    [Plugin] Free Rotate 4.4
    92 Posts 22 Posters 60.0k Views 22 Watching
    • jeff hammondJ Offline
      [attachment=0:2hw65bgx]<!-- ia0 -->Free Rotate.jpg<!-- ia0 -->[/attachment:2hw65bgx]
      Thanks TIG
      weird, that sort of the visual i get in my head when using the rotate tool as in this recent thread:
      http://forums.sketchucation.com/viewtopic.php?f=15&t=30344
      i don't really know of any practical application of being able to tie these two functions together but it might be there.. (meaning something along the lines of pinning the first point using tig's globe then rotating again around that axis)
      [just throwing this out there in case it will cause something to click in someone's head ๐Ÿ˜„]
        rv1974
        IMHO To become a useful script it must have some 'snap to the bottom center of selection' ability
          @Ken
          The 'Pivot' is the center of the selection's bounding-box, unlessthere is a cpoint [aka 'guide-point'] in the selection -then that is used as the 'Pivot' point.
          I am thinking about ways of adding functionality like holding down Alt so you can dictate so extra constraining points - look for updates in a week or so...
          @rv1974
          A suitable 'Pivot' point can be anywhere - it depends on a user's requirements - its 'Pivot' defaults to the selection's bounding-box center OR to a [pre]selected cpoint - so if you want the selection to rotate about a particular 'Pivot' then add a cpoint there and include it in the selection. If you can't readily find the bottom-center of your selection then you can trick Sketchup into making the bounding-box to suit... you add a temporary cline [aka 'guide-line'] from a bottommost extremity in the selection, drawing it vertically upwards [constrained in blue/Z with shift-key], to a topmost extremity of the selection: then you move that cline so that its top end is where its bottom end used to be... now you include that cline in the selection. Run the tool... the bounding-box is taken to include the cline - so the tool's 'Globe' will increase in size to encompass that cline as well and [as long as there are no cpoints to take precedence] to 'Pivot' should now be centered on the bounding-box and this should be located at the center of the lowest part of the original selection if you were to ignore the temporary cline you just added.
          PS: There are several useful plugins to add 'raw' clines andcpoints - do a Search for them
          • kenK Offline
            ken
            Thanks for the quick reply. However, in the past versions, I was able to select a cpoint, or change to another cpoint. It seems now that I am not able to do this.
            Also, would it be possible to make the globe and on/off selection. Sometime the glob make it hard to see cpoints on the selection.
            And when I select Free Rotate, my curses starts off to the left of the screen where Free Rotate was showing during my selections, so the selections has already been rotated right after I selected Free Rotate. Could the Rotate action start after the next cursor selection, so one would have time to maybe pick the top of the globe, than start the rotation. Right now, after selecting Free Rotate from the menu, I already have a rotation, that is almost impossible to get back to the original start position.
            Again thanks.
            Ken
              @Ken
              If you have one cpoint in the Selection WILL use that as the Pivot - I just retested it.
              Do you have another cpoint elsewhere ? It takes the first one it finds...
              Cpoints inside a group within the Selection are not used to determine a Pivot.
              To 'right' the Selection pick the globe's north-pole - and then free-rotate from there...
              This is a 'work-in-progress' so feedback and advice are welcomed... ๐Ÿ˜‰
              • kenK Offline
                ken
                @tig said:
                @Ken
                Mr TIG
                If I have two cpoints, it will pick one, and pivot around that cpoint. However, I can not move to the other cpoint as I could before.
                I am a little bothered by my posts. It seems to me that I may be complaining about something I have no earthly means of accomplishing, to people who are taking a great deal of time an effort to construct. I try to look at each plugin as how does it help me to achieve a completed project, and try not looking at each plugin as "WOW" it would be neat if it did this or this.
                In using this plugin, I am looking at using it to align rigging. A four part wire sling with shackles, does not have any flat and aligned surface. However, I need to align each sling part from the crane to the load. With this plugin, I could put a cpoint on the the bottom shackle, another on the top shackle, and align the whole sling from the load to the crane.
                Again thank you. I know from a previous post you are very busy and I am thankful for the time you spend working on these plugin.
                Ken
                • olisheaO Offline
                  olishea
                  HOW THE HELL DO YOU DO THIS?!!! ๐Ÿ˜ฎ
                  oli
                    @Ken
                    I think an option [+Alt?] where you can then select a 'pivot' point and a 'grab' point and then free-rotate using those might be useful then?
                    I'm thinking a bit like my 'Mirror' tool where you mirror objects using 1, 2 or 3 picked points which mirror about a point, line or plane: the Free-Rotate Tool could have options to set 1/2/3 points 1= pivot, 2= 1+grab i.e. an axis that follows the cursor; and 3= 1+2+offset i.e. another grab-handle that is offset from the 1+2 axis which allows you to rotate the object around that axis.
