    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • V Offline
      vidy
      Hai Fredo, thanks for this pre release ver, im really excited with this capability, thanks againn 😍
      regards,
      still so much to learn..
      • cmeedC Offline
        cmeed
        I think you need to draw first the rails that give the shape of the junction, making sure that each surface would be closed by 4 or 3 curves. Then you can apply the Skinning function.
        Fredo[/quote]
        Thanks but i couldn't get the rails working with this. I don't understand it completely yet. i need to wait till the documentation comes out as i seem to find myself with alot of colourful lines with 7,8,9 written on them.
        But on the up side i worked the path method see pics YES!
        look at me using colour edge plugin!
        result!!!!
        • charly2008C Offline
          charly2008
          This is a new milestone. I find this tool opens up new design possibilities. The loft tool works very well and easy to understand. Especially because the geometry of the forms can be calculated in advance. Thanks for this wonderful tool.
          The last image below is an almost perfect Moebius band. Unfortunately, the last segment is not closed.
          Moebius.skp
            This is already too impressive 👊
            • fredo6F Offline
              Here is the Moebius ribbon with closure
              Moebius - curviloft.skp
              • H Offline
                hgdn
                Fredo,
                Great impact for SU users in creating 3d models. With yours I am not afraid of creating 3d models from now on..still new!!! Easy and powerful plugins eventhough you give bug warnings but I have not seen any thing so far!!
                Genius and generous Fredo 😄
                  Ruturaj
                  Thank you Fredo Sir,
                  you are great
                  Many Many Many THANK you.
                  I'm shocked man 😲
                  This plugin is very helpful thank you.
                  Thanks,
                  RuturaJ
                    @lapx said:
                    I've tried it as well. Thanks Fredo for such a wonderful. Can you get it to maintain a sharp edge? I noticed it round the corners. Would be nice to have this as an option if available.
                    These tools do work very well.... 💚
                    The form is auto-smoothed ? You can always select the resultant group and right-click > soften, and set sliders to 0 and all edges will un-smooth/un-soften etc...
                    or view > hidden_geometry toggle to 'on' and use erase+ctrl+shift to un-soften wiped edges [also remember that erase+ctrl softens wiped edges and erase+shift hides wiped edges - but you must select hidden lines to unhide them using entity info, as there is not erase >> unhide equivalent key-combo...]
                    • massimoM Offline
                      massimo Moderator
                      Already a must-have plugin. Thank you Fredo. 👍
                        charly2008
                        Some ideas with Grow and Curviloft
                        Untitled.skp
                          charly2008
                          In some forms it comes to interesting but not unanticipated results.
                          • fredo6F Offline
                            Charly,
                            There are still missing features in Loft along Path, in particular about spiral specific treatments.
                            But if you can post your model, I can have a look and see if this can be handled.
                              charly2008
                              Hi Fredo,
                              attached you wil have a similar model because the first one i have deleted. I selected each segment separately. Thanks again for your plugin, thanks for your efforts.
                              Karl (Charly)
                              Test1.zip
                                charly2008
                                The same shape with small modifications
                                  lapx
                                  Thanks Tig! I'll try it out 🎉
                                  • Didier BurD Offline
                                    Didier Bur
                                    Hi Fredo,
                                    I get a bugsplat EVERYTIME I try to "loft by spline", no matter the method used. Any possible conflict with other plugins ?
                                    F: J'ai un bugsplat directement après avoir cliqué l'icône, quelle que soit la méthode de sélection que j'utilise pour les faces, contours, chemins, etc. Est-ce qu'il y a à ta connaissance un conflit possible avec un autre plugin (ceux de TIG par exemple, qui font un job similaire ?).
                                    Je suis scotché, là...
                                    DB
                                    • fredo6F Offline
                                      @didier bur said:
                                      Hi Fredo,
                                      At what step do you get the bug splat: selection, preview, generation of geometry?
                                      Is it with any model?
                                      I don't think there are conflicts with other plugins, and anyway not TIG's ones, because I have them in active my environment.
                                        Didier Bur
                                        @Fredo6: at any time, either in a blank new model, or in a model with geometry in it.
                                        The bugsplat occurs as soon as I click on the icon, once I have selected contours or faces and the path (no problem with selection. 😲
                                        I'm considering to start with an empty Plugins folder (except curviloft of course 😄 ) to see what happens.
                                        DB
                                        • urgenU Offline
                                          urgen
                                          ...Oh, Fredo,thank you very much! 👍
                                          --pupil forever...------
                                            djorkaeff
                                            Very good and promising plugin. Thank you for your effort and generosity!
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 65
                                            • 66
                                            • 30 / 66
