    Generating Plans?
    30 Posts 6 Posters 3.2k Views 6 Watching
      so setting the slice at the centre of each piece gives me a cutting plan, and also a positioning guide.
      Sure but you said that you have thousand of pieces ๐Ÿ˜ฎ
      So I am curious of the tricky trick for make that automatically ๐Ÿ˜‰
      • BoxB
        Well, so far I've tried several ways, all of them work, some better than others, I've yet to decide on the best way.
        The most basic way,
        I create a block of "Layer" the thickness I want, just by making one then doing multiple copies stacked on top of each other.
        Then I extrude the profile shapes, which I draw separately, through that block from the two different directions, Intersect all and then erase the bits I don't want.
        But having found Slice modeller and now Slice 3, I will probably attack things differently.
        Basically I'm trying to learn the best and quickest ways to create the shapes I want and get them down as workable plans.
        I'm not too interested yet in rendering etc, this is more for me to take the ideas out of my head and get them to working drawings.
        Generally I sculpt everything from Polystyrene first and then slice it up, rather messy and time consuming no matter how much fun it is.
        This is a rough unfinished torso in poly.
        http://i155.photobucket.com/albums/s296/storeben/Sculpt/Torso4-1.jpg
        And then I make that into something like this.
        http://i155.photobucket.com/albums/s296/storeben/Sculpt/FatsSmall.jpg
        That might explain why I can see the benefits of being able to draw in 3D
          As I see each Slices pieces is like a "vertical extrusion" following different axes?
          So Slices3 will be perfect!
          Just orient the volume in the good position ๐Ÿ˜‰
          http://forums.sketchucation.com/download/file.php?id=10513&mode=view
          • GaieusG
            Well, I do see a very big difference between that sexy woman and that old man!
            ๐Ÿ˜•
            • BoxB
              Yep, you got it.
              And any edge shaping I do by hand.
              This gives me the blank pieces of glass to start working with.
              Yes, well, I make all sorts. ๐Ÿ˜†
              • GaieusG
                Ok, just you wrote "And then I make that into something like this."
                ๐Ÿ˜†
                But I don't want to take you thread off-topic.
                ๐Ÿ˜‰
                • BoxB
                  I was thinking the same thing as I wrote it.
                  They were just two images in the different states that I had to hand.
                  Nothing wrong with a little hijack, it's got my post count moving so I don't get moderated anymore it seems.
                  • GaieusG
                    You were way over that already...
                    ๐Ÿ˜‰
                      I arrive after my lasagne and wine... and USA v Ghana half-time...
                      Use my Slicer...
                      Orient the form in the best direction before 'slicing'...
                      hic ๐Ÿค“ ๐Ÿ‘Š
                      • X
                        xrok1
                        i wonder if slicer could be modified for an option to keep curved edges?
                        PS, TIG did you ever make progress on the version with slots?
                        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                        • Mike LuceyM
                          Mike Lucey
                          Interesting application for SU, nice work Box. I imagine TIG will be along soon the USA v Ghana match. Its gone into extra time as its 1-1 at 90 min ๐Ÿ˜’
                            Here I am again [phew!] ...
                            Slicer + Slotter is currently 3rd on my list [barring more 'paid work']...
                            Back to the TV shortly... At this rate it's penalties...
                            PS: Thanks Pilou for the perfect example...
                            • BoxB
                              Thanks TIG I'm using it as we speak, however I can't find the lasagne plugin, the wine plugin is working wonders.
                              On a related note, once I have these slices, is there a simple way to print them?
                              Each one, for the scale model size, fits on an A4 page.
                              I imagine there must be a simple way to export them 1:1 into layout or as a pdf or some such, so that each is centred on it's own page?
                                Ghana score !!! Back later... ๐ŸŽ‰
                                • BoxB
                                  Thanks Mike, I missed this the other day, thanks for the "Nice Work" and yes I think this is a wonderful tool for my work, I've been looking for years for a way to think in 3D and actually produce a result. Nearly every part of sculptural work is "one off", lost wax, sand cast etc etc... yes yes you can do multiples, but to be able to draw in real 3d is something else. I dabbled some time back in a few other programs but it was like learning another language from another planet. With SU I have been able to produce workable stuff in a matter of weeks, and the things I see produced by people with real experience astounds me.
                                  I doubt I will ever move to the high end of the SU scale, but as a working tool it's fantastic.
                                    A astonished example in Athenes by Costas Varotsos
                                    http://storage.canalblog.com/10/08/323242/50042514.jpg
                                    http://storage.canalblog.com/63/45/323242/50042509.jpg
                                    • BoxB
                                      Stunning.
                                      • 2 / 2
