    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • brookefoxB Offline
      brookefox
      Here's a modest working use of the tool, much as exampled: to create a square to round transition, in this case for building gutter work.
      I hope folks will post more.
      ~ Brooke
      • fredo6F Offline
        @oxer said:
        Hi Fredo6,
        The plugin is fantastic, i'm modeling a XIV Century Church and it has a lot of organic details, your plugin will help me to finish it.
        I know that the plugin is a beta phase but i find a conflict with other plugin 'set.rb' requested for svg.rb (to import svg files to sketchup), it's a minor problem for me but i say it for inform to other users if they find that the plugin does not work and they have installed this plugin. (I work on Mac)
        Thanks for all your plugins!! πŸ‘
        Bye!
        Where can I find this plugin svg and set.rb? I'd like to see where the conflict comes from.
        • JClementsJ Offline
          JClements
          Fredo:
          Is there a possibility that coplanar surfaces would be created with Curviloft?
          • fredo6F Offline
            @jclements said:
            Fredo:
            Do you have an example?
              Joarek
              Simply amazing. Great work Fredo!
                arjunmax09
                WHOA........▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ ..WHOAAAAAAAAAA!!!!β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–† FREDO.........YOU ARE ******* ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ AMAZING..ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ .PARDON MY LANGUAGE..BUT THIS PLUGIN IS REALLY OUT OF THE WORLD....HOLY______!!!!!!! MAN !!...You're not an ordinary human fredo....you have some calculators or electronic chips planted in your body...looking at your plugins ..it seems as if you're some cyborg or ....i don't know ..I don't have words to describe your talent...you rockβ–€ β–„ β–ˆ β–Œ ▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ πŸ˜„
                when you fail at something....you haven't really failed...you've found one way the thing will not work out
                  Jim
                  @oxer said:
                  Hi Fredo6,
                  Bye!
                  Fredo, it probably came from this thread:
                  http://forums.sketchucation.com/viewtopic.php?f=180&t=13475&p=99818#p99542
                  That was an old attempt at include rexml in the plugins folder, but rexml required a set.rb from the ruby language installation which is in direct conflict with the built-in Set class.
                    Yea, the Set class is one that does differ in SU from the native. Not exactly sure what the differences are - wish it was documented.
                    • fredo6F Offline
                      And using Sketchup::Set instead generates a lot of warning messages.
                      Anyway, I found a way to do without the Set class.
                        d12dozr
                        Karl, that's very neat, thanks for sharing πŸŽ‰
                        http://goo.gl/f7ooYh
                        • charly2008C Offline
                          charly2008
                          Hi to All,
                          three experiments with Curviloft and Perpendicular Square. Please show your ideas for what is possible with Curviloft. It's just fun to try out new ideas.
                          Karl
                            alangood
                            Hi Fredo,
                            Please excuse me with my newbie question.
                            I am trying to get your Curviloft plugin to work on my mac (OS X 10.6.3) in SU7. (Maybe it's working already, but I don't know how to access its functions.) I've only used SU about 100 hours over two years. But as I'm starting to design, manufacture and install concrete ping pong tables, SU is proving more and more useful!
                            I'm dying to create curved surfaces, so am grateful for what appears to be an ideal plugin.
                            I downloaded these plug ins: Driving Directions, Ruby Console, Curviloft, and others. I installed the .rb files on min Library/App Support/SU7. I restarted SU.
                            I saw that DD and RC added themselves to the top pull down menus. DD created a floating tool bar. But I couldn't find CL. I deleted all the plug ins from Library/App Support/SU7, and from Library/Internet PlugIns. I still see RC and DD in the pull down menus. I don't mind them there, but my goal is to start to use CL.
                            Do you have any suggestions? Next I'll try trashing SU and reinstalling it.
                            thanks,
                            Alan
                            Alan Good
                            President
                            hengetables.com
                            • fredo6F Offline
                              I don't think you need to reinstall SU.
                              Rather, check the footprint (2 files, 2 subfolders) which is indicated in the main post where you downloaded from (http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195).
                              If needed, unzip in a neutral directory and then move the two files and folders to the SU Plugins folder, which on Mac should normally be:
                              Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                              • fredo6F Offline
                                Although Sweep is not supported (i.e. loft along two rails), you can in some situations simulate it via the Skinning function.
                                Here the model posted previously by Diego, where you can generate the sweep shape by half.
                                • X Offline
                                  xrok1
                                  AWSOME! 😲
                                  • ely862meE Offline
                                    ely862me
                                    I don't know what is going on in ur head...but what comes out is MAGIC. 😲
                                    Only if Waat would insert your editing method to his Subdivide and smooth tool. I think mixing SDS with this plugin will produce the most powerful plugin of sketchup .
                                    Thank you!
                                    Elisei (sketchupper)
                                    Come and See EliseiDesign
                                    • ken28875K Offline
                                      ken28875
                                      Wow!!!! 😲 😲 😲
                                      I have been busy and did not go to the forums lately, but what a surprise when I logged in today and saw that plugin.
                                      Genial! Merci beaucoup, Fredo.
                                      Best,
                                      _KN
                                      Follow Your Dreams.
                                        rachmatrf
                                        Fredo, I am a real newbie, as you can see, this is my first post.... I know you've produce many plugins. And those plugins are really helpful I believe. I just started to check this plugin section of the forum, and found that you're a master here. Thank you very much for bringing sketchup to a further stage as a modelling software... πŸ˜„
                                        I just downloaded your curviloft plugin and already installed it on my sketchup7 pro (windows7 platform). But, I got some real problem related to selection. I tried to follow the tutorial step by step. I tried the pre-selection mode. I selected the paths (two curves, I put one above the other), then click the "face icon" button. As we know, the curve is constructed by several connected lines (segment). And as I click the "face icon", just one segment can be selected, and I've no idea how to select the whole segment of the curve (or both curves).. I got the same problem also to apply the loft between two surfaces.. I just can select one segment.. 😒
                                        I can't even select the whole segment of the curve using manual selection mode... Forgive me if my problem is very basic thing... FYI, I Already tried the whole selection options... but nothing could worked it out. Do you know how to solve it? Please..., your help will be greatly appreciated..
                                        Thanks a lot.....
                                        • fredo6F Offline
                                          Rachmatrf,
                                          Can you post your model so that I get a better view of your situation.
                                          Also watch the videos to get some inspiration on how to select contours. Documentation is in my plan, but you can at least get some visual hints.
                                          • OxerO Offline
                                            Oxer
                                            Fredo wrote,
                                            Hi Fredo6, this is the plugin "svg.rb" for import svg files into sketchup, the plugin need other files included in the folder, the "set.rb" is the conflict file with Curviloft.
                                            svg.rb & set.rb, rexml folder, forwardable.rb
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 65
                                            • 66
                                            • 29 / 66
