    [Plugin] Extrude Edges by Rails by Face
    82 Posts 25 Posters 238.2k Views 25 Watching
    • charly2008C Offline
      charly2008
      Hi TIG,
      I find your EEbyFace is very suitable for the construction of Gothic vaults. But one problem I have! How can I predetermine the orientation of the final Profile exactly? So far I have turned the initial profile until I accidentally had the desired direction. Is there a simpler solution?
      Charly
      Extrude.skp
        When you draw the 'Profile' face flat on the ground its Y [green] axis is used as the Z up axis of the extrusion. If this extrusion starts flat it is kept at Y [?] πŸ˜•
          joebamber
          TIG - the other extrusion tools are awesome and i now use them as much as i can,
          But the Extrusion by Rail by Face; just has never worked for me, i've included pictures for you to understand...
          It always says i haven't selected the face and so wont extrude them across either rails or profiles (though as you can see, i defintly did select it),
          I have a MAC pro with sketchup 7 - and on bootcamp in both MAC and PC worlds i get this trouble... 😒
            It's because your selected Face isn't made 'FLAT' - i.e. it must line flat on the ground, and its Y [green] axis will be taken as the 'UP' direction when extruding it. It doesn't matter if it faces up or down the tool assumes it's facing up anyway!
            Just rotate it about an edge so it's 'flat' on the ground.
              stefx
              Hi TIG,
              I use a MacBook too and I have the same problem of Morphin_24....have you got any idea to solve that?
              Thank you very much.
              Stef.
                stefx
                You can control the number of points in a Bezier curve - as explained in my earlier response.
                Can you give any more info or an example SKP with a failing set of curves ?
                PM or posted πŸ˜•
                  stefx
                  It is a simple bunch of curves....could you explain how i can manage the segments with the bezier curves?
                  thank you very much.
                  Stef.
                  12~.skp
                    You don't have Beziers πŸ˜• They are 'Arcs' and you need to use the built-in tool 'Entity Info' to manage those. They have 12 segments which is reasonable. Reduce the face's size/shape to get 'bars' formed...
                      shoeb_cars
                      you are like right outta a scifi movie mahnnn....awesome
                      RESPECT +++
                      consider me ur fan... β˜€
                        joebamber
                        Thanks TIG - Noobie error here --> <--
                        πŸ˜„
                          stefx
                          Hi Tig,
                          Thank you for your tutorial...
                          managing the number of segments is working...!
                          In my last attempts I see the ribs are really thick.....see the screenshot... 😞
                          basically I cannot have the same result of your first post in this topic..
                          any suggestion?
                            d12dozr
                            Stefx, the ribs should be exactly the same size as your square(profile/face) on the ground, so maybe make your profile smaller?
                            http://goo.gl/f7ooYh
                              Ditto.
                              If you look in the picture in the first topic the face is quite tiny compared to the rib spacing...
                              The cross-section of the ribs will be made to match the face.
                              Scale it smaller if needed...
                              Small face >>> thin ribs
                              Big face >>> fat ribs
                              Face long in Y [green] >>> 'tall' ribs
                              Face long in X [red] >>> 'wide' ribs
                              etc πŸ˜’
                                joebamber
                                hello TIG ! - I'm trying to make a double curved mesh with only square faces.
                                With 'extrusion by rails'; if more than 1 rail is used; erasing coplanar edges (in the post curve production) cannot make the faces square and do not delete coplanar edges.
                                Do you get this too? (sorry if this another noobie error with these tools)
                                Joe
                                • jeff hammondJ Offline
                                  Hey Joe,
                                  Those lines aren't coplaner so they won't delete without deleting the adjoining faces as well
                                  To make a quad, you need at least two of the edges to be parallel. With complex curved surfaces like you're trying create, very rarely will a quad happen and even then, they're sporadically located throughout the mesh.
                                  Why do you need quads though if you don't mind me asking?
                                    joebamber
                                    Am trying to get quads so I can use *Paracloud for applying components across a mesh in sketchup, though if I use triangles, I get less control over the application of these components. I could always use soap and skin plugin, and then free-form, but was just wondering if it was possible with TIGs tools, as the curves are more accurate.
                                    Joe
                                      stefx
                                      Tig and the other guys,
                                      sorry for the late!
                                      Thank you for all your help!
                                      trying with small faces, it is working as I need.
                                      Stefx
                                        lapx
                                        Hello Tig,
                                        Will this work with a circle face and diagonal like the lattice by rail. Lattice by rail allows the diagonal. I notice the diagonal dialogue is not a choice with the rail by face.
                                        Is this correct? I would like to have pipes that cross diagonal to each other with glassin between.
                                          No... but you can use the EEbyRailsToLattice > diagonal edges... and then use the results to extrude the circular face along those paths [tip: add a cpoint at its center and select that too].Capture.PNG
                                          The are also other tools line 'Lines2cyl' or 'PipeAlongPath'that could do the second step in a slightly different way...
                                            lapx
                                            Thanks Tig,
                                            I got the diagonals from the EEbyrailstolattice but got lost At EEbyface. I would post a screen shot but I got a bugsplat error. Do I explode both sets if diagonals and then use eebyface? When I used eebyface it made the rails orthagonal. I did try the linsetocylinder and got that to worked. I missing one of your steps.
                                            • 4 / 5
