    [Plugin] Solid Inspector
    303 Posts 99 Posters 275.3k Views 98 Watching
      Overview
      A feeble beginning for a tool that checks if Groups or Components are solids or not, highlighting holes or areas or errors.
      [floatl:26l843su]mmc-solid-test.png[/floatl:26l843su]
      [floatl:26l843su]SolidInspector.png[/floatl:26l843su]
      Access
      Tools > Solid Inspector
      Usage
      Click on an group or component to analyst it for holes.
      Use Tab ( Shift+Tab) to cycle through and zoom to the errors.
      Use Up/Down Left/Right arrows to cycle between errors.
      Use Return to zoom to current error.
      Version 1.1.0:
      If nothing is selected - the current context will be inspected.
      Future Ideas
      • Webdialog list of errors with description of each error. If possible, attempt to automatically fix.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_solid_inspector.rb
      http://forums.sketchucation.com/download/file.php?id=53761
        Ben Ritter
        Wow Thomas, this is more exciting than the version 8 release. Thank you.
        • jeff hammondJ Offline
          ha! that just saved me a a bunch of headache (well the headache was already coming on trying to figure out why and older group of mine wouldn't be recognized as a solid in su8)..
          used your inspector and it found the teeniest tiniest little face inside
          πŸ‘ πŸ‘
          thank you!
            Creation's crisis! πŸ˜„ β˜€
            • N Offline
              notareal
              Nice!
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                jsteacy
                This is a great tool! Awesome!
                • olisheaO Offline
                  olishea
                  cheers πŸ‘
                  oli
                    GWD
                    Solid Inspector doesn't load. I place the plugin in the plugin folder and also downloaded the TT_lib2 and placed it on the right placed. But the menu doesn't show up. I tried to load it manually and get the following error:
                    Error: #<LoadError: (eval):923:in `load': No such file to load -- tt_solid_inspector.rb>
                    (eval):923
                    regards,
                    Guy
                      What is the exact location to extracted tt_solid_inspector.rb to?
                        GWD
                        C:\Program Files\Google\Google SketchUp 8\Plugins
                          This is just odd...
                          You have the file at "C:\Program Files\Google\Google SketchUp 8\Plugins\tt_solid_inspector.rb" - and when you type in load "tt_solid_inspector.rb" into the Ruby Console you get
                          Error: #<LoadError: (eval):923:inload': No such file to load -- tt_solid_inspector.rb>
                          (eval):923`
                          which claims the file is not there... ?
                          I also don't understand why it says (eval):923
                          When I try to load a non-existent file I get:
                          load 'test' Error: #<LoadError: (eval):0:inload': no such file to load -- test>
                          (eval)
                          (eval):0`
                          Are you sure you didn't but the .rb file in a folder and not directly in the Plugins folder?
                          Can you post a screenshot of the file in Explorer (including the filepath in the address bar). Sorry to have to make you confirm what you say, but I have had cases like this where the file actually was misplaced.
                            GWD
                            thomthom,
                            no problem...
                            regards,
                            Guy
                            • KrisidiousK Offline
                              Krisidious
                              I know you're tryin to get me to upgrade Thom...
                              By: Kristoff Rand
                                GWD
                                ThomThom,
                                Problem is fixed. I completly removed v7 from my system. It seams that he sometimes opened v7 when i thought i was working with v8.
                                regards,
                                Guy
                                  This doesn't require SU8. πŸ˜‰
                                    ThomThom,
                                    regards,
                                    Guy
                                    Ah - yes, if you double-click a file to open SU it will open the version you last used.
                                      GWD
                                      ThomThom,
                                      Thanks for this fantastic plugin!!!!
                                      regards,
                                      Guy
                                        πŸ˜„
                                        • F Offline
                                          fountainhead
                                          I think this plug-in is long overdue...great job ThomThom! I can't tell you the number of times I've tried a boolean operation, or a volume calculation, only to get the "this ain't a real solid dude" message.
                                          "It isn't a real solid...well what's wrong with it?"
                                          "Not gonna tell ya...but it's wrong for sure. Good luck finding the problem man."
                                          Now instead of hunting aimlessly for the micro gapped edge, or the itty bitty hanging triangle that can only be seen under exponential magnification, you point us right to it.
                                          NICE.
                                            πŸ˜„
                                            • 15
                                            • 16
                                            • 1 / 16
