    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 438.3k Views 87 Watching
      Busy today! Heres 1.8 - Trapped for spaces in image-names/paths.
      http://forums.sketchucation.com/viewtopic.php?p=172790#p172790
        @tig said:
        Thomthom, I assume you are referring to the size/units ?
        No - it was the messed up geometry you noticed. You see it in the screenshots I posted - with the red circles.
        @tig said:
        PS: I can't tested your problem 'van' OBJ/MTL because PPartner010000.jpg wasn't in the zip file?
        But I can see that its geometry seems a bit messed up around the side windows and the image file-names have spaces in them which confuses the MTL parser. I thought that you were 'recommended' to avoid having spaces in these paths/names - however, manually editing the MTL and the corresponding image-names so they are without spaces fixes that... BUT the 'PPartner010000.jpg' file is still missing altogether - see the Ruby Console error reporting πŸ˜•
        The OBJ was initially created by SketchUp - then edited textures in PhotoShop.
        I've attached the missing texture.
        Will try v 1.8
        missing texture
          Even with 1.8 some geometry is messed up. Seem to be the same faces.
            I see the messed up UV textures.
            I re-imported it as 'mm' and the messed geometry went.
            BUT I had to edit the faulty UV mapped parts manually.
            As it's symmetrical a quick mirror/copy of the correct panel on the other side fixed them.
            The 'Badge' is messed up though - did you map that on separately ?
            I've no idea why just those few parts fail to map properly πŸ˜•
            VAN.PNGVAN.skp
              I import in mm - but it's not just the UV being messed up. It's the actual geometry.
              Notice that for the incorrect mapping the face is split diagonally-crossing itself - as opposed to the mirrored side.
              When you compare against the 3ds import you see that Max does not do this.
              I did not do anything to the mapping other than take the OBS into PS and adding the text on the side of the van. The model came from a pre-modelled and pre-mapped third party model.
              I wonder if it's the order of the vertices that's abnormal in these cases... ?
                The cross-threading of the faces' vertices into 'bowtie' triangles - which then probably mess up the UV-mapping - must be in the OBJ file itself [?].
                The OBJ Importer simply uses the f n/n nn/nn/ nnn/nnn... values to form the faces and mapping ? Unfortunately unless you can reproduce the problem in a file with relatively few faces it'll be all but impossible to plough through the data to find the problem instances... [+460+ faces here?].
                I was hoping that the OBJ had some -ve face indices that were causing the problem which recent versions might have solved... but NO! πŸ˜’
                In SUp export the ordering of a face's vertices shouldn't be a problem as they should always return ordered, and in the correct 'clockwise-ness' for the face's normal direct ?
                  Jim
                  The vertexes in the 'f' line are out of order for whatever reason.
                  Creates a "bow tie":
                  Sketchup.active_model.entities.add_face([0,0], [1,1], [1,0], [0,1])
                    So it's the OBJ data that's invalid... but Max manage to deal with it somehow.
                    I'll compare against the raw output from SU and see if it's SU or PS that mangles the geometry.
                      It's SU generating the odd vertex order. Here's the OBJ directly from SU:
                      SU Export
                        Could you PM me the original textured SKP - I have a new embryonic OBJ-Exporter that might NOT do this glitch ?
                        • N Offline
                          notareal
                          Here is a model that seems to fail http://www.fileden.com/files/2009/5/30/2461193//dragon_scene_OBJ.rar (From CGTalk Frosted Glass Challenge). Maybe it's a bit large... but simlab obj importer seems to handle it.
                          • honoluludesktopH Offline
                            honoluludesktop
                            TIG, Wow, nice piece of code. Lots stuff I have to learn, like next, case, when, def file.run(par1, par2), etc. Makes the code look more compact and easy to read. Oh well, if I looked here before starting what I am working on, I may not have understood:-)
                            Some of the stuff that's driving me nuts when writing importers, is that different exporters do not format the data exactly. SU's DxfIn treats "10", and " 10" equally, and many exporters ignore the convention that is " 10". I don't know if I should go back and fix my code to read "10" or not. It's no problem for my use, and would like to "share", but am concerned about posting something that may not work for some.
                              honoluludesktop
                              A DXF has alternating lines for 'code' and 'value'.
                              So if it's an odd-numbered line then it's always 'code' and if it's an even-numbered line it's always the previous line's code's 'value'...
                              It's a DXF convention to indent the 'code' number, BUT it's not necessary and any importer should strip off leading spaces anyway...
                              SECTION
                              HEADER
                                9
                              etc
                              is the same as
                              SECTION
                              HEADER
                              9
                              etc
                              To see a DXF 'parser' look at my DXF Text Importer http://forums.sketchucation.com/viewtopic.php?p=194488#p194488
                              πŸ€“
                                honoluludesktop
                                OK, thanks, I will look at it. I may have to wait for a complete rewrite to parse the 'code'. Isn't some of that done in the Obj translator? I couldn't tell since I am not at all familiar with Obj.
                                When I think about it, any translator can be a modular app., just as you did with the text importer as a supplement to SUs DxfIn. My own interest has been limited to very basic geometry, and dealing with the anomalies of my Cad's DxfIn/Out. It suits me since I use SU exclusively for visualization and modeling, and Cad for functional diagramming and production drawings. Accordingly, I only require the basic geometry to pass between SU and Cad.
                                • O Offline
                                  onesimo
                                  hi tig! thanks for the importer. its working perfectly for me on my archmodels.
                                  i should have tried it when i first saw the post. thanks so much and i really appreciate your work.
                                  • O Offline
                                    onesimo
                                    hi tig! im using 3ds max design 2011. when i open/obj import my exported file the textures are not showing.. it seems my .mtl file is different from the one posted (the one with the building). thanks!
                                    my exported file from 3ds max
                                    • KrisidiousK Offline
                                      Krisidious
                                      I imported an Obj file and the uvw map came in perfectly.
                                      but some geometry was lost... any ideas on why?
                                      By: Kristoff Rand
                                        The MTL file has the lines
                                        Ka 0.0000 0.0000 0.0000
                                        Kd 0.0000 0.0000 0.0000
                                        Ks 0.3500 0.3500 0.3500
                                        they should read
                                        Kd 0.3500 0.3500 0.3500
                                        Ks 0.0000 0.0000 0.0000
                                        The Kd value sets the material's RGB color in the original MTL file it is [0,0,0] = 'black'
                                        If you swap the Kd and Ks values and it renders 'gray' as expected...
                                        Only the 'Kd' value is read by the SUp importer - the other twp 'K' values involve reflectivity and spectral info that SUp can't use and are superfluous...
                                        Also if an MTL material has an image_file defined at the end of its text_block that will be used as its 'texture', overriding any RGB 'color' - but this material does not have a texture.
                                        When you make an OBJ file check that its MTL file's 'Kd' is set to RGB otherwise it will be 'black'.
                                          The OBJ importer should import all available geometry described in the file - sometimes with very convoluted meshes it can fail, but it rarely 'misses' stuff out - in fact it's more likely to try and tie vertices together that don't join in the original with extra geometry!
                                          If you import the same file into another app - like Blender? - is it still missing parts?
                                          If so perhaps the export didn't pick up parts in the first place πŸ˜•
                                          What app made the OBJ file originally?
                                            Krisidious
                                            it came from AC3D, I tried the file in 3Dmax and it's all there. it's no biggy, I don't need to do it. I was just trying it out.
                                            By: Kristoff Rand
                                            • 13
                                            • 14
                                            • 5 / 14
