    Generating Plans?
    30 Posts 6 Posters 2.6k Views 6 Watching
    • BoxB Offline
      Thankyou gentlemen.
      I had already tried slicer but hadn't found slicer 3 which gives you the flattened copy.
      Excellent, I knew I shouldn't have been so reluctant to ask, didn't want to get the old Use the Search answer.
      Thanks again, now go back to arguing about who got there first. ๐Ÿ˜‰
        Not exactly that you want but can maybe help you (slice3) ๐Ÿ˜‰
        (maybe you must registered to this forum for see images)
        Slice3 by Tig (I f you take a big step, maybe that can works ๐Ÿ˜‰
        You can see also fragmentation-explosed view ๐Ÿ˜‰
        last plugs'version are always at the end of the fisrt post of a thread!!!
        • BoxB Offline
          I'll give it a try a bit later and let you know the results.
            Problem is that is for one group or composant so maybe you must make only one big component or group?
            Here box and cylinder are each a group, so I group all and that works fine ๐Ÿ˜‰(a group of groups)
            A tricky plug! ๐Ÿ˜Ž
              Try also fragmentation-explosed view ๐Ÿ˜‰
              When all are explosed maybe you can fall down all components in one click on the same plan with Drop by TBD ๐Ÿ˜‰
              • BoxB Offline
                Thanks Pilou, I had tried to do it with those two plugins but found it a bit cumbersome. My main problem was getting Eclate to explode it the way I needed. I also tried exim, but didn't manage to get what I wanted there either.
                It may be that I'm not quite understanding exactly how those plugins work.
                Slice 3 does it perfectly, couple of clicks and I have my plans all ready to make a scale model.
                Thanks for the help.
                  The only diffilcuty for you with Slice3 is to find the good measure's slice for your existant components ๐Ÿ˜‰
                  if you have something like that ๐Ÿ˜‰
                  • BoxB Offline
                    I think I understand what you are getting at, but all I need is the overall shape or outline of each piece. So in effect each of the layers you see in the image is nothing more than a square sided rectangle, so setting the slice at the centre of each piece gives me a cutting plan, and also a positioning guide.
                    If I was using shaped edges on the individual pieces then, yes, I think it would create a problem.
                      Sure but you said that you have thousand of pieces ๐Ÿ˜ฎ
                      So I am curious of the tricky trick for make that automatically ๐Ÿ˜‰
                      • BoxB Offline
                        Well, so far I've tried several ways, all of them work, some better than others, I've yet to decide on the best way.
                        The most basic way,
                        I create a block of "Layer" the thickness I want, just by making one then doing multiple copies stacked on top of each other.
                        Then I extrude the profile shapes, which I draw separately, through that block from the two different directions, Intersect all and then erase the bits I don't want.
                        But having found Slice modeller and now Slice 3, I will probably attack things differently.
                        Basically I'm trying to learn the best and quickest ways to create the shapes I want and get them down as workable plans.
                        I'm not too interested yet in rendering etc, this is more for me to take the ideas out of my head and get them to working drawings.
                        Generally I sculpt everything from Polystyrene first and then slice it up, rather messy and time consuming no matter how much fun it is.
                        This is a rough unfinished torso in poly.
                        http://i155.photobucket.com/albums/s296/storeben/Sculpt/Torso4-1.jpg
                        And then I make that into something like this.
                        http://i155.photobucket.com/albums/s296/storeben/Sculpt/FatsSmall.jpg
                        That might explain why I can see the benefits of being able to draw in 3D
                          As I see each Slices pieces is like a "vertical extrusion" following different axes?
                          So Slices3 will be perfect!
                          Just orient the volume in the good position ๐Ÿ˜‰
                          http://forums.sketchucation.com/download/file.php?id=10513&mode=view
                            Well, I do see a very big difference between that sexy woman and that old man!
                            ๐Ÿ˜•
                            • BoxB Offline
                              Yep, you got it.
                              And any edge shaping I do by hand.
                              This gives me the blank pieces of glass to start working with.
                              Yes, well, I make all sorts. ๐Ÿ˜†
                                Ok, just you wrote "And then I make that into something like this."
                                ๐Ÿ˜†
                                But I don't want to take you thread off-topic.
                                ๐Ÿ˜‰
                                • BoxB Offline
                                  I was thinking the same thing as I wrote it.
                                  They were just two images in the different states that I had to hand.
                                  Nothing wrong with a little hijack, it's got my post count moving so I don't get moderated anymore it seems.
                                    You were way over that already...
                                    ๐Ÿ˜‰
                                    • TIGT Online
                                      I arrive after my lasagne and wine... and USA v Ghana half-time...
                                      Use my Slicer...
                                      Orient the form in the best direction before 'slicing'...
                                      hic ๐Ÿค“ ๐Ÿ‘Š
                                      • X Offline
                                        xrok1
                                        i wonder if slicer could be modified for an option to keep curved edges?
                                        PS, TIG did you ever make progress on the version with slots?
                                        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                        • Mike LuceyM Offline
                                          Mike Lucey
                                          Interesting application for SU, nice work Box. I imagine TIG will be along soon the USA v Ghana match. Its gone into extra time as its 1-1 at 90 min ๐Ÿ˜’
                                          • TIGT Online
                                            Here I am again [phew!] ...
                                            Slicer + Slotter is currently 3rd on my list [barring more 'paid work']...
                                            Back to the TV shortly... At this rate it's penalties...
                                            PS: Thanks Pilou for the perfect example...
