    Fredo Scale not installing
    11 Posts 6 Posters 2.0k Views 6 Watching
      rstanley
      I'm running Mac Os 10.5.3 with Sketchup 7 and have tried several times to load FredoScale into the application support google sketchup/sketchup plugins folder to no avail. Heres the error message I'm getting:
      Erro loading file_loader.rb
      uninitialised contstant TraductorError Loading File
      ZLoader_Fredoscale.rb
      no such file to load-LibFredo6.rb
      It does not turn up in the preferences folder for sketchup either...
      Ideas anyone ??
      Thanks in advance
        Get the 'Lib' files as explained in the script's download page - either you don't have them or they are not in the correct folders - that's what that error message is telling you!
          rstanley
          TIG, have done so for the .LIb files and still no luck...
          I downloaded the zip file titled LibFredo6–3.4czip Folder, which i opened and moved directly and completely into the Sketchup plug-ins folder ---It has expanded out to unveil the referenced .lib files. These all reside at the same level of all the other FredoScale files and Fredo scale resides at the same level as a few other plug ins that I have managed to load successfully.
          This one is fighting back...thoughts ?
          • fredo6F Offline
            Richard,
            When you unzip, you must respect the file and folder footprint for FredoScale and LibFredo6 as indicated in the main post.
            In the SU Plugins directory, you must have only 4 elements:
            • LibFredo6.rb
            • ZLoader__FredoScale.rb
            • LIBFREDO6_Dir_34 folder (or LIBFREDO6_Dir_35 if you installed curviloft too)
            • FREDOSCALE_Dir_20 folder
              rstanley
              Fredo and TIG, still no luck. Below, exactly in order shown, is a screen shot of the the content of my Application support/>sketchup 7>sketchup plugs in folder. Fredo, all the elements you mentioned are there and to the best of my awareness, nothing else from your file.
              Still nothing turns up on the sketchup window
              R Stanley
              bezier-1.rb
              bezier.rb
              bezierspline.rb
              Bezierspline.zip Folder
              BZ__BSplineU.rb
              BZ__CubicBezier.rb
              BZ_Dir
              DEFPARAM_Dir
              drawhelix13.rb
              Examples
              examples.rb
              FREDOSCALE_Dir_20
              LIBFREDO6_Dir_34
              LibFredo6.rb
              nudge.rb
              Ocean
              ocean_extension.rb
              Smustard - Nudge.rb plugin for Sketchup(TM)
              stitcher.rb
              subdivide and smooth 1/2 Screen shot 2010-07-18 at 7.25.01 PM
              Subivide and smooth screen shot 2/2 2010-07-23 at 1.15.41 PM
              Subsmooth
              subsmooth_loader.rb
              Utilities
              utilities.rb
              • jeff hammondJ Offline
                that looks right.
                are you quitting and relaunching sketchup after installing.. (sorry, just curious πŸ˜„ )
                are the folders FREDOSCALE_Dir_20 and/or LIBFREDO6_Dir_34 empty?
                what's inside the folder called DEFRARAM_Dir? as far as i can tell, fredoscale is the only plugin you have that would use that folder(and, fredoscale would have created it to begin with)
                  rstanley
                  Fredo, Installing Round corner did it,
                  thanks much,
                  donation enroute
                    alternatively, download the zip attached to this post.
                    unzip and place the folder 'SU7_FS' on your desktop
                    open the folder then double click 'SU7_FS_install.app'
                    launch sketchup and enjoy fredoscale
                    [edit - zip removed]
                    • fredo6F Offline
                      Richard,
                      You seem to have two files which should not be at the level of the SU Plugins directory. You should remove them. These are:
                      BZ__BSplineU.rb
                      BZ__CubicBezier.rb
                        carolyn17
                        hey how did you get fredoscale to download? thanks!
                          Here
                          http://forums.sketchucation.com/viewtopic.php?t=17948
