ‘
      thank you!
        Creation's crisis! πŸ˜„ β˜€
        • N Offline
          notareal
          Nice!
            jsteacy
            This is a great tool! Awesome!
            • olisheaO Offline
              olishea
              cheers πŸ‘
              oli
                GWD
                Solid Inspector doesn't load. I place the plugin in the plugin folder and also downloaded the TT_lib2 and placed it on the right placed. But the menu doesn't show up. I tried to load it manually and get the following error:
                Error: #<LoadError: (eval):923:in `load': No such file to load -- tt_solid_inspector.rb>
                (eval):923
                regards,
                Guy
                  What is the exact location to extracted tt_solid_inspector.rb to?
                    GWD
                    C:\Program Files\Google\Google SketchUp 8\Plugins
                      This is just odd...
                      You have the file at "C:\Program Files\Google\Google SketchUp 8\Plugins\tt_solid_inspector.rb" - and when you type in load "tt_solid_inspector.rb" into the Ruby Console you get
                      Error: #<LoadError: (eval):923:inload': No such file to load -- tt_solid_inspector.rb>
                      (eval):923`
                      which claims the file is not there... ?
                      I also don't understand why it says (eval):923
                      When I try to load a non-existent file I get:
                      load 'test' Error: #<LoadError: (eval):0:inload': no such file to load -- test>
                      (eval)
                      (eval):0`
                      Are you sure you didn't but the .rb file in a folder and not directly in the Plugins folder?
                      Can you post a screenshot of the file in Explorer (including the filepath in the address bar). Sorry to have to make you confirm what you say, but I have had cases like this where the file actually was misplaced.
                        GWD
                        thomthom,
                        no problem...
                        regards,
                        Guy
                        • KrisidiousK Offline
                          Krisidious
                          I know you're tryin to get me to upgrade Thom...
                          By: Kristoff Rand
                            GWD
                            ThomThom,
                            Problem is fixed. I completly removed v7 from my system. It seams that he sometimes opened v7 when i thought i was working with v8.
                            regards,
                            Guy
                              This doesn't require SU8. πŸ˜‰
                                ThomThom,
                                regards,
                                Guy
                                Ah - yes, if you double-click a file to open SU it will open the version you last used.
                                  GWD
                                  ThomThom,
                                  Thanks for this fantastic plugin!!!!
                                  regards,
                                  Guy
                                    πŸ˜„
                                    • F Offline
                                      fountainhead
                                      I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
                                      "It isn't a real solid...well what's wrong with it?"
                                      "Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
                                      Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
                                      NICE.
                                        πŸ˜„
                                          tomislavm
                                          When can we expect this
                                          Future Ideas
                                          * Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
                                          Automatically fix, o yes!
                                            I don't know. It all depends on when I get a spare moment. I'm currently looking into some UV mapping tool.
                                            • 15
                                            • 16
                                            • 1 / 16
