    Various rendering choices? -- Challenge!
    108 Posts 27 Posters 23.5k Views 27 Watching
      KarinaGM
      Wow! I love it. What are the settings for this material? and what material is this?
      Lights?
      **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
      -Benjamín Franklin.**
      • TaffGochT Offline
        TaffGoch
        notareal,
        I'm also intrigued by your Thea transparent material for your latest.
        Is this material available for download (here or at Kerky website.) ?
        Here's my latest (slowly improving) attempt at jade (still using Photoshop adjustments):
        http://i579.photobucket.com/albums/ss233/taffgoch/Jade_small.jpg
        (I'm testing only material changes, to get accustomed to the materials editor parameters in Kerkythea. I'll move on to lighting & environment, after I'm more comfortable with materials.)
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • N Offline
          notareal
          Sorry, unfortunatelly Thea materials cannot be used in KT, material systems are that different. Thea can do a conversion of KT materials, but as it does use heuristic, one might need to tune up imported complex KT materials.
          But to the render... The material uses thin film interference for color and fairly simple studio with HDR. You can find full Thea scene here (Note: need to use Thea RV378 or later).
            There are some other, interesting layers in there...
            • AnssiA Offline
              Anssi
              A first quick one with ArtLantis. 20 seconds.
              Anssi
              • TaffGochT Offline
                TaffGoch
                @solo said:
                I smell a render challenge.... 👍
                Frigging cool model, curious how it was made.
                Your wish is granted...
                I included hidden layers in the model, to demonstrate the development of the sinusoidal "Follow me" path. The methods are conceptually simple, and radial symmetries permit copies of components, so it's not as complex as it first appears.
                BTW, you may consider yourself challenged....
                -Taff
                • TaffGochT Offline
                  TaffGoch
                  Indeed! Extreme "lensing" magnification, by that orb.
                  Nice resultant caustics, too.
                  -Taff
                    KarinaGM
                    You mean you used thin film and nothing else? 😲
                    well, that HDRI must be a good one.
                    • boofredlayB Offline
                      boofredlay
                      Twilight Render. Progressive, 175 passes.
                      Iridescent Coated Aluminum material, two spot lights.
                      • soloS Offline
                        It must be a guy thing... we love rendering balls.
                          boofredlay
                          And mine is blue. 😄
                            Ah, nice trick indeed. MLT is "best" when there is (are) enough light(s). In some really shady areas it can get clear really slowly.
                            • TaffGochT Offline
                              TaffGoch
                              Gai,
                              I liked your iridescent render enough to give it a try, using Kerkythea, Metals_Ashikhmin_MLT, rainbow_metal_02, (M)etropolis(L)ight(T)ransfer (for a couple of hours):
                              http://i579.photobucket.com/albums/ss233/taffgoch/WeaveIridescent.jpg
                              Actually, I only used the resultant iridescent colors, saturated and layered, in Photoshop, to "colorize" a greyscale version of my original gold render. (Much faster than waiting for a long MLT render.)
                              [ My new wallpaper! ]
                              -Taff
                                boofredlay
                                Here is another angle.
                                • olisheaO Offline
                                  olishea
                                  like this one A LOT!! 👍
                                  oli
                                    +1 👍
                                      boofredlay
                                      😄 Thanks.
                                      • TaffGochT Offline
                                        TaffGoch
                                        Boof,
                                        Can you dish out some details?
                                        (I'm still learning materials, but need to move on to depth-of-field, etc.)
                                        -Taff
                                          Thanks for sharing the settings Eric 👍
                                          This is a great learning thread, much appreciated.
                                            boofredlay
                                            Sure. That last one was a metal texture in the Twilight Library called Aluminum NK. Part of the NK Metals.
                                            The rendering was an overnight shot, 10 hours I think, using a progressive setting called Metropolis Light Transport (BPT).
                                            All I did was open your model, click the face with the material eyedropper. Found the Aluminum NK and applied it. I then set the camera focal point inside the sphere and set the camera F number to 8.
                                            Finally I set the render size and progressive setting then hit render and went to bed. That simple.
                                            Edit. Oops I forgot. I placed 3 spot lights in the scene as well. One to the left, one to the right and one below. Each was a separate color. And I set the background color to black.
                                            • 3 / 6
