    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 188.8k Views 88 Watching
      mspisz
      Hey Chris!
      Great plugin!, does exactly what I need it for in school!
      Your the man!
      Milo
      • Chris FullmerC Offline
        Great, glad it helped. It is admitedly outdated now though. Check out TIG's extrude scripts. Those are considerably more powerful!
        • O Offline
          ovandenbroek
          Hi Chris and all others,
          I like the concept of loft very much. In fact, it is one of the tools IMO that are making sketchup becoming a 'really' professional tool...
          see the attachment of a particular shape (based on a design made earlier in 3DMAX, it's a counter).
          I think you can make this only with 'loft' and not with TIG extrude tools. (?)
          Okke
          (PS For this kind of work I would love to have some more control over the 'bending' spline. In planview it's supposed to be a round counter, but as you can see the bending is not totaly 'circular')
          Loftshape-ovdb
            EEbyRails requires some 'rails' to follow - CF's Loft doesn't - it always joins the two profiles by a bezier [?] curve [and you must have equal numbers of segments in each profile and no 'loops' allowed].
            To use the profiles you have shown with EEbyRails simply add some curves between them to be used as rails... then do a pair of profiles in turn with their 'rails[s]', using the second profile as the first profile in the next pair etc...
              arch.sani
              just found it out, installed and tried: Chris, this is simply fantastico!
                anient
                Had to join the forum simply to get a hold of this pluggin thanks sooo much πŸ‘
                  guillermorage
                  how do i install it
                    The first post in this thread has the instructions. It's the same for most plugins here. Some are zipped so they need extracting. Others are just .rb files which need to go in your plugins folder. And some are .rb with folders containing files.
                    All plugins go in your plugin folder.
                      guillermorage
                      Sorry, i am new in this forum, im using mac, i downloaded and its a ziped file, so i extracted and it appears a folder wich contains an rb file called:clf_simple_loft_loader.rb and another folder which contains; clf_simple_loft_small.png, clf_simple_loft.png, clf_simple_loft.rb.
                      I tried to move them to the plugins and then open sketchup, but nothing.
                        When you extract you get this...
                        Place both the .rb and the folder in your plugins folder. Do not take the files out of the folder as this will prevent it working.
                        I'm not familiar with Mac so where your plugin folder is located is a mytery 😲
                          If you are unclear about where your β€˜Plugins’ folder might be then type [or copy+paste] this line into the
                          Window > Ruby Console:
                          Sketchup.find_support_file("Plugins")
                          • press <enter>
                          Typically the PC path that is returned is:
                          C:/Program Files/Google/Google SketchUp 7/Plugins
                          Whilst typically the Mac path that is returned is:
                          Macintosh HD/Library/Application Support/Google Sketchup 7/SketchUp/Plugins
                          Test to see where yours is... πŸ€“
                            microracer9
                            I installed it.... 1st time it worked perfectly....now...dont work.
                            Any idea why?
                              When reporting software problems please be more specific to what doesn't work. Is it a particular operation that fails? Or does it appear to not be loading at all? (No menus/toolbars) Any error messages (open the Ruby Console as see if any messages appear when you try to use the plugin) ?
                              That's the only way for the developer, or any other, to have an idea of what "doesn't work" and why.
                              • N Offline
                                nektares
                                This is amazing! you are a very creative coder, thanks for this!
                                    Gromit
                                    Chris, You are A GENIUS!!!
                                      jeh397
                                      I just downloaded the loft plugin and I'm finding that once I select the loft tool
                                      I can't select any of the curves in my model. Any suggestions?
                                        Jacqueline, could you post either the model or a screen shot so we can see what you're doing?
                                        Out of curiosity, is there any chance your curves are inside components or groups that are not open for editing?
                                          Alezio
                                          Thank you so much for sharing this use full πŸ‘ plugin . im new in sketchup....perhaps everybody would like to help me....thank's again πŸ˜„ πŸ˜„ πŸ˜„ πŸŽ‰
                                            You're welcome. There are better tools for lofting now. This was the first one, but TIG and FREDO in particular have done lots of amazing work with lofting plugins. I'd recommend looking at theirs.
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
