Fredo Scale not installing
I'm running Mac Os 10.5.3 with Sketchup 7 and have tried several times to load FredoScale into the application support google sketchup/sketchup plugins folder to no avail. Heres the error message I'm getting:
Erro loading file_loader.rb
uninitialised contstant TraductorError Loading File
ZLoader_Fredoscale.rb
no such file to load-LibFredo6.rbIt does not turn up in the preferences folder for sketchup either...
Ideas anyone ??Thanks in advance
Get the 'Lib' files as explained in the script's download page - either you don't have them or they are not in the correct folders - that's what that error message is telling you!
TIG, have done so for the .LIb files and still no luck...
I downloaded the zip file titled LibFredo6β3.4czip Folder, which i opened and moved directly and completely into the Sketchup plug-ins folder ---It has expanded out to unveil the referenced .lib files. These all reside at the same level of all the other FredoScale files and Fredo scale resides at the same level as a few other plug ins that I have managed to load successfully.
This one is fighting back...thoughts ? -
Richard,
When you unzip, you must respect the file and folder footprint for FredoScale and LibFredo6 as indicated in the main post.
In the SU Plugins directory, you must have only 4 elements:- LibFredo6.rb
- ZLoader__FredoScale.rb
- LIBFREDO6_Dir_34 folder (or LIBFREDO6_Dir_35 if you installed curviloft too)
- FREDOSCALE_Dir_20 folder
Fredo and TIG, still no luck. Below, exactly in order shown, is a screen shot of the the content of my Application support/>sketchup 7>sketchup plugs in folder. Fredo, all the elements you mentioned are there and to the best of my awareness, nothing else from your file.
Still nothing turns up on the sketchup window
R Stanleybezier-1.rb
bezier.rb
bezierspline.rb
Bezierspline.zip Folder
BZ__BSplineU.rb
BZ__CubicBezier.rb
BZ_Dir
DEFPARAM_Dir
drawhelix13.rb
Examples
examples.rb
FREDOSCALE_Dir_20
LIBFREDO6_Dir_34
LibFredo6.rb
nudge.rb
Ocean
ocean_extension.rb
Smustard - Nudge.rb plugin for Sketchup(TM)
stitcher.rb
subdivide and smooth 1/2 Screen shot 2010-07-18 at 7.25.01 PM
Subivide and smooth screen shot 2/2 2010-07-23 at 1.15.41 PM
Subsmooth
subsmooth_loader.rb
Utilities
utilities.rb
ZLoader__FredoScale.rb -
that looks right.
are you quitting and relaunching sketchup after installing.. (sorry, just curious
)are the folders FREDOSCALE_Dir_20 and/or LIBFREDO6_Dir_34 empty?
what's inside the folder called DEFRARAM_Dir? as far as i can tell, fredoscale is the only plugin you have that would use that folder(and, fredoscale would have created it to begin with)
Fredo, Installing Round corner did it,
thanks much,
donation enroute -
alternatively, download the zip attached to this post.
unzip and place the folder 'SU7_FS' on your desktop
open the folder then double click 'SU7_FS_install.app'
launch sketchup and enjoy fredoscale[edit - zip removed]
Richard,
You seem to have two files which should not be at the level of the SU Plugins directory. You should remove them. These are:
BZ__BSplineU.rb
BZ__CubicBezier.rbFredo
hey how did you get fredoscale to download? thanks!
