    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 415.3k Views 92 Watching
      hmm... a sort of brush... interesting idea...
      • X Offline
        xrok1
        it would be like the smoove tool works when nothing is preselected. ๐Ÿ˜‰
        also a weld tool would be nice too with distance setting like in MAX. ๐Ÿ’š
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          Yup! Already on my list.
          ... I should probably make a list of the features I am planning...
          Other features are:
          Jitter - randomly offset the vertices
          Gizmos - Move,Rotate and Scale gizmos for better control
          And some other stuff ๐Ÿ˜‰
          • X Offline
            xrok1
            love the jitter idea. i already use the jitter ruby (modified a little ๐Ÿ˜‰ ) to add a little age or just mellow out the CG look sometimes.
            • honoluludesktopH Offline
              honoluludesktop
              Wow, it that a mesh, or linked surfaces?
                What is?
                  honoluludesktop
                  The plane, or cylinder, etc. Hmm..... maybe I don't know how to ask my question. If still unclear, attached is a sample. Can I change its shape? What happens to the textures? Btw, thats a very slick menu.
                  Temp00.skp
                    Yes - here's your model after I selected a part of it, with soft selection and moved it. Looks like the wind pushes the curtains.
                    As for the UV mapping, that will unfortunately be messed up - as normally happens in SketchUp when you modify UV mapped geometry.
                    However, this is another feature I am looking into. If I can get it working I will probably also make a standalone "preserve UV mapping" plugin.
                    I hope that answered your question? ๐Ÿ˜•
                      Btw, here is your sample file after I modified it. The UV mapping didn't seem to bad.
                      Temp00_TT.skp
                        honoluludesktop
                        Thanks, where were you when I needed it ๐Ÿ™‚ the texture was a SU floor covering that I scaled and changed the color of.
                          Coding into the night ๐Ÿ˜‰
                          • shuraS Offline
                            shura
                            Woohoo! Thomas, this is a fantastic modelling tool! I feel so lucky watching this wonderful software growing in your hands. Gizmo control? how cool is THAT?
                            btw, nice to hear your voice again ๐Ÿ˜‰
                            best
                            alex
                            • X Offline
                              xrok1
                              Thom, what address do you send your email from? maybe the domain name is in my blocked sender list for some reason. i still havn't recieved. ๐Ÿ˜ž
                                honoluludesktop
                                Thom, How difficult would it be to use portions of your algorithm to redraw a selected mesh with 50% less faces? We could use a simple plugin to do this. I have a pair of shoes I like to include in my scenes to be rendered that have more faces then the model itself. If I could select the mesh that I needed reduced, even if the change is by every other vertex, I could reduce the mesh to something manageable.
                                • X Offline
                                  xrok1
                                  are you talking about a cage or proxy mesh? or opposite of subdivision?
                                    honoluludesktop
                                    What is a cage or a proxy mesh?
                                    • X Offline
                                      xrok1
                                      like in SDS where you edit a high poly mesh with a low poly mesh (cage) around it.
                                      here is an example: you manipulate the outer mesh to effect the inner one.
                                      • X Offline
                                        xrok1
                                        ๐Ÿ˜ฒ this is better than i could have dreamed! it works with SDS!!!!!!!!!!!! ๐Ÿ˜ฎ
                                        SDS WITH SOFT SELECTION!
                                        http://forsythe4kc.com/uploaded_images/HeadExplodeBig.gif
                                        • ArcA Offline
                                          Arc
                                          I made a little video tut, but I don'n know how to instert ping video in post?
                                          http://www.screencast.com/t/OTlkZWRjMT
                                          [flash=800,600:29tenr79]http://content.screencast.com/users/xwtao/folders/Jing/media/9c408fd9-078e-401b-bb07-fe845dfd7e86/2010-07-21_vertextools.swf&blurover=false[/flash:29tenr79]
                                            honoluludesktop
                                            Not sure I get it, but it seems like what I suggested is a simple reversal of subdivide. May be not so simple?
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 33
                                            • 34
                                            • 17 / 34
