    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 102.0k Views 35 Watching
    • C
      c.plassais
      Hi all,
      A little plugin for colored edge and dotted lines.
      Thanks to Fredo for help, Jim Foltzfor clinetools.rb and TIG for his plugin ListeLayerColors
      For the dotted line, the plugin use the curve fonction for keep faces
      Original Date : 14 May 2010 version 0.0
      Type : Plugin
      Description : Edge colored
      Usage : By ToolBar
      Version 0.1.0
      Fonction :
      Draw line single color by click
      Draw axis color line by click
      colorizes line with a single color, by selecting or all entities
      colorizes line with axis color, by selecting or all entities
      Dotted colored line by selecting or all entities
      Angles colorizes
      Use TAB key to modify tool's parameters
      Icons designed by Max (Cadfather)
      Please wait few seconds and click on the text message to continue
      [flash=800,600:pc1hrn24]http://content.screencast.com/users/c.plassais/folders/Jing/media/ffa39657-0281-4dd0-92de-f3bf45d0bc3e/ColorEdge.swf[/flash:pc1hrn24]
      Video links :
      http://www.screencast.com/t/ZmRhOTJjYjkt
      The original link http://www.biblio3d.com/plug-in-sketchup-f19/plugin-coloredge-colorisation-des-aretes-t1263.htm
      ****13/06/2010 Version 0.1.1 Fixed an error related to the translation into English with the use of the default color
      ****14/06/2010 Lite version add a lite version only with 8 basic colors
      ****17/06/2010 Version 0.2.0 add the possibility to colorize angles
      Edge by edge per click
      Edges connected to a face by clicking on the face
      All edges connected by double-clicking on face or edge
      ****25/06/2010 Version 0.2.2 Adding the management layer
      Draw an edge by layer, with a color of your choice or the color of the active layer.
      Recolor the edges by layer’s filter, with a color of your choice or the color of the active layer.
      Dotted lines by layer’s filter
      Thank to TIG for his plugin ListeLayerColors
      ****26/06/2010 Version 0.2.2 Add new icons designed by Cadfather, much prettier than mine Thank Max 👍
      ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
      Enjoy
      Christophe
      Icons designed by Max (Cadfather)French version 0.2.3English version 0.2.3English lite version 0.2.3 only 8 colors
      • CadFatherC
        CadFather
        Amazing script Christophe - Thank you for sharing!
        can i suggest an addition: while drawing the coloured edges it would be great if you could also choose any angle yourself
        enter an angle - assign it a colour, and voila! no need of the protractor.. 😍
        • C
          c.plassais
          Thank Cad
          It should be possible.
          Draw the line over a selected line or the plane orthogonal
          Christophe
          • C
            c.plassais
            404 Not Found
            (forums.sketchucation.com)
            Sorry
            Christophe
            • CadFatherC
              CadFather
              Thanks Chris - i think this is pure genius - and has a lot of potential for more...edges by layer or coloured angles
              jump to mind.. 👍 👍
              • shuraS
                shura
                Just great!
                • cmeedC
                  cmeed
                  Is it possible to colour By profile? Would also look cool to just have the outside of something highlighted.
                  Great plugin by the way.
                  • P
                    Panga
                    Thanks Christope, It'll be helpfull.
                    Regards
                    • W
                      watkins
                      Dear Chris,
                      Is this plugin only for wireframe models, or can one use it to colour the edges of models with faces? There is an icon in the toolbar which appears to be unused at the moment (multi-coloured checkerboard face). What does this do?
                      The functionality offered by the plugin is very interesting, but where might one use it? Am I being dense?
                      Kind regards,
                      Bob
                      • kenK
                        ken
                        Thanks for the plugin. Maybe I will be able to get the black screen drawing display.
                        On another note, would it be possible to limit the color selection to just the basic colors.
                        Again thank you for your plugin.
                        Ken
                        • C
                          c.plassais
                          Sorry if I dont understand everything I am a Frenchy and it is a real handicap 🤣
                          I am newbie with English and ruby
                          In response to your comments :
                          Cadfather
                          About protractor, the difficulty is the accuracy with the mouse to find the right angle with inference no problem. But I'll try.
                          Colorize only corners no problem, it’s fairly easy and it's a good idea
                          Cmeed
                          What do you mean to colour by profile ?
                          I see you using Mac, so no problem with the plugin apparently?
                          Watkings
                          no problem for use on the edges of a face.
                          The only restriction is if you do a push pull on the face, must be weld segments and after dotted repeat
                          The last icon is just for information, it is the color chart
                          Ken
                          I posted a "lite" version with only 8 basic colors
                          Christophe
                          • kenK
                            ken
                            Thank you for the very fast response and the plugin.
                            Ken
                            • MALAISEM
                              MALAISE
                              I was waiting for such a plugin for a while. Thanks a lot Chris for sharing
                              Pierre
                              • cmeedC
                                cmeed
                                Cmeed
                                Not really the person to ask about crashes as I've only used it once but happily with great success. No crashes.
                                heres what i was asking about in the pic - just profiles?
                                • C
                                  c.plassais
                                  sorry but I dont think this is possible.
                                  profile changes with position camera.
                                  The plugin will change line's material 😞
                                  • C
                                    c.plassais
                                    Hello
                                    As requested Cadfather, I have added the possibility to colorize angles
                                    [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
                                    Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                                    Christophe
                                    • CadFatherC
                                      CadFather
                                      thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
                                      (really sketchup fun changing the colours 😛 )
                                      if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
                                        Jörg
                                        Thank you Chris, this is amazing!!!!
                                        I waited for the dottet lines for years!
                                        Jörg
                                        • DavidBoulderD
                                          DavidBoulder
                                          I trick for color by profile. Not very smooth, but if you have to tools it works nice.
                                          • Work as normal in SketchUp
                                          • Drop views into Layout
                                          • Export from Layout as vector PDF
                                          • Import into Adobe Illustrator
                                          • Select "Final all lines with same width"
                                          • You can now isolate them and color or alter as desired
                                          note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
                                          David
                                          David Goldwasser
                                          OpenStudio Developer
                                          National Renewable Energy Laboratory
                                            stefx
                                            I use Mac and it looks like it doesn't work..... 😞
                                            any tips?
                                            stef.
                                            • 1 / 4
