    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Extrude Edges by Rails by Face
    82 Posts 25 Posters 229.8k Views 25 Watching
    • simon le bonS Offline
      simon le bon
      Hi Pilou,
      Isfahan is a pure Gem (as you sometimes like to say) It would deserve a dedicated thread IMO.
      (I would like to know what softs Cristobal Vila had used.)
      And at the end you can now rotate each "lines volumes" between them! ๐Ÿ˜‰
      Can you please explain further. I don't understand what you mean. What you say let me think I have missed an important enhancement.. โ“
      A remark for TIG:
      Here and there, the process make Su krashes whith the following message: BUG SPLAT RC _ RESOURCE DLL NOT FOUND
      Is there some manipulations to avoid?
      *simon
        I believe that it's yet exist somewhere in this forum ๐Ÿ˜‰
        Cristobal uses in general Electric Image! It's a big fan of it ๐Ÿ˜‰
        You absolutly no missed something ๐Ÿ˜„
        Is just that your final example is some "Flat"
        So if you take each form you can rotate it ๐Ÿ˜‰
          simon le bon
          Electric Image Animation System v8.0 EIAS 8 full version $895.00
          ๐Ÿ˜Ž not for me dear Pilou
          Oh! I see! ๐Ÿ˜‰
          In my mind that wasn't really an "exemple" to show but a potential to point out. ->How can we obtain else way a regular evolution of a curve from a shape to another in SU without any calculation? I see plenty of possible applications in architecture..
          -> the other possibility offers a great time saving in building fences, trellis, framework...
          Here is a quick rather poor exemple
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch001_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch003_th.jpg
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch004_th.jpg
          ๐Ÿ˜• s
            yes you have also the 2 faces + path who give the evolution of a curve/ surface ๐Ÿ˜‰
            http://forums.sketchucation.com/download/file.php?id=32785
              simon le bon
              Kirill 2 faces + path exact, exact ๐Ÿ‘
                simon le bon
                I pursued my idea with : "La jolie petite fontaine"
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_048th.jpg
                *s
                  Morphing_24
                  Hey TIG
                  I have just downloaded this plugin and I tried to find an answer here if there is always a default number of ribs . Everytime, I find that there are always 21 ribs and I have no idea how to change it. How can I do it??
                  thanks
                    That number depends on the segments in the "rail/profiles's" curve - so add/subtract segments to change that...
                    Your 'rail/profile' must have 20 segments >> 21 "ends" ???
                    ๐Ÿ˜’
                      Morphing_24
                      thanks, problem solved ๐Ÿ˜„
                      But now i have one problem and another question.
                      I use a macbook pro and this only happens on mac not on the PC generally. The problem is that whenever I try to use the extrude edges by rail by face, and most of the time after I choose profiles and rails it crashes and the crashDialogHeader appears . What do you think it might be??
                      And the other question is if the number of ribs depend on the segments, I made a curve using the line tool but it looks really edgy, and if I draw a line with the bezier tool, how can I control the number of ribs using this tool and at the same time keeping it smooth?
                      Thanks in advance
                        The Bezier tool has an Edit option on its toolbar - so use that to change the number of segments in a curve - it's similar to how you can change the segmentation of an Arc in 'Entity Info'.
                        • charly2008C Offline
                          charly2008
                          Hi TIG,
                          I find your EEbyFace is very suitable for the construction of Gothic vaults. But one problem I have! How can I predetermine the orientation of the final Profile exactly? So far I have turned the initial profile until I accidentally had the desired direction. Is there a simpler solution?
                          Charly
                          Extrude.skp
                            When you draw the 'Profile' face flat on the ground its Y [green] axis is used as the Z up axis of the extrusion. If this extrusion starts flat it is kept at Y [?] ๐Ÿ˜•
                              joebamber
                              TIG - the other extrusion tools are awesome and i now use them as much as i can,
                              But the Extrusion by Rail by Face; just has never worked for me, i've included pictures for you to understand...
                              It always says i haven't selected the face and so wont extrude them across either rails or profiles (though as you can see, i defintly did select it),
                              I have a MAC pro with sketchup 7 - and on bootcamp in both MAC and PC worlds i get this trouble... ๐Ÿ˜ข
                                It's because your selected Face isn't made 'FLAT' - i.e. it must line flat on the ground, and its Y [green] axis will be taken as the 'UP' direction when extruding it. It doesn't matter if it faces up or down the tool assumes it's facing up anyway!
                                Just rotate it about an edge so it's 'flat' on the ground.
                                  stefx
                                  Hi TIG,
                                  I use a MacBook too and I have the same problem of Morphin_24....have you got any idea to solve that?
                                  Thank you very much.
                                  Stef.
                                    stefx
                                    You can control the number of points in a Bezier curve - as explained in my earlier response.
                                    Can you give any more info or an example SKP with a failing set of curves ?
                                    PM or posted ๐Ÿ˜•
                                      stefx
                                      It is a simple bunch of curves....could you explain how i can manage the segments with the bezier curves?
                                      thank you very much.
                                      Stef.
                                      12~.skp
                                        You don't have Beziers ๐Ÿ˜• They are 'Arcs' and you need to use the built-in tool 'Entity Info' to manage those. They have 12 segments which is reasonable. Reduce the face's size/shape to get 'bars' formed...
                                          shoeb_cars
                                          you are like right outta a scifi movie mahnnn....awesome
                                          RESPECT +++
                                          consider me ur fan... โ˜€
                                            joebamber
                                            Thanks TIG - Noobie error here --> <--
                                            ๐Ÿ˜„
                                            • 2 / 5
