    Drop Geometry to Surface - Brainstorming for methods
    12 Posts 7 Posters 1.4k Views 7 Watching
      Jim
      SmartDrop does this, so maybe there are some ideas to be drawn out from it.
      http://forums.sketchucation.com/viewtopic.php?t=3474
        SmartDrop deals with the bounding box of the instances - not the actual geometry.
          @martinrinehart said:
          I'm not sure I understand what you want to do. Is the object a ComponentInstance?
          Drop a Group or ComponentInstance downwards to the surface underneath by the actual geometry inside.
          • TIGT Online
            An instance will 'rest' on the surface on three points [?].
            Test all instance-vertices and their intersections with the surface - getting paired points.
            Take the pair with the shortest distance between them.
            We'll all that instance_pt0 and surface_pt0
            Drop the instance vertically onto that surface-point.
            Now retest [excluding the instance_pt0, that is now zero distance away].
            If at least two of the other tested vertex-points are also zero distance away you do nothing more as the instance now rests on the surface.
            If not then find the nearest matched pair again = instance_pt1 and surface_pt1.
            This time you can't 'drop' the instance - you need to rotate it in 3D so this second vertex is touching the surface NEAR surface_pt1 [can actually be on it!].
            To do that find the
            angle = surface_pt0.vector_to(surface_pt1)angle_between(surface_pt0.vector_to(instance_pt1))
            then the transformation to rotate the instance
            axis = surface_pt0.vector_to(surface_pt1).cross(surface_pt0.vector_to(instance_pt1)) tr = Geom::Transformation.rotation(surface_pt0, axis, -angle) ### it's untested! or maybe +angle ??? instance.transform!(tr)
            Now we have the instance rotated so that instance_pt0 and instance_pt1 both touch the surface...
            Retest for nearest matched pair again - this time omitting the 2 vertices that touch the surface.
            If there is at least one pair at zero distance do no more since you have three touching vertices; if not you need to re-rotate the instance again so that the third [nearest paired] vertex instance_pt2 again touches the surface NEAR the intersection at surface_pt2.
            We need a pivot_point relative to surface_pt0 and surface_pt1...
            vector01=surface_pt0.vector_to(surface_pt1) line01=[surface_pt0, vector01]
            Find the point on line01 nearest surface_pt2
            pivot_point = surface_pt2.project_to_line(line01)
            Find the vectors from pivot_point to surface_pt2 and instance_pt2 and the angle between them
            etctetc yawn!
            'cross' the vectoro1 and the vector pivot_point.vector_to(surface_pt2) to get the rotation_axis.
            again transform rotation the instance about pivot_point and rotation_axis by ang [or -ang???] and you should now have at least 3 points of contact ?????????????
            I ran out of steam during the last few bits of code but you get the idea........... πŸ‘Š
              That's the thing - is brute force the only method? Testing all kinds of combinations?
              Another issue: say you find three points that rest of the surface, now, it could be that they are very close together - say a chair's leg, you might end up with the chair resting on one foot and the remaining three legs in the air.
              I guess we are then talking about taking mass and gravity into account - a whole lot more complicated?
              One way I was pondering about was - brute force iterate over various combinations and see in which combination the most points are closest to the surface ... ?
              • jeff hammondJ Offline
                not really sure how krill is doing this but maybe it's related?
                http://forums.sketchucation.com/viewtopic.php?t=24676
                  Never noticed that plugin before.
                  It's not doing what I'm trying to do though - but still interesting. It subdivides the selected group and makes it fit to the surface underneath. Nearly like vacuum forming. Could come in handy.
                  • Dan RathbunD Offline
                    Dan Rathbun
                    @thomthom said:
                    I'm able to find the points facing the surface underneath - but then what?
                    Any clever way of fitting the object to the surface?
                    There's a theread over at GG, where a guy and I discussed this a few days ago.
                    He had a different purpose of course.
                    contour seen from above
                    I'm not here much anymore.
                    • N Offline
                      notareal
                      Maybe kirill2008 Stick groups to mesh can inspire
                      Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                        Same as Jeff's link. πŸ˜‰
