    I am Finally BUILDING!!!
    101 Posts 23 Posters 18.5k Views 23 Watching
    • aadbuildA Offline
      aadbuild
      I like the way the walls are going to be fully braced great for strength. We don't get earth quakes in Australia or tornadoes so we are only required to do 60% of the walls in bracing. Glad to see your house coming along David.
      Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
      https://www.plusspec.com
      • david_hD Offline
        david_h
        Well , the bracing is temporary until the upper floor joists and roof are installed which will provide a rigid diaphragm. However, there are also lots of shear panels in the walls for lateral strength. My area is a category 3 earthquake zone. Plus we can have fairly strong wind gusts from time to time so we design to pretty rigid lateral stress standards.
        • david_hD Offline
          david_h
          as of yesterday afternoon. . .this is getting very exciting.
          • david_hD Offline
            david_h
            2 days ago. Framing is pretty much done. we are starting to put in the guts now. . .elec, plumbing and mechanical.
            sorry  .. lousy cell phone camera on a cloudy day
              I see the house but where's the tree? πŸ˜‰
              Oooops, wrong thread!
              Really nice home David. I hope the rest of build goes as planned πŸ‘
              • david_hD Offline
                david_h
                it seems like I fell an entire forest of trees to build this thing.
                • david_hD Offline
                  david_h
                  putting the roof on!
                  • david_hD Offline
                    david_h
                    Windows Installed. 4-way inspection today. . .and then we start closing her in and doing finishes!
                    • Chris FullmerC Offline
                      That's awesome David! It is looking great, I like the updates. Keep them coming,
                      • david_hD Offline
                        david_h
                        So . ..I we went thru the 4-2ay inspection yesterday. Got dinged on a few things--mostly having to do with switching from stick frame to trusses -- but all in all it went okay.
                        We start drywall and sheathing this week, once I get the inspectors satisfied with the corrections.
                        It's goin' sooooo fast! but my wife is thrilled and that's the most important thing.
                        • david_hD Offline
                          david_h
                          Well the 4 way re-do is done. These dingbat inspectors had to actually Make up stuff to ding me on because the house is so well built, if I say so myself. These 2 city inspector idiots actually argued -- with each other no less -- about whether or not my attic style bedroom --which is huge BTW -- allowed enough head room. They have to justify their existence and their paycheck I suppose. Seriously, I think I have the only house going up in my pretty small town, so these guys really need something to do. So rather than 1 guy, they send 2. Instead of spending 20 minutes checking off items from the previous list, they spend 2 1/2 hours trying to find new stuff. . . .This is the room they groused about.
                          My builder: Excuse me. . you approved the drawings. We built it as per plan and now you're wondering whether we need to rebuild it? Are you kidding me? Bedrooms like this have existed for centuries.
                          Inspector: I can do it. . .It's my job.
                          My builder: I don't think so. . .
                          It went on like that for 20 minutes.
                          But, the house passed, and we are now insulating, sheathing and start dry wall probably first of the week.
                          Its great.
                          • N Offline
                            notareal
                            Inspectors 🀣 I kind of got a similar experience... Our fire regulations do define exit routes quite detailed, what are minimum dimension for windows used as exit, how they should open and so...
                            Anyhow I had forget some safety lock on (or stopper) that prevents window open too much on a window that is used as fire exit. Naturally they did give me a notification that window did not open properly. When re-examination was done later (now it did open properly as the stopper was removed) inspector was trying to give a notification about missing stopper!
                              In the UK there used to be strict rules about 'rooms in the roof' - half the floor area had to have a ceiling of 7'6" [2.3m] or higher whilst the rest was to be at least 5' [1.5m]clear - you could not count anything under 5' as usable floor area: the opening window[s] then had to be 1/20th of the floor ares and their glazed area[s] 1/10th [measured on the floor itself - excluding skirting boards ?]; for all windows a zone of space outside of the window 5'/1.5m wide [irrespective of the glazed width] at the sill [or 4'/1.2m] up, taken up to the glazing head and thereafter extending up at 45 degrees out 12'/3.6m and 12'/3.6m width, the outer rectangle of the zone at least overlapping the centerline of the window by some extent, all this discounting overhanging eaves/canopies/similar projections up to 5'/1.5m out...
                              Then they scrapped minimum heights etc and it became something of a free for all - only 2m minimum height below a beam/lintel you had to pass under and on stairs etc [1.5m measured perpendicular to pitch] etc... It's much more sensible. But there are new rules about cleaning widows, glass-safety, fire-escape windows - sill-height/clear-width/-height etc etc πŸ˜’
                              • david_hD Offline
                                david_h
                                Oh no question. Yeah. . .we had to have 70% of the floor area under 7'6" or greater. However, that isn't the case here, because A) the room is actually about a foot higher than as shown here cuz of the switch to roof trusses, but also, the color tie is at 8'6. the room more than qualifies.
                                • david_hD Offline
                                  david_h
                                  All the walls insulated. One day. These guys are movin'!
                                  D
                                  • david_hD Offline
                                    david_h
                                    Sheathing started today as well as tape and mud. very exciting. Paint colors are chosen and so are many of the light fixtures.
                                    Kitchen Ceiling
                                    • JClementsJ Offline
                                      JClements
                                      Dave, I really like the style/design of the house. It reminds me of the style of the house I grew up in in S.E. Portland, Oregon (no, I don't know Tanya Harding πŸ˜• )
                                      What neck of the woods is your new home?
                                      • david_hD Offline
                                        david_h
                                        I live just south of Salt Lake City. . Murray UT be exact. Thanks for the interest. I am having a little heartburn this morning tho because the siding is up and they forgot the window trim. .Geez. . .you try to leave town for a few days for Basecamp . . . so I am trying to get my contractor on the phone.
                                        • david_hD Offline
                                          david_h
                                          Well, My contractor said. . "oops!" so they will fix it. Good. I am so tired of losing sleep over this. My wife / my client said to me last night
                                          "I am not just excited to move into this house because you designed it. I am not just excited to spend our first holiday season in the new house. I am just excited to have this done because I am sick of worrying about this and that and every little detail. It's exhausting."
                                          Hear. Hear.
                                          πŸ’š
                                          • david_hD Offline
                                            david_h
                                            P9090005.JPGAs of this morning. . .Siding and flooring. They need to go back and put trim around the windows, but it's going to be great! 😍
                                            • 3 / 6