                    So you'd probably pick points 1+2 and rotate the object so 1+2s fall on a desired 'line', then you'd pick +3 to rotate the object about that 1+2 axis/line so it aligns correctly in that way too...
                    It is difficult to control completely 'free' rotation as you have the one cursor but need several reference points at once.
                    I am busy for the next week or two... but I'll think about it as I do other things....... ๐Ÿ˜‰
                    @Oli
                    Arcane magic arts... ๐Ÿ˜•
                      Here is v2.0 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                      It includes some radical new methods using modifier-keys Ctrl/Alt/Tab as toggles to freeze/suspend Free-Rotate and let you change the Pivot/Axis dynamically... please read the notes [or at least the VCB text]...
                      Feedback please.
                        Here is v2.1 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                        It now has some radical changes to the modifier-keys "Down_Arrow/Ctrl/Tab" as toggles, to freeze/suspend Free-Rotate and let you change the Pivot/Axis dynamically - using 'Alt' was proving too 'flaky'...
                        The Cursor colors during the 'Tab' options are now fixed too.
                        Please read the notes [or at least the VCB text]...
                        Feedback please.
                        • kenK Offline
                          ken
                          1. It may just be me, but the first thing I do is to make the globe 200% so I can more easily see the selection inside the globe.
                          2. And I just can't figure out what why there is 3 selections on the "TAB" key. I know it states, change the pivot point on one selection and the axis on the other selection, however, I just don't have a clear idea what each does.
                          3. Must time in trying out each of the tab selections, I get to a stage, that I can't start the orbiting again.
                          Ken
                              Ken
                            The 'globe' is currently made 10% bigger than the selection's bounds - it could be bigger if desired... I await more feedback. I'll rest it to x1.5 for the next version to see how it goes...
                            The are 3 Tab steps.
                            Press Tab 1 - you can set the Pivot
                            Press Tab 2 - you can set the Axis
                            Press Tab 3 to finish... BUT I see what you mean... once the Axis is done you are done. ๐Ÿ˜’
                            I have changed the selection keys - 'Alt' is flaky and locks up ???
                            See v2.1... but I am considering v2.2 to sort out the Tab anomaly...
                            Thanks for the feedback.
                              Here's v2.2 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                              The Tab options are rationalized - picking the axis-point exits to the previous state.
                              The default 'globe' radius is 150% of the selection's bounds but the notes contain advice on changing this to suit your preferences...
                              • kenK Offline
                                ken
                                Darn, TIG, I just can't get the second TAB to work consistently. There are times it works sometimes, that I get exactly what I want, other times I just can not figure out what I am doing wrong. Note, by the time it works, I have pressed so many keys, I not sure just what made it work.
                                1. I press the down arrow, it resets, and stops.
                                2. I press the TAB, and I can set the pivot point, by moving my cursor the location and clicking the left mouse button.
                                3. I press the TAB again, and here is where I get lost. How do I select the next point, or axis?
                                Ken, confused.
                                • CadFatherC Offline
                                  CadFather
                                  Thanks TIG - cool plugin.. ๐Ÿ‘
                                    Ken, confused.
                                    3... Press TAB and then Pick a point on the axis - it should be on a line from the pivot to where you pick [I'll add a guide-line in the next update it might assist...]
                                    4, After you pick it waits for you to press Down_Arrow or Ctrl to restart the Free-Rotate OR you can Tab again to set anew Pivot & Axis point...
                                      Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=266561#p266561
                                      It now draws a DarkOrange guide-line from the Pivot-Point [picked at Tab-1] to the moving cursor before you pick the Axis-Point [Tab-2] - This might help clarify what the axis-line will be when you click that second point. This is 'axis' is the orientation that the object will use and 'point' to the moving cursor, as it rotates freely anchored at the pivot.... ๐Ÿค“
                                      • mitcorbM Offline
                                        mitcorb
                                        Thank you, TIG:
                                        I am going to download and experiment with it.
                                        • kenK Offline
                                          ken
                                          Well I see my problem. When I picked the pivot point, it has a sticky attribute, however, the New_Axis Point did not have this characteristic. It doesn't become sticky until you press TAB again or the down arrow. This is shown in the video, after selection the pivot point, I press TAB and now try to pick the New_Axis point. Note, I see the change to the selection point is made by the circle color, however, I am still allowed to move this point until I press the TAB or the down arrow.
                                          And to the second anomaly. If I correctly pick a pivot point and New_Axis point, and just move the cursor around and around the globe and come back to the starting point on the globe, the selection is not at the original position. I would think that it should be at the same positioning before and after rotation, if I don't make the final selection.
                                          Again thanks.
                                          Ken
                                          FreeRotate2.wmv
                                            Ken
                                            I'll watch it and absorb...
                                            • 1 / 5
