    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      jeabdc
      I don't understand about "assign_material"&"get_from_material".
      Thank Jeab from Thailand 😄
      • OxerO Offline
        Oxer
        @mariocha said:
        I'm so sorry to have to report the web dialogs still do not work on Mac here. Empty.
        I have other plugins that use them, and they work just fine.
        Hello mariocha,
        I work on Mac too, and the web dialogs don't appear but i find a solution for resolve this problem, edit "fur_en.rb" (with TextWrangler for example) and delete this sign "#" in the lines 638 and 1609, now the web dialogs will work.
        There is a problem yet, all performances of Crowd work but when you select a component for crowd the plugin create a noname group on surface but isn't a group with your component selected, it's a group of triangles, i don't know why.
        I hope that tak2hata help us for resolve this problem.
        Bye!
          tak2hata
          Thanks Mario and Oxer. 😆
          I change "#" in line(638 and 1309).
          now, version is 1.4d.
          I wish this work on mac very well.
          Bye!
          I will examine the part again.
          Please wait.(few days)
          Thanks a lot.
          by TAK2HATA
            tak2hata
            Hi jeabdc.
            Now, "assign_material"&"get_from_material" do not work.
            It assign the parameters of fur to current material.
            If exporter plugin include the function of make fur,It will perform.
            Thanks.
            by TAK2HATA
            • pyrolunaP Offline
              pyroluna
              is there any difference between 1.4b and 1.4d(c?) if I'm on a windows machine?
              • mariochaM Offline
                mariocha
                Feedback on 1.4d.
                Yes! the web dialogs show properly now.
                But ...
                Make crowd stops short at "Calc __ polygons".Screen shot 2010-06-25 at 08.57.26.png
                And for Fur, units have only one choice, Imperial, Input box and web dialog. normal ?
                %(#008000)[Mario C.
                  tak2hata
                  I update version1.4e.
                  Change is only one thing.
                  remove from context menu.
                  Hi ,Pyroluna.
                  Recently changes do not effect windows machine.
                  When I will change big thing ,I will increase version number to 1.5 higher.
                  @mariocha said:
                  Feedback on 1.4d.
                  But ...
                  Hi ,Mario.
                  I will examin that problem.
                  Please wait.
                  "Units" is only seeing units working with sketchup.
                  so it can not change.
                  Thanks.
                  by TAK2HATA
                  • romboutR Offline
                    rombout
                    finally had a project to test.
                    this is my first and only test yet, i did need to manually adjust everything to my desire though.
                    But im gonna 'play' with it a lot more!!!!!
                    • BurkhardB Offline
                      Burkhard
                      Here is the German file
                      fur_lang_de.txt
                      [http://www.ia-plus.de(http://www.ia-plus.de)]
                        MDM
                        man this plugin is awesome 😍 🎉 🎉 🎉 🎉 🎉 🎉
                        for landscaper couldn't be anything better, our dreams came through now we can grow grass in the computer, can't wait for the first mower 🤣 will be available
                        great stuff I love it, and it's so much fun 😄
                        Nothing is impossible :smile:
                        • F Offline
                          frv
                          On a Mac crowd maker still does not work.
                          The dialog now works fine but it does not create any crowd on the selected surface.
                          Hope you can update when you have any time. But don't worry, I am already fine with the current version making crowds with the fur dialog.
                          Francois
                          An idea for crowd maker, it would be nice if we can project a line that guides the crowd into certain directions. For instance at stations crowds tend to walk back and forth following routes. Maybe its possible to click a line, or a curved line and crowdmaker puts the crowd with a specified with along this line.
                          Francois
                            cnsdkliang
                            Very nice plugin. 😎 😆
                            • DareDevilD Offline
                              DareDevil
                              @tak2hata said:
                              Hi,all.
                              I updated this plugin to version1.3i.
                              Webdialog sees easier.(Thanks Diego.)
                              Parameter name translates by langage text file.
                              Thanks.
                              A french translation.
                              Thanks to you all !
                              Edit :
                              The file is now in UTF8 format
                              fur_lang_fr.txt
                                AcesHigh
                                people, you are talking about making grass, but if I try to make a simple rug, with fur, the file will jump in size to some 20-30mb! It will take minutes to import it into another file (like, inside of a house). And render times (to start the render) will soar in VRAY.
                                • jo-keJ Offline
                                  jo-ke
                                  sorry, but where do I copy the language file and how can I activate it?
                                  http://www.zz7.de
                                  • BurkhardB Offline
                                    Burkhard
                                    Just to the Plugins folder. After restart you'll find fur_en in the Menu>Plugins. But opening the browser it is in German.
                                    (Wurde allerdings noch nicht überprüft; Gegenvorschläge sind willkommen )
                                    • jo-keJ Offline
                                      jo-ke
                                      OK, very easy, it worked.
                                      Danke
                                      http://www.zz7.de
                                        Technohippy
                                        AWESOME... many thanks
                                        http://www.realitybuildingdesign.co.uk
                                          MartinK
                                          Just downloaded this and look forward to trying it out. My respect and admiration for all those who create and make these Rubies available is beyond words...so THANKS TO ALL.
                                            djrique
                                            Paulower
                                            I downloaded this translation Portuguese-BR, but it didn't work. I put it on the sketchup plugin folder like the instructions, how I do? Thx.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 32
                                            • 33
                                            • 17 / 33
