    How to remove a house from a photo
    22 Posts 14 Posters 4.8k Views 14 Watching
    • W
      wyatt
      Yeah, the content aware fill in CS5 is such a great tool. Sometimes it requires a few iterations to get it to look right, but it's a tremendous time saver compared to the clone method. I've heard Gimp has something similar, though I've not used it.
        @solo said:
        Whoah!! that CS5 has some cool stuff.
        Yea - we finally got it at work. It's great at doing the bulk work. Quite impressive how often it does it right.
          Aerilius
          Adobe sells it as innovation, but Gimp has that feature since 2005.
          As you see, the result is not equal (CS5's tool is more intelligent), but for landscapes the difference is not noticeable. So if you want to use it but don't have CS5, you can just install gimp-resynthesizer (or http://www.logarithmic.net/pfh/resynthesizer)
          • Al HartA
            Al Hart
            @massimo said:
            Photoshop Cs5 is quite a nice tool. A 5 sec work. Just made a rough selection then pressed canc. Obviously you can complete better the job with some additional work. 😄
            Wow!
            Are you telling me that CS made the third image from the 1st image all on its own?
            Al Hart
            IRender nXt from Render Plus
            • Chris FullmerC
              Yes! <in summary> It has to be the newest CS5. And GiMP has had it for a few years, though possibly not quite as clean as the expensive photoshop version.
              And all previous versions of Photoshop had tools that let you do it manually very quickly (again, depending on the photo - some are rather time consuming to fix).
              But still, that CS5 example above is very impressive! I hope some day my office decides to upgrade. I have a feeling we'll be skipping 5 altogether though 😞
              • massimoM
                massimo Moderator
                Wow!
                Exactly Al, just what I said: a lasso selection and canc. That's all.
                Obviously the result depends on the base image and often you need some additional work.
                Here you have another example made with the "spot healing brush tool": paint on the objects you want to remove, then release the left button of the mouse...
                  dylan
                  Amazing tools. Maybe I should upgrade my CS4!
                  http://dmdarchitecture.co.uk/
                  • bmikeB
                    bmike
                    Where in GIMP?
                    I'm running 2.6 (just downloaded a few weeks ago).
                    Can't seem to find it!
                      Aerilius
                      It is a plugin "gimp-resynthesizer". You can download it here: http://www.logarithmic.net/pfh/resynthesizer
                      • N
                        notareal
                        This technique was represented in SIGGRAPH some years ago. There is also another image operator called seam carving that supports content-aware image resizing (CS4 and greater).
                        • daleD
                          dale
                          You can also remove an image in PS Elements with the "magic extractor", but I think you will have to fill the space manually with clone tool etc.
                          The Gimp plugin is windows only, or used to be anyway.
                            Aerilius
                            The Gimp plugin supports many platforms. The easiest installation is in Linux, Windows is a bit more to do by hand and the site offers also a download for OS X:
                            http://www.logarithmic.net/pfh/resynthesizer/history
                            • daleD
                              dale
                              Thanks, that's good to know, I'm using Gimp more and more. It does fairly good bump and normal maps as well.
                              • E
                                ericschimel
                                That new CS5 "Content Aware" tool is just amazing.
                                This video is the most compelling use of Content Aware 🤣
                                -Eric
                                http://plugin.sketchthis.net
                                Sketchup Kitchen Design Plugin
                                Custom Models
