[Plugin] Groups to Components
Overview
By request; bulk conversion of groups to components. The Group's name is transferred to the component's definition's name.If anything selected, it processes only the selection, else it processes the current context.
Access
Plugins -> Groups to Components
(Supports ThomThom's Menu)
SketchUp Plugins | PluginStore | SketchUcation
SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
(sketchucation.com)
Thanks Thom - i take it if there are multiple instances of a group, we'll get one component definition too (a la select toys)
how about mining into nested groups?
No - it doesn't. This was quickly produced according to some specific requirement in time of a deadline. It's very basic.
But I can update it to take into account multiple group-instances. -
That would be great
There is a logic issue here:
This plugin works in a selection or current context scope. Group instances can exist across this scope.
What is expected to happen to group instances outside the scope? -
You use
model.definitionsto get all of thegroup.instances[?] and then swap them out for the new component'sdefinition, even if they are outside of theactive_entities...Just as you could if you were swapping all
definition1.instancesfordefinition2with
definition1.instances.each{|ins|ins.definition=definition2}- which ignores 'context'
That's the thing - ignore the working context or not... ?
IF you are to replace all instances of a group with a component surely you'd [usually] should do it across the whole model.
Perhaps if there are 'other-context' instances of a group [which is easily checked by getting all instances and comparing their parents against the current context parent ?] then a simple dialog along the lines of"There are Instances of Group 'xxx' outside 'active_entities'\n Make a Component of these too ?" Yes/No- which would allow the user to choose to leave some unfixed or fix all...........
I'm wondering if this isn't a feature fit for this plugin after all.
There is a plug in Make_components by Matt66 I think is the author. It will change groups to single or one overall. Is there any diff here??
http://forums.sketchucation.com/viewtopic.php?t=17590
@matt666 said:
- Make a group of just one entity (right click or menu plugins/Make group)
- Make a component instance of just one entity (right click or menu plugins/Make component)
- Convert each entity in the selection in a single group (right click or menu plugins/Convert on single groups)
- Convert each entity in the selection in a single component (right click or menu plugins/Convert on single components)
- Convert the selected component into a group (right click or menu plugins/Make group)
I don't see any Group -> Component feature there... no?
Might be partly duplicate functions - but a key feature in this script was the naming: the definition inherited the group's name, not the instance.
@mac1 said:
I use it very often to convert single groups to components especially in models where some one has used a number of identical groups.
Does SketchUp still consider them copies of each other? If you select one and open Entity Info - does it say "Group (3 in model)" ?
If so, Selection Toys can convert them into components in one operation. -
I use it very often to convert single groups to components especially in models where some one has used a number of identical groups. Then you can use the component browser function of replace selected to replace all these converted groups with one component. Caution there is a quirk with the program. You also have to include in your selection a line also. http://forums.sketchucation.com/viewtopic.php?f=323&t=28395
If so, Selection Toys can convert them into components in one operation.Don't remember but you can take say 50 groups and then convert them to a single component or individual components (50) If my memory is correct it did use the same name for the component as the group number but what I don't like is how it moves around in the outliner and in a large model you have to then search to find the ones converted to replace as noted above
Here is a good test case for you if you want to go crazy. http://www.google.com/support/forum/p/sketchup/thread?tid=0a9b7b20ecc8e1bf&hl=en The model uses a number of identical groups and those should be reduced to a single definition
I did not see any model to download... where about in the thread is it?
thom hello.
thanks for the new plugins.
a question:
what is the difference with the "Group copies> Convert Into components" of your plugins SELECTION TOY 2.0. -
@diego-rodriguez said:
thom hello.
a question:
what is the difference with the "Group copies> Convert Into components" of your plugins SELECTION TOY 2.0.This one converts each group instance into a component instance. (plus it transfers the name to the definition)
Selection Toys will convert all instances of a group into instances of one component definition.
Matts plugin is still buggy, he has been very busy and not able to update many of his scripts - on the other hand Fredo's scale tools include a group to component command, so Thom you don't really need the extra effort for this plugin - but perhaps a CTRL toggle between the wider context and not could be handy...
