    [Plugin] Extrude Edges by Rails by Face
    82 Posts 25 Posters 235.3k Views 25 Watching
      That number depends on the segments in the "rail/profiles's" curve - so add/subtract segments to change that...
      Your 'rail/profile' must have 20 segments >> 21 "ends" ???
      πŸ˜’
        Morphing_24
        thanks, problem solved πŸ˜„
        But now i have one problem and another question.
        I use a macbook pro and this only happens on mac not on the PC generally. The problem is that whenever I try to use the extrude edges by rail by face, and most of the time after I choose profiles and rails it crashes and the crashDialogHeader appears . What do you think it might be??
        And the other question is if the number of ribs depend on the segments, I made a curve using the line tool but it looks really edgy, and if I draw a line with the bezier tool, how can I control the number of ribs using this tool and at the same time keeping it smooth?
        Thanks in advance
          The Bezier tool has an Edit option on its toolbar - so use that to change the number of segments in a curve - it's similar to how you can change the segmentation of an Arc in 'Entity Info'.
          • charly2008C Offline
            charly2008
            Hi TIG,
            I find your EEbyFace is very suitable for the construction of Gothic vaults. But one problem I have! How can I predetermine the orientation of the final Profile exactly? So far I have turned the initial profile until I accidentally had the desired direction. Is there a simpler solution?
            Charly
            Extrude.skp
              When you draw the 'Profile' face flat on the ground its Y [green] axis is used as the Z up axis of the extrusion. If this extrusion starts flat it is kept at Y [?] πŸ˜•
                joebamber
                TIG - the other extrusion tools are awesome and i now use them as much as i can,
                But the Extrusion by Rail by Face; just has never worked for me, i've included pictures for you to understand...
                It always says i haven't selected the face and so wont extrude them across either rails or profiles (though as you can see, i defintly did select it),
                I have a MAC pro with sketchup 7 - and on bootcamp in both MAC and PC worlds i get this trouble... 😒
                  It's because your selected Face isn't made 'FLAT' - i.e. it must line flat on the ground, and its Y [green] axis will be taken as the 'UP' direction when extruding it. It doesn't matter if it faces up or down the tool assumes it's facing up anyway!
                  Just rotate it about an edge so it's 'flat' on the ground.
                    stefx
                    Hi TIG,
                    I use a MacBook too and I have the same problem of Morphin_24....have you got any idea to solve that?
                    Thank you very much.
                    Stef.
                      stefx
                      You can control the number of points in a Bezier curve - as explained in my earlier response.
                      Can you give any more info or an example SKP with a failing set of curves ?
                      PM or posted πŸ˜•
                        stefx
                        It is a simple bunch of curves....could you explain how i can manage the segments with the bezier curves?
                        thank you very much.
                        Stef.
                        12~.skp
                          You don't have Beziers πŸ˜• They are 'Arcs' and you need to use the built-in tool 'Entity Info' to manage those. They have 12 segments which is reasonable. Reduce the face's size/shape to get 'bars' formed...
                            shoeb_cars
                            you are like right outta a scifi movie mahnnn....awesome
                            RESPECT +++
                            consider me ur fan... β˜€
                              joebamber
                              Thanks TIG - Noobie error here --> <--
                              πŸ˜„
                                stefx
                                Hi Tig,
                                Thank you for your tutorial...
                                managing the number of segments is working...!
                                In my last attempts I see the ribs are really thick.....see the screenshot... 😞
                                basically I cannot have the same result of your first post in this topic..
                                any suggestion?
                                  d12dozr
                                  Stefx, the ribs should be exactly the same size as your square(profile/face) on the ground, so maybe make your profile smaller?
                                  http://goo.gl/f7ooYh
                                    Ditto.
                                    If you look in the picture in the first topic the face is quite tiny compared to the rib spacing...
                                    The cross-section of the ribs will be made to match the face.
                                    Scale it smaller if needed...
                                    Small face >>> thin ribs
                                    Big face >>> fat ribs
                                    Face long in Y [green] >>> 'tall' ribs
                                    Face long in X [red] >>> 'wide' ribs
                                    etc πŸ˜’
                                      joebamber
                                      hello TIG ! - I'm trying to make a double curved mesh with only square faces.
                                      With 'extrusion by rails'; if more than 1 rail is used; erasing coplanar edges (in the post curve production) cannot make the faces square and do not delete coplanar edges.
                                      Do you get this too? (sorry if this another noobie error with these tools)
                                      Joe
                                      • jeff hammondJ Offline
                                        Hey Joe,
                                        Those lines aren't coplaner so they won't delete without deleting the adjoining faces as well
                                        To make a quad, you need at least two of the edges to be parallel. With complex curved surfaces like you're trying create, very rarely will a quad happen and even then, they're sporadically located throughout the mesh.
                                        Why do you need quads though if you don't mind me asking?
                                          joebamber
                                          Am trying to get quads so I can use *Paracloud for applying components across a mesh in sketchup, though if I use triangles, I get less control over the application of these components. I could always use soap and skin plugin, and then free-form, but was just wondering if it was possible with TIGs tools, as the curves are more accurate.
                                          Joe
                                            stefx
                                            Tig and the other guys,
                                            sorry for the late!
                                            Thank you for all your help!
                                            trying with small faces, it is working as I need.
                                            Stefx
                                            • 3 / 5
