    Architectural models - untextured, unrendered
    33 Posts 13 Posters 4.3k Views 13 Watching
    • brookefoxB
      brookefox
      @pbacot said:
      Thanks, I guess you don't run into that problem. If I leave as much as 1-2" between a line and a covering surface--not coincident--and view the surface from some distance, the lines bleed through,looking dotty.
      Oh yes, for what its worth, I have that problem, too.
      ~ Brooke
      • brookefoxB
        brookefox
        An even less polished attempt at a model of the existing structure. The railing really pretty much looks like that.
        ~ Brooke
        • daleD
          dale
          Great work. It reminds me of a job I was involved in a while back. Although this ended up as a monster file colored, textured and rendered, in the early stages we presented them as simple line drawings. I was always fond of it, maybe because of a background in hand rendering. I had several, but could only find this one.
          • bmikeB
            bmike
            Nice to see other work that keeps it simple.
            I posted these over in the LO discussion on construction documents: (size will hurt me here, these were 24x36" PDFs)
            http://lh5.ggpht.com/_0jkA5M3PGcY/TAgS8rNOEfI/AAAAAAAAPRg/MLtHgfNq2Hw/s800/vww-6-2-10-presentation_14.jpg
            http://lh4.ggpht.com/_0jkA5M3PGcY/TAgS7KlD9-I/AAAAAAAAPRI/aRoaJXwk38o/s800/vww-6-2-10-presentation_03.jpg
            Another project:
            http://lh5.ggpht.com/_0jkA5M3PGcY/S47R9usMzlI/AAAAAAAAOvI/pZzgrI8fwks/s800/millrd-presentation_01.jpg
            http://lh4.ggpht.com/_0jkA5M3PGcY/S47VeCJZR7I/AAAAAAAAOvw/MATZLkwV90I/s800/millrd-presentation_03.jpg
            http://lh6.ggpht.com/_0jkA5M3PGcY/S47RfUBqjNI/AAAAAAAAOug/yNobOMTAFok/s800/millrd-presentation_12.jpg
            http://lh3.ggpht.com/_0jkA5M3PGcY/S47Ry5ItDNI/AAAAAAAAOuk/slcbzaoND3s/s800/millrd-presentation_14.jpg
            • marvins_dadM
              marvins_dad
              You guys have some great work. Love the play of the shadows and minimal textures.
              Here is a little dome I am working on for a Court House.
              My Gallery
              • C
                cheffey
                Wow, it's refreshing to see some native SU work. Excellent work. The simple style really works well on these very detailed models you are all showing.
                BROS RŌMAN BRÄUN
                • bazB
                  baz
                  here's a couple of sculptures to mix it up a bit.
                  baz
                  300mm high, cast bronze from carved forms.
                  3000mm high, cast bronze from carved form.
                  • daleD
                    dale
                    great stuff!
                    Here's one that I did a while back to solve some framing and truss issues.
                    • bmikeB
                      bmike
                      A few quick shots of recent work (design by another firm):
                      • Bryan KB
                        Looks great.
                        • brookefoxB
                          brookefox
                          Carkeek renovation exterior - CURRENT - more or less
                          This is the same as was posted before, only larger. Is it too large, obnoxious, requiring scrolling? I did notice some glitches. The improved quality doesn't show until you play it.
                          [flash=1280,745:3rskvj8r]http://www.youtube.com/v/QE8L8jD6xuA&amp;hl=en_US&amp;fs=1?rel=0&amp;hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/QE8L8jD6xuA&amp;hl=en_US&amp;fs=1?rel=0&amp;hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="1280" height="745"></embed></object>[/flash:3rskvj8r]
                          Direct link for smaller (formerly larger) display
                          ~ Brooke
                          • brookefoxB
                            brookefox
                            Thanks for your future response, ecofeco. I replaced the videos with the larger size.
                            ~ Brooke
                            • brookefoxB
                              brookefox
                              Thanks much, Pilou and Hieru!!
                              Native SU scenes, with added patience and practice. (For instance, this was processed overnight, and I'm not doing it again any time soon even though parts are too dark to see what I'm trying to show.) Set everything to a minimum (delays, size, fps, no shadows, etc.) to do tests. There are good tutorials online. I am far from expert.
                              ~ Brooke
                              • brookefoxB
                                brookefox
                                test embed - WIP - all my postings to this thread are of this same project
                                Carkeek renovation interior - CURRENT - more or less
                                [flash=1280,745:5o7ctb76]http://www.youtube.com/v/yX6vYGpw2kg&amp;hl=en_US&amp;fs=1?rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/yX6vYGpw2kg&amp;hl=en_US&amp;fs=1?rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="1280" height="745"></embed></object>[/flash:5o7ctb76]
                                Direct link for smaller (formerly larger) display of same video
                                For those like me, learning this linkage stuff, the above EQUALS:
                                Direct link for smaller display:
                                http://www.youtube.com/watch?v=yX6vYGpw2kg
                                AND IS:
                                'left bracket' url=http://www.youtube.com/watch?v=yX6vYGpw2kg]Direct link for larger display[/url 'right bracket'
                                ~ Brooke
                                • 2 / 2
