    Polar Array
    11 Posts 8 Posters 3.6k Views 8 Watching
    • C
      cjlopez4
      I like to array a component along an arc, however how do I find the center of the arc to array the object?
        mac1
        Couple of ways to find center. Brute force and plugin
        The arc segments are just the cords of a circle so pick two, find the centers and construct a bisector and they will intersect at thee center. The easy way is use the plugin point at center http://forums.sketchucation.com/viewtopic.php?f=323&t=18963&hilit=point+at+center
        • BoxB
          If you draw the arc you want, then draw a straight line from the end of the arc towards what you think is the centre it will snap to the centre.
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            Make sure that you have enabled the "Utilities" extensions in Windows Menu --> Preferences --> Extensions.
            You usually do that once.
            When done, restart SU. Now, when you right click on a circle, a polygon or an arc, the Choice "point at center" will show in the contextual menu. This will place a "Guide Point" at the center. You can delete it later if you dn't need it anymore.
            However, you really don't need this utility since you can infer a center. Just hover the cursor on any endpoint on the curve and, when you get the pop-up stating "endpoint", move the cursor around where the center should be. You should get a pop-up stating "center".
            Of course, for shallow arcs, having a very large radius, the "point at center" is easier to use, since you loose less time eyeballing the center.
            Just ideas.
            • bmikeB
              bmike
              @jean lemire said:
              Hi folks.
              Not seeing this work for me... on an arc or circle.
                mac1
                @bmike said:
                @jean lemire said:
                Hi folks.
                You may have to enable ruby scrip examples also
                • boofredlayB
                  boofredlay
                  Jean, this must be a plugin as I have never seen it.
                  Here is a short video of a couple of methods.
                  [flash=767,512:5qutom5l]http://content.screencast.com/users/Boofredlay/folders/Jing/media/a0892b04-0cc3-4f84-a0f1-adf0ec6ca481/2010-08-02_2150.swf[/flash:5qutom5l]
                    Here's a tweaked version of the @Last ArcCenterContextMenu ruby ArcCenterContextmenu.rb - put it into Plugins and restart. Whenever you have an Arc/Circle selected you'll get the option to add a Point at its center.
                    This doesn't work on scaled or exploded arcs - then Chris Fullmer has another tool for this too http://forums.sketchucation.com/viewtopic.php?p=155504#p155504
                      Jean's suggestion works for me perfectly. But only as TIG says on non-scaled/exploded arcs or circles.
                      @TIG
                      what's been tweaked?
                        @TIG
                        The file name and text in context menu etc - nothing dramatic πŸ˜‰
                        • boofredlayB
                          boofredlay
                          Cheers for that TIG. This is one I had never seen (or realized I had seen πŸ˜‰ )
