    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • fredo6F Offline
      @didier bur said:
      Hi Fredo6,
      I finally got it to start without a bugsplat. Select edges, spline, and here is the error message:
      I located the problem, but it must depend on the model somehow (most likely the orientation of curves).
      I'll put a protection (or an error message) to avoid the bugsplat anyway and will republish.
      • charly2008C Offline
        charly2008
        Hi Fredo,
        your plugin is a miracle. Could be a must for historical models.
        Karl
        • OxerO Offline
          Oxer
          Hi Fredo6,
          The plugin is fantastic, i'm modeling a XIV Century Church and it has a lot of organic details, your plugin will help me to finish it.
          I know that the plugin is a beta phase but i find a conflict with other plugin 'set.rb' requested for svg.rb (to import svg files to sketchup), it's a minor problem for me but i say it for inform to other users if they find that the plugin does not work and they have installed this plugin. (I work on Mac)
          Thanks for all your plugins!! πŸ‘
          Bye!
          • brookefoxB Offline
            brookefox
            Here's a modest working use of the tool, much as exampled: to create a square to round transition, in this case for building gutter work.
            I hope folks will post more.
            ~ Brooke
            • fredo6F Offline
              @oxer said:
              Hi Fredo6,
              Bye!
              Where can I find this plugin svg and set.rb? I'd like to see where the conflict comes from.
              • JClementsJ Offline
                JClements
                Fredo:
                Is there a possibility that coplanar surfaces would be created with Curviloft?
                • fredo6F Offline
                  @jclements said:
                  Fredo:
                  Do you have an example?
                    Joarek
                    Simply amazing. Great work Fredo!
                      arjunmax09
                      WHOA........▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ ..WHOAAAAAAAAAA!!!!β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–†β–‚β–ƒβ–…β–† FREDO.........YOU ARE ******* ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ AMAZING..ٌ۩ﺴ ﺴ۩ٌ ٌ۩ﺴ ﺴ۩ٌ .PARDON MY LANGUAGE..BUT THIS PLUGIN IS REALLY OUT OF THE WORLD....HOLY______!!!!!!! MAN !!...You're not an ordinary human fredo....you have some calculators or electronic chips planted in your body...looking at your plugins ..it seems as if you're some cyborg or ....i don't know ..I don't have words to describe your talent...you rockβ–€ β–„ β–ˆ β–Œ ▐▀ β–„ β–ˆ β–Œ ▐ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ β–€ β–„ β–ˆβ–Œ ▐░ β–’ πŸ˜„
                      when you fail at something....you haven't really failed...you've found one way the thing will not work out
                        Jim
                        @oxer said:
                        Hi Fredo6,
                        Bye!
                        Fredo, it probably came from this thread:
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=13475&p=99818#p99542
                        That was an old attempt at include rexml in the plugins folder, but rexml required a set.rb from the ruby language installation which is in direct conflict with the built-in Set class.
                          Yea, the Set class is one that does differ in SU from the native. Not exactly sure what the differences are - wish it was documented.
                          • fredo6F Offline
                            And using Sketchup::Set instead generates a lot of warning messages.
                            Anyway, I found a way to do without the Set class.
                              d12dozr
                              Karl, that's very neat, thanks for sharing πŸŽ‰
                              http://goo.gl/f7ooYh
                                charly2008
                                Hi to All,
                                three experiments with Curviloft and Perpendicular Square. Please show your ideas for what is possible with Curviloft. It's just fun to try out new ideas.
                                Karl
                                  alangood
                                  Hi Fredo,
                                  Please excuse me with my newbie question.
                                  I am trying to get your Curviloft plugin to work on my mac (OS X 10.6.3) in SU7. (Maybe it's working already, but I don't know how to access its functions.) I've only used SU about 100 hours over two years. But as I'm starting to design, manufacture and install concrete ping pong tables, SU is proving more and more useful!
                                  I'm dying to create curved surfaces, so am grateful for what appears to be an ideal plugin.
                                  I downloaded these plug ins: Driving Directions, Ruby Console, Curviloft, and others. I installed the .rb files on min Library/App Support/SU7. I restarted SU.
                                  I saw that DD and RC added themselves to the top pull down menus. DD created a floating tool bar. But I couldn't find CL. I deleted all the plug ins from Library/App Support/SU7, and from Library/Internet PlugIns. I still see RC and DD in the pull down menus. I don't mind them there, but my goal is to start to use CL.
                                  Do you have any suggestions? Next I'll try trashing SU and reinstalling it.
                                  thanks,
                                  Alan
                                  Alan Good
                                  President
                                  hengetables.com
                                  • fredo6F Offline
                                    I don't think you need to reinstall SU.
                                    Rather, check the footprint (2 files, 2 subfolders) which is indicated in the main post where you downloaded from (http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195).
                                    If needed, unzip in a neutral directory and then move the two files and folders to the SU Plugins folder, which on Mac should normally be:
                                    Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                                    • fredo6F Offline
                                      Although Sweep is not supported (i.e. loft along two rails), you can in some situations simulate it via the Skinning function.
                                      Here the model posted previously by Diego, where you can generate the sweep shape by half.
                                      • X Offline
                                        xrok1
                                        AWSOME! 😲
                                        • ely862meE Offline
                                          ely862me
                                          I don't know what is going on in ur head...but what comes out is MAGIC. 😲
                                          Only if Waat would insert your editing method to his Subdivide and smooth tool. I think mixing SDS with this plugin will produce the most powerful plugin of sketchup .
                                          Thank you!
                                          Elisei (sketchupper)
                                          Come and See EliseiDesign
                                          • ken28875K Offline
                                            ken28875
                                            Wow!!!! 😲 😲 😲
                                            I have been busy and did not go to the forums lately, but what a surprise when I logged in today and saw that plugin.
                                            Genial! Merci beaucoup, Fredo.
                                            Best,
                                            _KN
                                            Follow Your Dreams.
                                            • 11
                                            • 65
                                            • 66
                                            • 9 / 66
